Tile On Concrete Block Wall
Old 01-06-2009, 11:46 AM   #1
Milhaus's Avatar
Trade: Renovations
Hi everyone,
Happy New Year to you all.
My plumber threw a question at me the other day that I could not answer. I have some experience with tile, but I'm no expert. He just bought a house and is planning on finishing the basement. He was wondering about tiling directly onto concrete block. With mortar joints and uneven surfaces, I didn't think it would be advised. Anyone have any advice on this? He was considering studding up a new wall on the interior, throwing durock on it, and then tiling that.
Any help is appreciated.
mark
Milhaus is offline
Old 01-06-2009, 12:05 PM   #2
Remodeling GC
kevjob's Avatar
Re: Tile On Concrete Block Wall
If he has the room I would frame insulate with unfaced and then denshield then tile. Allows you to make walls flat and square and the tiling will go a lot easier.
kevjob is offline
Old 01-06-2009, 01:12 PM   #3
Tile Contractor
Bud Cline's Avatar
I would whole-heartedly agree with that.
I have tiled many many block walls over the years and that has to be the biggest PITA there ever was. It can be done but a lot of grinding is necessary, a lot of grinding.
Bud Cline is offline
Old 01-06-2009, 01:50 PM   #4
cleveman's Avatar
Trade: custom home building
I prefer the denshield as well.
I wouldn't be afraid to lay on the block if the block was laid nicely and the joints were hopefully cut instead of struck. If it is an exterior wall, you may as well fir it out and insulate. I don't think you find many block partition walls anymore.
Which brings us to the studs and specifically the flatness of the wall. I've done this on bowed walls and it results in lippage. How to solve this? Use straight studs, put in a lot of blocking, use smaller tile, use steel studs? I'd be willing to try any and all of these.
cleveman is offline
Old 01-06-2009, 02:33 PM   #5
Remodeling GC
kevjob's Avatar
use shims to achieve flatness and plumb
kevjob is offline
Old 01-06-2009, 03:30 PM   #6
Tile Contractor
Bud Cline's Avatar
Old 01-08-2009, 08:17 AM   #7
Milhaus's Avatar
Trade: Renovations
Thanks for the input. I was leaning towards framing new walls myself. I don't know if he has the room to spare or not, or the actual condition of the walls. But, I can only imagine the PITA it could be.
mark
Milhaus is offline
Old 01-08-2009, 09:02 AM   #8
Pompass Ass
bwalley's Avatar
Originally Posted by Milhaus View Post
Hi everyone,
mark
Are the concrete walls currently painted or have any other finish on them?
You can mudset the walls using No-sag thinset, if the walls were previously painted they will have to be stripped and a bonding agent added to the thinset.
You can get the tile perfectly plumb with no "lippage" this way.
bwalley is offline
Old 01-08-2009, 11:30 AM   #9
BirmanBuilders's Avatar
Trade: Framing
Framing a wall would be easiest but if theres no room could he plaster the wall instead to get a flat surface then tile?
If at first you don't succeed hit it harder!
BirmanBuilders is offline
Old 01-08-2009, 12:46 PM   #10
Tile Contractor
Bud Cline's Avatar
Old 01-18-2009, 07:07 AM   #11
tile mason
MattCoops's Avatar
You could always install a moisture barrier, fasten lath with masonry screws, and screed a portland mix.
MattCoops is offline
Concrete Block Wall skpjose Construction 26 10-20-2008 04:38 AM
Concrete block usage gladiatorxx Masonry 11 10-03-2008 11:01 PM
How to cap off 8" concrete block wall Michaeljp86 General Discussion 18 09-20-2008 08:18 AM
leaking block wall BuilderDave Construction 8 01-09-2007 11:09 PM
Tile wall anchors smellslike$tome Ceramic & Stone Tile 18 10-03-2006 06:20 PM
