Substrate Around Stand Alone Tub ?
Old 02-08-2018, 09:52 AM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,992
Bathroom reno. Shower 42x48 Kerdi - board (most likely) or Kerdi Membrane over DW. Kerdi pan also.
Floor to ceiling glass on shower curb --- then pedestal / stand alone tub next to shower area.
I'm up in the air about substrate for the 2 walls around the tub ? Walls around the tub subway tile ~ 48" - 60" hgt.
Not sure what is best way to go -- WR - DW with Red Guard, Cement backer board or Kerdi Membrane over DW ? The shower and tub share a 9.5 ft wall so need to have a good transition of materials.
Appreciate your input so I can quiet the committee in my head on this ?
Floor will be Ditra with Kerdi band around the perimeter.
Steve
We Fix Houses is offline
Old 02-08-2018, 12:27 PM   #2
tjbnwi's Avatar
Rewards Points: 3,634
Re: Substrate Around Stand Alone Tub ?
4-1/2” of Kerdi Board.
Stack two 2” pieces, back with 1/2”. Cut the niche spaces in the 2” before installing the 1/2” piece.
tjbnwi is offline
Old 02-08-2018, 12:39 PM   #3
Tom, maybe re-read....about wall substrate around stand alone tub beyond shower area.
Thanks a lot.
Steve
Old 02-08-2018, 01:54 PM   #4
RichVT's Avatar
Rewards Points: 637
Only reason not to use Kerdi Board would be the cost.
RichVT is offline
The Following User Says Thank You to RichVT For This Useful Post:
We Fix Houses (02-08-2018)
Old 02-08-2018, 07:08 PM   #5
tjbnwi's Avatar
Thanks a lot.
Got it now...
Kerdi board, easy to install, waterproof, one step install.
tjbnwi is offline
Old 02-08-2018, 07:20 PM   #6
I may do that as it would span the new framing completely.
I'll say the vanity /shower control wall 9 ft and the perp wall 9 ft - I built out with 1 5/8 metal stud for a true surface. Was plaster with too much variance with the studs.
Steve
Old 02-08-2018, 07:51 PM   #7
tjbnwi's Avatar
They make 10' Kerdi board. At the tub I'd lay it on its side, this will get you to the 4'.
tjbnwi is offline
Old 02-08-2018, 08:01 PM   #8
Tom, got a question ---
The height of the walls are 8 ft - 8 inches.
The pic is the shower 42 w x 48 long (see the supply risers) --to the right will be the stand alone tub.
I can stand up the shower....lay down the tub area to 48 hgt.
I'm thinking WR - DW above the Kerdi...put an 8" horiz fill piece DW above the Kerdi or where, up by the ceiling ??
I need to call Dal-Tile about the 10 ft.
Steve
Old 02-08-2018, 08:12 PM   #9
tjbnwi's Avatar
Any drywall above the tub will be fine. I believe you only need to be 1' above the tub for it to be considered waterproofed. I believe it is also only 1' above the shower head also.
This shower is 10', Kerdi board to the ceiling (tile also goes to the ceiling).
Substrate Around Stand Alone Tub ?-img_3837.jpg   Substrate Around Stand Alone Tub ?-img_3135.jpg
tjbnwi is offline
Old 02-08-2018, 08:19 PM   #10
Ok I think I'll go with that. Thanks
Steve
Old 02-13-2018, 10:10 PM   #11
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,808
Or the fact that it's not in a wet area and there is no need for it.
Then there is the tape and overlap at the seams. I ca't stand Kerdi Board or Kerdi Membrane. Too many steps and too much overlap.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 02-13-2018, 10:14 PM   #12
Hair Splitter
Trade: General
Originally Posted by tjbnwi View Post
Got it now...
One step?
Hang board
Mix Thinset
Install band on seams and over screws
Wedi is one step and no mess of mixing thinset.
Old 02-13-2018, 10:30 PM   #13
tjbnwi's Avatar
Originally Posted by TNTSERVICES View Post
One step?
Hang board
Mix Thinset
Novel concept, mixing mortar when setting tile...
You not have to apply the sealant to the Wedi joints or cover the screws with the sealant anymore? (Serious question, haven't used Wedi in about 2 years) I hate working with the sealant.
I've used both, give me Kerdi board any day.
tjbnwi is offline
Old 02-13-2018, 11:09 PM   #14
Hair Splitter
Trade: General
I don't know of any setter who sets tile the same day they install the Kerdi. So it's an extra step. During an bathroom remodel we will set the shower and floor (Kerdi pan on the shower, DensSheild walls and Ditra floors) and then have some other trades come in and finish drywall and prime the walls.
And yes you still have to use sealant on the seams and screws, but it's all the same step and there are no strips to cut or screws to cover with fabric. You apply the sealant to the seams and screws as you install. No extra step of mixing anything or have to clean up a thinset mess. No buckets to clean. Just two products, the board and the sealant.
Laminate substrate for commercial use SavannahReno Kitchens & Baths 2 03-14-2016 07:04 PM
which substrate for shower wall? AustinDB Tiling 33 05-02-2014 04:34 PM
suitable substrate for vinyl sheetgoods AustinDB Flooring 3 01-26-2012 10:12 AM
Substrate for wall tile. theflynner Tiling 7 08-01-2011 11:50 PM
Vertical granite slab substrate hirayama Tiling 0 02-02-2009 02:37 AM
