Tile Over Vinyl Floor - Tiling - Contractor Talk
Old 10-18-2017, 06:42 PM   #1
Groundupdave35's Avatar
Trade: Handyman
Hello
Looking for some insight on installing tile over vinyl flooring. Talked to another tile installer and he suggested removing top of vinyl with adhesive solvent ( so thinset can adhere to), lay thinset, then hardie board over. The floor is also low in some spots so he also suggested putting extra thinset in low spots (prior to laying hardie backer down) then fasten to floor. Is this a proper way to do this? Thanks!
Groundupdave35 is offline
Old 10-19-2017, 09:24 AM   #2
avenge's Avatar
Rewards Points: 3,218
Re: Tile Over Vinyl Floor
No it's not quite that simple and I can't think of a good reason to tile over vinyl.
avenge is online now
Old 10-19-2017, 09:27 AM   #3
Trade: Handyman
So would I have to take up all the vinyl squares? What about all the adhesive on floor? What would you suggest
Old 10-19-2017, 11:24 AM   #4
rblakes1's Avatar
Rewards Points: 2,016
It can be done as long as you meet all requirements
https://www.schluter.com/schluter-us...vinyl-flooring
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 10-23-2017, 04:15 PM   #5
Archbishop of Titipu
Sweebs's Avatar
Trade: Residential Remodeling
Rewards Points: 75
As long as the vinyl is bonded well I see no problem, go at it with a belt sander to give it tooth if it makes ya feel better, but modified thinset and proper schedule of screws will have your hardi or durock attached perfectly. We've even successfully used ditra over sheet vinyl.
I just cash in on the fact that I'm good looking, and I've got a nice figure and girls like me.
Sweebs is offline
Old 10-26-2017, 07:58 PM   #6
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 33
Schluter Ditra can go over vinyl flooring. I would not recommend it personally tho.
cedarboarder is online now
Old 10-26-2017, 08:05 PM   #7
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,062
If you're screwing down hardi then there should be no issues.
illbuildit.dd is offline
Old 10-26-2017, 08:28 PM   #8
Kumpel's Avatar
Rewards Points: 28
This
Kumpel is offline
Old 10-26-2017, 10:57 PM   #9
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
Screw Cement board. Heavy. Hard to cut and work with. The dust will kill ya and the mess is not worth it.
As long as the vinyl is secure I would Mapei EcoPrim Grip over it. Sand it first. Wash it down with denatured alcohol. EcoPrim Grip and then Ditra or just tile if the subfloor underneath is sufficient.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
Old 10-26-2017, 10:58 PM   #10
Hair Splitter
Trade: General
Rewards Points: 214
You don't just screw it down. That's the issue. You must apply thinset then the board, then screw it down. The thinset won't just adhere to the vinyl unless you are using some sticky icky like Ardex 77.
Old 10-26-2017, 10:59 PM   #11
Hair Splitter
Trade: General
Rewards Points: 214
You could also Ardex GPS when mixed with Ardex E 25 over the vinyl.
Old 10-29-2017, 10:38 PM   #12
Tile-guy's Avatar
Trade: Tile installations
Rewards Points: 116
You can use Eco Prim Grip Mapei primer so adhesive sticks to it. But if it particle board under it I would never tile over it. Remove it and put plywood down
Tile-guy is offline
Old 10-29-2017, 10:52 PM   #13
Trade: Handyman
Thank you guys for all the advice!!I?ve never heard of the ardex stuff or the ecoprim. I will have to research it a little more, but will probably end up using.
Old 11-01-2017, 07:07 PM   #14
General Contractor
slickhick's Avatar
Trade: Tile and Hardwood
Rewards Points: 16
When tiling over top of anything other than a subfloor, I recommend using a thinset additive (like this one).
It's obviously more expensive than water, but so are call-backs.
I've not used the Mapei product mentioned above, but if you go with hardie, get the additive. Glue it, screw it, and you'll be fine.
slickhick is offline
Old 11-01-2017, 07:59 PM   #15
Hair Splitter
Trade: General
Rewards Points: 214
If you get a highly modified thinset there is no need for the additive.
Old 11-01-2017, 08:03 PM   #16
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,303
Plain old Versabond modified thinset will work just fine if the floor is solid and clean.
MarkJames is online now
Old 11-01-2017, 08:09 PM   #17
General Contractor
slickhick's Avatar
Rewards Points: 16
Do you have a brand you recommend? I'd be interested in trying it out.
Old 11-01-2017, 09:48 PM   #18
Hair Splitter
Trade: General
Rewards Points: 214
I use Mapei, but any modified thinset would do. For tile over anything other than tile substrate I would use Kerabond with Keralastic.
Old 11-01-2017, 11:25 PM   #19
avenge's Avatar
Additive is just a waste of time. What are you mixing it with, CustomBlend? Just upgrade to VersaBond or others.
The Following User Says Thank You to avenge For This Useful Post:
TNTSERVICES (11-01-2017)
Old 11-05-2017, 05:27 PM   #20
General Contractor
slickhick's Avatar
Rewards Points: 16
I use VersaBond. I recommend using an additive in cases like this because like I said, call-backs are expensive. The additive seems like an inexpensive way to avoid them.
I've had jobs where I go in and demo a tile floor that was laid over vinyl (or over plastic laminate in the case of countertops) and I'll hit hollow spots where the mud has broken up over the years, as well as spots where the mud sheared right off the substrate (no backer there, but backer could, in theory, react the same way). After doing a little research I decided that utilizing an additive would be a good way to potentially avoid issues like this.
I'm not preaching this as a fool-proof method, just adding a layer of protection to the work.
Ceramic Tile on Wood Plank Floor Fresh Decks Tiling 9 02-26-2014 06:15 AM
large format tile Video charimon Tiling 9 10-11-2012 09:38 PM
advice needed on comm vinyl tile job 21gun Flooring 10 08-31-2009 08:30 PM
Tile over vinyl pros and cons tileguy7 Tiling 23 01-17-2009 09:53 PM
