Tile Over Lightweight Concrete
Old 05-30-2008, 04:55 PM   #1
wopachop's Avatar
Trade: construction
Was going to lay these tiles directly down on the 2x4's and lightweight concrete. The height between tiles and carpet is perfect we dont want to go any higher if possible.
Question is for you guys with the years of experience will this hold up? What can i do to insure a solid bond? Thanks everyone
wopachop is offline
Old 05-30-2008, 06:40 PM   #2
Tile Contractor
Bud Cline's Avatar
Re: Tile Over Lightweight Concrete
It'll never last. You don't want to install single tiles over those two different materials. Lighweight concrete can be bad news and tile over the dimensional wood is never a good idea.
Bud Cline is offline
Old 05-30-2008, 07:28 PM   #3
bathroom guru
jarvis design's Avatar
Bud's right, it'll never last!! Your could put some Schluter Ditra mat on top of your existing sub-floor/2x4's which is an uncoupling membrane. It is only about 1/8-3/16" thick so it won't add a lot to your overall height
jarvis design is offline
Old 05-30-2008, 07:33 PM   #4
wopachop's Avatar
Trade: construction
damn it!! in this application i guess we will just break out the lightweight concrete and 2x, then frame it in and use ply and backerboard.
what about on 2nd story apartment bathrooms floors. where the floor is completely lightweight concrete?
wopachop is offline
Old 05-30-2008, 07:44 PM   #5
wopachop's Avatar
Trade: construction
thanks i missed this post. might have to give that stuff a try
wopachop is offline
Old 05-31-2008, 09:19 AM   #6
Professional Remodeler
firemike's Avatar
Try it, you'll like it.
I agree with Bud also, the slate is really soft and will crack easily over the differing substrates. The Kerdi adds very little to the height, and you won't have any problems down the road.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 06-01-2008, 07:33 PM   #7
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
What I'll usually do is go over the whole area with a paint roller and Keralastic liquid latex and let it dry overnight.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 06-01-2008, 09:47 PM   #8
Its all ball bearings
angus242's Avatar
Trade: Tile
What's the benefit of this? Do you then use Kerabond/Keralastic (or similar) for thinset when setting tile?
angus242 is online now
Old 06-01-2008, 10:45 PM   #9
tile contractor
The benefit is that it'll stop the concrete from powdering as most lightweight concretes are notorious for, and the tile will stay, and yes, I'll always use K/K over it afterward.
Tile over cold concrete ponch37300 Flooring 6 02-01-2009 12:29 AM
Installing tile on a concrete floor in a basement... do I need a membrane? EZ Mode Ceramic & Stone Tile 33 05-10-2008 12:56 AM
Tile Over Concrete Basement Floor Tommy C Ceramic & Stone Tile 0 04-07-2008 10:40 AM
Removing Tile On Concrete dougchips Ceramic & Stone Tile 20 12-01-2007 08:02 PM
Concrete over old asbestos tile... Cellomangler Flooring 10 10-20-2007 05:52 PM
