Small Tile In Shower
Old 03-08-2011, 05:00 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Question
doing a shower with little 2x2 octagon tile and man is it a pain in the boote'. i've been useing a 1/4 1/4 square notch and got some thinset coming through the cracks. is a 1/4 1/4 what you would use or should i swap over to a v notch?
bluebird5 is offline
Old 03-08-2011, 05:09 PM   #2
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
Re: Small Tile In Shower
I use a 1/4 x 1/4 notch mix my thinset a little loose. Set the tile and smack it with a float. Then take a old paint brush dipped in water and wash out the joints. THAT A GREAT TIP...ANY more and ya have to fill up my gas tank
opiethetileman is offline
Old 03-08-2011, 05:17 PM   #3
bluebird5's Avatar
Rewards Points: 694
I like the painbrush idea. Is that a common thing that all tile guys know or is that a Dan trick of the trade?
Old 03-08-2011, 05:20 PM   #4
its a top secret tile trick man. I use a paint brush on just about all my tile now. Wash the joints down the day you are installing and almost never do you have to cut out thinset the next day. i have alot of good tips up in the crazy head of mine.
Old 03-08-2011, 05:24 PM   #5
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
1/4x1/4 seems very big for 2x2 tiles. you could get away with a smaller one. maybe 3/16 V notch. If it starts to squeeze out the joints, I know I'm using too big of a trowel.
ApgarNJ is offline
Old 03-08-2011, 05:26 PM   #6
on a shower floor the more coverage the better. I also forgot to say i use a worn 1/4x1/4 trowel. I have torn out many and many shower floors with 3/16 v notch with no bond. I would rather be safe than sorry
The Following User Says Thank You to opiethetileman For This Useful Post:
tazmanian (03-08-2011)
Old 03-08-2011, 05:33 PM   #7
Dan
ApgarNJ's Avatar
could get away with it for walls in a shower though. i always pull back the tiles and check. the last thing I need is to worry about pushing some tiles in more than others and you don't get a perfectly flat surface.
ApgarNJ is offline
Old 03-08-2011, 05:46 PM   #8
are you wet setting your tile into fresh mud??? I set my tile on the mud floor after it has dried for at least a day. i also tap them down with a float or a small level. just giving a tip of trade amigo
Old 03-08-2011, 05:51 PM   #9
Dan
ApgarNJ's Avatar
i'm not talking about a new mud base. i'm talking about putting 2x2 tiles on a shower wall. i don't think he stated that this was a shower base only.
but to answer your question, i don't tile onto a fresh thick mud bed. i let that part set up. and come back the next day to tile to that with thinset.
the mud base is mortar. last several jobs though were tub surrounds or shower bases, fiberglass.
ApgarNJ is offline
Old 03-08-2011, 05:55 PM   #10
well on wall i have another trick to keep matte sheets flat. make a wooden hawk basiclly. if the sheet is 12 x 12 make it 14 x 14 out of plywood with a small handle. Spread thinset and then take the sheet and flop in on the plywoood and press onto the wall. It works and gets good coverage very good coverage. then brush out the joints and smile
ok that is TIP TWO...........gas is getting cheap
ApgarNJ (03-08-2011)
Old 03-08-2011, 07:01 PM   #11
Dan
ApgarNJ's Avatar
i just normally smooth those 12x12 mats out with my hand and then make sure they are all spaced and positioned perfectly. unless it's an tile that's not meant to have perfect grout lines.
ApgarNJ is offline
Old 03-10-2011, 10:51 PM   #12
bazemk1979's Avatar
Trade: pro
Rewards Points: 77
1/4x1/4 on a 2x2 sheet tile....
Dude V-notch 1/8x1/8 is the way to go with this size of tile.
bazemk1979 is offline
Tub tile backing KennMacMoragh Kitchens & Baths 10 05-12-2010 01:28 PM
Tile over existing shower surface SK Builders Tiling 16 07-06-2009 12:42 AM
Tiled shower leaks...Could use any advise at all... Jay22 Tiling 17 12-10-2008 06:15 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 07:01 PM
How to tile a shower floor??? CALKAM Carpentry 6 03-19-2007 07:23 PM
