TEC AccuColor Epoxy Special Effects Grout
Old 04-13-2008, 08:14 PM   #1
cleveman's Avatar
Trade: custom home building
I had a fair amount of epoxy grouting to do and after pricing several types of grout, I settled upon the above. I had to buy 2 gallon kits as a minimum order.
After wasting portions of the first few batches, I finally put on my thinking cap and got some exact measurements down:
Part A weighs 1190 grams net (without the bucket)
Part B 3670 g
Sand 11.25
So I mix in 1/8 batches:
A: 149 g
B: 459 g
Sand: 1.41 KG
I have a digital baking scale and I can get down to about 5 grams difference. The reason I went with weights instead of volumes is because part B is the consistency of gravy and it was difficult to measure it out by volume.
They don't recommend mixing less than full batches, but I haven't had any troubles yet.
I also found that if I scrape most of the stuff off and get back to it quickly (which the 1/8 batches allow me to do), then I can do the cleanup with a sponge and not have to use the doodle pad. The texture is bit glossy then, but I don't mind it.
This is a very simple method, I realize, but it really helps. The shelf life of the product is about 2 years.
cleveman is offline
Old 04-13-2008, 08:24 PM   #2
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Re: TEC AccuColor Epoxy Special Effects Grout
A long time ago, one of the chemists from Construction Adhesives Company in Patterson New Jersey told me that with ANY epoxy, so long as you add in atleast a LITTLE bit of the catylist and mix it well, it'll harden up. It might take a bit longer, but it'll still harden. Conversely, if you add too much catylist, it'll flash set. But of course, you'll know about that pretty quickly.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Grout Filling Cells younguy22 Masonry 4 01-22-2008 10:21 AM
Need help on grout Red Ceramic & Stone Tile 10 01-15-2008 08:42 PM
Tile grout color too light fsbr Flooring 18 11-29-2007 06:05 AM
Grout width query. Nick S. Ceramic & Stone Tile 18 10-12-2006 10:22 PM
best way to seal grout for glass mosaics. ApgarNJ Masonry 2 06-27-2006 06:18 AM
