Tile Over Existing Shower Surface
Old 03-04-2009, 12:29 PM   #1
SK Builders's Avatar
Trade: Remodeling contractor
Hi guys, I have a question concerning a customers existing shower surface. It is 4' x 6' and has a stucco like coating over the entire area. It is a walk-in shower with a small speed bump like curb. This coating is almost like a plastic drywall mud kind of coating. Anyhow, she wants to tile over it because she doesn't like the hard water stains on the floor of the shower. My question is, what will bond to the existing curb to create a new square curb to tile to? This is only my second shower, so I am unsure if mortar or thinset will stick to the existing coating...any help would be appreciated. Thanks, Scott
SK Builders is offline
Old 03-04-2009, 03:11 PM   #2
Remodeling GC
kevjob's Avatar
Re: Tile Over Existing Shower Surface
are you sure there is no water damage or leaking? usually these old showers require re-building them.
kevjob is offline
Old 03-04-2009, 03:37 PM   #3
No, this is only a couple years old...it has a stain in the coating that is the same color as the floors. I am going to try and find out who the builder was and find out what the surface actually is...and thanks
Old 03-04-2009, 04:11 PM   #4
tile mason
MattCoops's Avatar
If you're taking the time to do the job why not start fresh with correct preperation and know the installation will last.
You'd probably spend more time and money in "mickey mousing" the job halfass rather than removing the odd materials and creating a suitable substrate that meets ANSI standards and TCNA recommendations.
Some sledge hammers, flatbars, and cold chisels are invalubable demo tools, if not a power demo hammer.
MattCoops is offline
The Following User Says Thank You to MattCoops For This Useful Post:
MALCO.New.York (03-04-2009)
Old 03-04-2009, 07:30 PM   #5
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Agreed 1000%
How can you be responsible for something you didn't install? Covering up another contractor's work in a shower is not something I could sleep with Whose fault will it be if/when it leaks? Thats a finger pointing contest you're sure to lose.
Precision Flooring
(772) 237-9900
PrecisionFloors is online now
Old 03-04-2009, 07:50 PM   #6
Update...After revisiting the job, it appears that the previous contractor did NOT waterproof the shower at all. It rains water through the subfloor when turning on the shower...it is a subfloor thank goodness. The original question was how to bond two surfaces together, but now that won't be a problem as it is all coming out anyhow...thanks, Scott
Old 03-05-2009, 11:01 AM   #7
bathroom guru
jarvis design's Avatar
I hope you are going to build your customer a shower that lasts!!
Schluter Kerdi and Laticrete Spectralock Grout= "bullet proof"
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 03-05-2009, 11:13 AM   #8
I am going to check that out...around here, they either use a rubber liner(which sucks imo) or we fiberglass the area...
Old 03-05-2009, 11:34 AM   #9
Hey Jarvis, am I to assume that you can just thinset over the kerdi and start tiling? I also noticed that, in the video, they were going right over drywall...no longer need hardi-backer on walls? Thanks, Scott----update, I see I can tile right over the kerdi, pretty cool as now I don't need the second layer of mud now! Oh and thanks for your help, I really appreciate it! I have to order the kerdi, but I think that it will save me time, depending on how much they want for it!
Old 03-05-2009, 12:53 PM   #10
Can you explain the process you use? I am pretty well versed in 'glassing (used to build boats eons ago). What mortar do you use to bond to the glass?
Precision Flooring
(772) 237-9900
Old 03-05-2009, 01:30 PM   #11
You don't. You have to put in another mortar bed to tile on...seems like the kerdi might be alot quicker system than two mortar beds and fiberglass.
Old 03-05-2009, 03:06 PM   #12
Remodeling GC
kevjob's Avatar
yup and waterproof on the surface .
kevjob is offline
Old 03-06-2009, 12:26 AM   #13
Gotcha. Yeah Kerdi would definitely be quicker.
Precision Flooring
(772) 237-9900
Old 03-06-2009, 10:26 AM   #14
bathroom guru
Going over drywall is certainly approved, however, I do not like it myself. I still install concrete board, then kerdi. I know it is overkill, but, its hard to change my ways on some things!!
If you plan on doing a lot of Kerdi, I would invest in a Kerdi trowel (from Schluter). It puts just the right amount of thinset to set the Kerdi and is a damn nice trowel (made by Rubi)
Another thing, if you are doing a lot of tile work I would suggest going to a Schluter training course. They are normally 2 days and cover Kerdi, Ditra, plus a lot of information on substrates, concrete, etc. I went just last year and can honestly say I learned a lot - this after being in the business for close to 20 years.
Good luck with your install!!
519-495-4062
Old 04-02-2009, 03:19 PM   #15
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Originally Posted by bathmagician View Post
mr jarvis are you SURE tile on drywall is still an approved install / if I remember right its not in any WET area I don't have my book with me
so I could be wrong but doubt it. Doug Bathmagician Its magic
He meant kerdi over drywall...
You need to slow down a tad a let people get to know you before you throw your weight around and get all sassy... Build some rapport and a reputation first.
Just a friendly bit of advice...take it or leave it.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 04-02-2009, 06:45 PM   #16
R&D Tile's Avatar
Trade: Tile installations
Just another know it all who needs to do his homework and read up some more.
R&D Tile is offline
Old 07-06-2009, 01:42 AM   #17
coveinspiration's Avatar
Trade: Tile Sles and Installations
Thumbs up to Jarvis Design! Good advise. I am gonne get myself into one of these clinics.
coveinspiration is offline
how many courses for ceramic tile shower walls? Bazooka Joe Ceramic & Stone Tile 19 02-14-2009 11:06 PM
Tile over Tile? ak_aiken Ceramic & Stone Tile 9 03-29-2008 11:57 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Bathroom Tile Shower Remodel, 12" travertine with 4" alternating border MattCoops Flooring Picture Post 2 04-29-2007 10:12 PM
How to tile a shower floor??? CALKAM Carpentry 6 03-19-2007 08:23 PM
