Speed Set In White?
Old 05-17-2008, 12:00 AM   #1
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Speed Set In White?
I just set about 100 sq ft of 24''x24'' travertine tile in a bathroom and now the H.O wants me to tile around the jacuzzi tub with the same tile. It's not much, only about 20 sq ft. The question I have: is there a white speed set so I can get this job done a day sooner? I checked the big boxes and no luck, just wanted to stop here first before I run around town to all the tile stores. Thanks.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 05-17-2008, 12:39 AM   #2
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Re: Speed Set In White?
All types of thinset are made in both gray and white. Just check around your area. The last Speedset I used was Tec in white.
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 05-18-2008, 12:03 AM   #3
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Make your own. Baking Soda is a neat thing, play with the mix until you find a ratio that sets to your liking
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 05-18-2008, 01:56 PM   #4
tile mason
MattCoops's Avatar
Custom makes white SpeedSet.
We get ours from local Dal Tile.
MattCoops is offline
Old 05-18-2008, 03:54 PM   #5
user15686's Avatar
You can get Henry 316 two hour mud at Lowe's. It is white.
user15686 is offline
Old 05-18-2008, 09:57 PM   #6
Sharp Improvements
Great answers. I will look into the possibilities. Thanks.
Norman Sharp
Old 05-18-2008, 10:37 PM   #7
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
NO NO NO NO NO!!!! I just went to an NTCA workshop about two weeks ago, and this specific subject came up. I've done the same thi9ng with sandmix to patch floors over a bonding agent, and that's not a problem. But with thinset, the baking soda will destroy the bonding strength of the thinset. DO NOT do this!
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 05-18-2008, 11:37 PM   #8
Good to know, thanks Bill. I have only used it on a few occasions when I didn't have any speedset on hand and it seemed to work very well. I thought about the bonding issue and pulled some tiles just to see what the outcome would be.....stuck like a mofo they was.
What about masonry additives specifically for that purpose?
Precision Flooring
(772) 237-9900
Old 05-19-2008, 06:58 AM   #9
tile contractor
The industry line is that thinsets should not be "home modified" in any way, due to the fact that unless you know what polymers are in the particular thinset you're using, and in what proportions, you don't know what kind of reaction may occur between them and whatever you add to that thinset.
