StarQuartz QuartzLock 2 Review
Old 02-16-2012, 09:32 AM   #81
Aaron Tritt's Avatar
Trade: Tile Installation
Rewards Points: 150
Re: StarQuartz QuartzLock 2 Review
Laying a piece of plastic (celephane or something) down over the top of the lefover in a bucket will keep it good longer.
If you have a large air volume in the bucket, the top layer gets a little crunchy. I found out the hard way that if this happens, you need to get a new bucket.
Aaron Tritt
Custom Expressions LLC
Insured, NTCA Member, BBB accredited
Aaron Tritt is offline
Old 02-16-2012, 09:34 AM   #82
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
Originally Posted by JohnFRWhipple View Post
To save $60-$90 I would not have a warm fuzzy feeling inside. I would get fresh product that way if you have any problems you have a receipt in hand.
John-
I have always used BOSTIKS TruColor Urethane. it is what my go to supplier carries. Its can be used on glass. It has a shelf life of two years once sealed. It can even be frozen, brought back into room temperature for a day and re-used. I have never had a problem with color variation. Not sure if you can get this up your way, but I pay about $60.00 for a small 9lb tub and about $110 for an 18lb tub here in the states. Give it a try if you can and maybe put it through one of those Whipple tests of yours
Brian
ROVACON is offline
Old 02-16-2012, 11:00 AM   #83
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
TruColor is the exact same thing as QuartzLock 2.
Angus
angus242 is offline
Old 02-16-2012, 11:02 AM   #84
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I have used buckets that I have stored for over a year and aside from a different consistency (because of more or less urethane than originally contained), I had no problems with it.
Very important to properly seal the lid when done using (for shelf life). You will actually feel the lid "snap" when it's closed.
Angus
angus242 is offline
Old 02-16-2012, 12:03 PM   #85
Holy Crap!
ROVACON's Avatar
Rewards Points: 296
Angus-
I thought you had to buy "starQuartz" for glass? I know the two are nearly identical. Just wasn't sure about the Quartzlock being safe on glass as they seem to have an alternative product. Thanks!
Brian
ROVACON is offline
Old 02-16-2012, 12:15 PM   #86
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
StarQuartz is the parent company.
QuartzLock 2 is their standard urethane grout. It's made with quartz aggregate and can scratch polished stone or glass.
TruColor is the exact same thing as QL2, made by StarQuartz for Bostik.
StarGlass is a urethane grout with glass aggregate and is designed to be safely used on polished tile and glass.
Dimension is the exact same thing as StarGlass, made by StarQuartz for Bostik.
Did I confuse anyone
Oh yeah, Bostik owns StarQuartz
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
ROVACON (02-16-2012)
Old 02-16-2012, 12:22 PM   #87
Holy Crap!
ROVACON's Avatar
Rewards Points: 296
I understand "colonel"
Now I have not seen nor requested Dimension for grouting glass. I have always used the standard TruColor for that with out issues. I wonder why the standard directions for TruColor say it is safe on glass if they clearly make another product? Very interesting.....
Brian
ROVACON is offline
Old 02-16-2012, 12:29 PM   #88
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
It's all about the aggregate. Quartz can scratch glass. The glass aggregate is round beads so much less of a chance of scratching.
When I'm using either over a high gloss surface, I use a soft polyproxylene float instead of the typical epoxy float. That helps too.
Angus
angus242 is offline
Old 02-16-2012, 12:50 PM   #89
Bathroom Remodeler
srwcontracting's Avatar
Trade: Bathroom Remodeling
Rewards Points: 560
Thanks guys.....but since John put doubt in my mind..... So I just ordered some new stuff
Even though.....it's probably going to be that old anyways.....being in there warehouse.
The seran wrap is a good idea
I'll probably just use that bucket on a floor somewhere other than a shower
srwcontracting is offline
Old 02-16-2012, 01:14 PM   #90
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,292
Just popped my cherry with some Trucolor by Bostik today.
Very fast install, easy to clean and not a bit of waste. Think I paid 55 bucks for the 9 pound pail.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 02-16-2012, 06:01 PM   #91
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
I never buy the small tubs. I took Aaron's advice and just put some plastic wrap over the remainder when I am done. I currently have 80% of the colors in stock. If its a larger floor and I need more than half a bucket, I mix the two together since the buckets never seem to be more than half full anyway.
Josh
hhicontracting.com
HandyHails is offline
Tags
chicago , elite tiling , naperville , plainfield , quartzlock
Spider Lath, my review. sitdwnandhngon Masonry 14 06-06-2015 07:10 PM
Spectrloc vs Quartzlock II wannaBelkhuntin Tiling 10 01-19-2011 10:57 AM
Mini Review of the Cadex 18.50 18g nailer jhark123 Tools & Equipment 11 10-29-2010 07:28 PM
Vehicle Graphics for review. LNG24 Vehicles 85 12-04-2009 12:45 AM
Mitertite Casing Assembly System Review basswood Finish Carpentry 3 11-21-2009 10:36 AM
