Tile Installation Method
Old 08-02-2017, 07:14 AM   #1
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,557
Can anyone tell what's going on here? It looks like this backsplash is set into the drywall but that's not likely. I like the look waaaay better than using a metal edging but can't figure out what they did.
Big Johnson is online now
Old 08-02-2017, 07:43 AM   #2
tjbnwi's Avatar
Rewards Points: 1,678
Re: Tile Installation Method
My guess is they used 1/4" plywood backer on the wall, installed the tile on a membrane, cut the membrane, installed the tile "assembly".
tjbnwi is online now
Old 08-02-2017, 07:57 AM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,269
What about the joint where the mosaic meets the flush wall? It seems too "clean" to be drywall.
MarkJames is online now
Old 08-02-2017, 09:03 AM   #4
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,882
Just requires good planning. Drywall has a J bead for a finished edge. Tile backer was either notched into studs or thicker drywall or extra layer was used so everything ended up flush.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Jaws (08-24-2017), Workingmanvan (08-07-2017)
Old 08-02-2017, 09:26 AM   #5
MarkJames's Avatar
Well anyway...I wouldn't get too attached to that look. With those mosaics, it would be a pita to get "just right" with the sink.
Old 08-02-2017, 10:40 AM   #6
tjbnwi's Avatar
Tear away bead. Will give a perfect butted joint every time.
The Following 5 Users Say Thank You to tjbnwi For This Useful Post:
Dan_Watson (08-02-2017), Jaws (08-24-2017), jlhaslip (08-02-2017), MarkJames (08-02-2017), Workingmanvan (08-07-2017)
Old 08-02-2017, 07:34 PM   #7
Well the gauntlet has been thrown down so I have to do this tile install. I'll do it with some 1x2 mosaics though.
My plan: 1/4" drywall from floor to 4" above countertop, then regular 1/2", Maybe 5/8" drywall with tear away bead. I think 1/2" drywall will be fine since it will be thicker at the bead and tiny mosaics don't need much thin set.
Old 08-02-2017, 08:21 PM   #8
KAP's Avatar
Trade: Custom
Rewards Points: 24,282
Butt edge of rock or edging, painted on the bottom of the rock where it will come in contact with the grout, painters tape on edge while grouting, wipe clean, pull tape, touch-up..
KAP is offline
Old 08-02-2017, 10:23 PM   #9
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Send a message via Yahoo to charimon
I need to see more pics from different angles before I am willing to make any sort of guess
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following 2 Users Say Thank You to charimon For This Useful Post:
gbruzze1 (08-02-2017), Inner10 (08-03-2017)
Old 08-03-2017, 12:05 AM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,602
Hard to tell, could be plastic thin profile.
Inner10 is online now
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 01:14 PM
Check this Installation Method Out plazaman Tiling 49 12-09-2011 04:45 PM
