Tile In Mouth Of Fireplace.
Old 09-23-2008, 11:51 PM   #1
Home Improvement Contract
Apex McGann's Avatar
Trade: Handyman
Cool
Hi all,
I'm bidding on framing out a brick fireplace that the client want to tile the lower half of. My question is; is the client asking for heat related problems down the road if his tile guy wraps the tile into the mouth of the fire box about 4 inches to cover the existing brick work? Its a wood burning fireplace and looks like he uses it. I need to know so i can advise him on the firring/framing out the brick made necessary by other aspects of the job.
TIA
Mark
Apex McGann is offline
Old 09-24-2008, 10:34 AM   #2
Kgmz's Avatar
Re: Tile In Mouth Of Fireplace.
http://www.contractortalk.com/f73/tile-inside-fireplace-35533/#post397986
Kgmz is online now
Old 09-25-2008, 02:04 AM   #3
Trade: Handyman
yes i read that post. thanks for point it out too. in that thread it appeared that the client wanted the entire inside tiled. my client is proposing just the return of he facial brick. which is about 4 inch. i thought the the difference was enough for a different thread. should i have posted to the other thread or is the previous poster concurring with the other thread that it's a bad idea?
Mark
Old 09-25-2008, 08:05 AM   #4
genecarp's Avatar
it will probably be fine, that 4'' return you speak of does not get intense heat, proper tile choice will be important. also a special heat resistent thinset may be available.
genecarp is offline
Old 09-25-2008, 08:15 PM   #5
Tile Contractor
Bud Cline's Avatar
The tile will take the heat within reason. The thinset will be the issue. I am not aware of any high temp thinsets but there may be some. I would gamble and use dry-set thinset. Dry-set will not have the additives that modified thinset will have and therefore no chemicals to react to the heat in my thinking. Dry-set is "unmodified" thinset.
Bud Cline is offline
Old 09-25-2008, 10:35 PM   #6
Trade: Handyman
Thanks for the feedback
Old 09-25-2008, 11:10 PM   #7
reveivl's Avatar
Trade: Renovations
I ran into this today doing research on something entirely different, but... Mapei has high temperature thin sets. Go to their site and they have some info. Certainly other manufacturers do too.
reveivl is offline
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Tile over fireplace brick Ronman39 Flooring 14 08-19-2008 02:19 PM
Tile Inside of a Fireplace ccmrehab Ceramic & Stone Tile 15 06-17-2008 08:14 PM
Tile over brick fireplace surround John Pride Ceramic & Stone Tile 7 03-04-2008 07:47 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
