Stubborn Grout Haze - Tiling - Contractor Talk
Stubborn Grout Haze
Old 08-15-2018, 05:21 PM   #1
AustinDB's Avatar
Rewards Points: 876
Stubborn Grout Haze
HO chose a ceramic floor tile against my recommendation. Itís a cheap tile and chipped easily.
Grouted with Mapei Flexcolor CQ and in an air conditioned space and a clean rinse... so the dirty water didnít dry on due to the heat.
Hard to tell in the pictures, but there are spots here and there that arenít coming up easily with a traditional urethane grout haze remover. The Nanoscrub does work with a tile scrub brush but not with a 3x8 white scrub pad. Lot of extra work!
Any recommendations on how to get this up more quickly? First pass with the scrub brush gets 90% and second pass to clean it up.
Final question, have you run across ceramics that are troublesome to clean or is this my fault?
AustinDB is offline
Old 08-15-2018, 06:58 PM   #2
tjbnwi's Avatar
Rewards Points: 5,402
Re: Stubborn Grout Haze
Probably your wash technique got you.
CQ you need to change the water often and grout small areas.
Keep working at it you’ll get it cleaned up. Try a citrus cleaner.
tjbnwi is online now
Old 08-15-2018, 07:01 PM   #3
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,284
Magic eraser. Aka, melamine sponge.
Big Johnson is offline
Peter_C (08-15-2018)
Old 08-15-2018, 07:05 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,348
That tile looks prone to having grout and thinset stick to it.
I typically use vinegar with warm water. There are lots of concoctions I have heard of though.
Are you using one of these pads? That is what I have had good success with, but sometimes it takes some serious scrubbing, and sweating.
Peter_C is online now
The Following User Says Thank You to Peter_C For This Useful Post:
AustinDB (08-15-2018)
Old 08-15-2018, 07:05 PM   #5
tjbnwi's Avatar
Test the magic eraser, I’ve seen them change surface sheen.
Old 08-15-2018, 08:39 PM   #6
rblakes1's Avatar
Rewards Points: 2,016
You forgot cursing. There will be lots of cursing
rblakes1 is offline
The Following 3 Users Say Thank You to rblakes1 For This Useful Post:
B.D.R. (09-19-2018), Bull Trout (08-15-2018), Robie (08-16-2018)
Old 08-15-2018, 09:05 PM   #7
AustinDB's Avatar
Rewards Points: 876
that's the exact scrubber I have. just picked it up at Dal Tile.
AustinDB is offline
Old 08-15-2018, 09:22 PM   #8
Bull Trout's Avatar
Rewards Points: 66
I bet the "stuff" in the bottom drawer of your toolbox will cut through a good haze
Bull Trout is offline
The Following User Says Thank You to Bull Trout For This Useful Post:
Old 08-15-2018, 10:26 PM   #9
AustinDB's Avatar
Rewards Points: 876
good one
AustinDB is offline
Old 08-15-2018, 11:56 PM   #10
Peter_C's Avatar
Scrub harder, flip it often, and replace the scuffy pad as needed
Old 08-16-2018, 07:20 AM   #11
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,860
CQ is a bitch to get the tiles clean. You gotta wash the hell out of it to remove the haze before it sets. If it sets the best thing I found was a scotch brite pad or a turtle back sponge and scrub the bastard.
Inner10 is online now
Old 08-16-2018, 07:29 AM   #12
Radical Basement Dweller
Robie's Avatar
Rewards Points: 6,390
I have a friend who does a lot of tiling.
He wipes a thin coat of haze remover on the top surface of his tiles before putting them down. Says it saves a lot of clean-up time.
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is offline
sparehair (09-20-2018)
Old 08-16-2018, 11:53 AM   #13
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 667
Did you set that tile? First pic, grout line on the left looks off.
Sometimes with less expensive tile, the sizes vary, and you have no choice. Split the difference.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
BlueRidgeGreen (09-21-2018)
Old 08-16-2018, 12:59 PM   #14
AustinDB's Avatar
Rewards Points: 876
I figured out a system that works, hope it helps others.
Aqua Mix NanoScrub with a splash of water. Working a few tiles at a time.
4Ē polisher on lowest speed (1000 rpm) with a green scotch pad cut to fit. Used a utility knife to cut it out.
The water is to keep the slurry wet so the scotch pad can do its job. Itís like auto body work, if the compound gets too hot from application, it stops working.
After application, lots of clean towels. Dirty towel gets the first pass then a cleaner towel to finish up.
Tried five other processes before finding this one, which gets most of the haze off.
AustinDB is offline
The Following 3 Users Say Thank You to AustinDB For This Useful Post:
B.D.R. (09-19-2018), sparehair (09-20-2018), Tinstaafl (08-16-2018)
Old 08-16-2018, 04:33 PM   #15
Peter_C's Avatar
Next time don't leave the job until the haze is gone. Less work in the end. Micro-fiber cloths are great for performing the final cleaning before walking away too. I just buy the packs at Costco. Sometimes washing them, most of the time they are done for.
Glad to hear it came clean
The Following 2 Users Say Thank You to Peter_C For This Useful Post:
MarkJames (08-16-2018), TNTSERVICES (09-19-2018)
Old 08-16-2018, 08:17 PM   #16
rrk's Avatar
Rewards Points: 3,092
this works also
https://www.amazon.com/Aqua-Mix-Sulf...ustomerReviews
rrk is offline
Old 09-19-2018, 12:46 AM   #17
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,910
Originally Posted by rrk View Post
Does it work on the urethane grout ?
B.D.R. is offline
Old 09-19-2018, 07:54 AM   #18
Frenchy93's Avatar
Trade: Earthworks
Rewards Points: 154
I don't want to insult your work.. But are they not more worried about the tile joints that don't even come close to lining up?
Frenchy93 is offline
Old 09-19-2018, 08:42 AM   #19
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
A glass cleaner with ammonia works on urethane.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
Old 09-19-2018, 09:56 AM   #20
B.D.R.'s Avatar
That is good to know.
But,I wouldnít think that the sulphamic acid would work on it.
B.D.R. is offline
Urethane grout haze. HELP!!! Stevarino Tiling 8 08-11-2015 01:46 PM
Removing Grout Haze Brian2014 Remodeling 18 02-16-2014 11:14 AM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Haze on tile with urethane grout cleveman Tiling 9 07-20-2012 08:07 PM
Quartz Lock Urethane Haze Issues nhill2090 Tiling 6 01-17-2011 01:11 PM
