Shower Wall Tile Options - Tiling - Contractor Talk
Old 08-19-2018, 08:54 PM   #1
Ampridehomes's Avatar
Trade: Multi trade
Hi guys...its been many years since I tiled a shower, i normally stick to backsplashes and such, but I got roped into one. Pan is cast iron and all done. I just need to do the walls. I know times have changed from just slapping up durarock and setting.
Ive yet to take the kerdi plunge. But what is the most universally accepted method right now?
Durarock and red guard? Hari and redguard? Hardi and kerdi? How about Schlutters foam board??
What do you do in the corners if we decide to just do hardi and redguard?
Thanks in advance!
Ampridehomes is offline
Old 08-19-2018, 09:32 PM   #2
avenge's Avatar
Rewards Points: 3,218
Re: Shower Wall Tile Options
I prefer Wedi or GoBoard quit using Hardi and Durock some time ago they both suck. I'm not a Kerdi fan either.
Since you're asking about corners what did you do in the past?
avenge is offline
Old 08-19-2018, 09:41 PM   #3
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,222
If you are comfortable with RG over CB do what you know. Mesh the corners before RG. If you want to branch out and have GoBoard or equivalent available in your area give it a try. Waaaay easier to cut and install. Definitely need to do some reading on how to seal the joints and fasteners.
overanalyze is offline
Old 08-19-2018, 09:49 PM   #4
Trade: Multi trade
When i first started we used quad in the corners then redguard. That wa 15 years ago though. Havent really been into doing them since. Lots of risk and i make money doing all kinds of other things so...not my favorite. But I am a high quality guy and I love the new systems. High tech for sure.
Want to use them, but dont want to have a customers home be my Guinea Pig either.
Old 08-19-2018, 09:50 PM   #5
Trade: Multi trade
Never heard of go board. Looked it up and definitely never seen it around here. Is it equivalent to kedi board?
Old 08-19-2018, 09:52 PM   #6
Trade: Multi trade
As far as CBSeems like i alwas see durarock vs hardi too. Is there a reason? Durarock sucks in my opinion vs Hardi.
Old 08-19-2018, 11:01 PM   #7
rblakes1's Avatar
Rewards Points: 2,016
Kerdi board is so easy to use. You can carry up all your sheets at once in one hand, cuts super easy, installs fast, even adds R2 to your exterior walls. I don't use anything else on tub and shower walls
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Anderson (08-22-2018)
Old 08-22-2018, 09:06 AM   #8
AustinDB's Avatar
Rewards Points: 876
I was using a mesh tape in the corners with Redgaurd. Hydroban is similar, they have a seam tape to use in the corners/seams. Itís more like a fiberous tape, not sure how to best describe.
Iím all about the Kerdi-Board because itís light, easy to work with and gives a great bond with the tile (thinset).
AustinDB is online now
Old 09-19-2018, 12:33 AM   #9
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,910
My only complaint about Kerdi is I feel it needs extra backing.
B.D.R. is offline
Old 09-19-2018, 08:46 AM   #10
Frenchy93's Avatar
Trade: Earthworks
Rewards Points: 150
Waterproof Membrane Paint used for foundations right over drywall. Best you can get!
Frenchy93 is online now
Old 09-19-2018, 04:39 PM   #11
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,626
Iím not a tile guy , but tiling over drywall in a shower doesnít seem like a good idea
Idothat is online now
Old 09-19-2018, 05:50 PM   #12
avenge's Avatar
Don't think so.
avenge is offline
Old 09-19-2018, 07:33 PM   #13
PC&R's Avatar
Rewards Points: 122
I'm a big fan of Kerdi.
I use mold resistant drywall for the entire bathroom, then Kerdi in the shower area and Ditra on the floor.
Make sure you waterproof the pan to the floor tile on the outside of the shower.
PC&R is offline
The Following 2 Users Say Thank You to PC&R For This Useful Post:
rblakes1 (09-19-2018), TNTSERVICES (09-19-2018)
Old 09-19-2018, 08:11 PM   #14
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
This has to be a joke. Exterior membranes should NOT be used on the interior. They are typically petroleum or solvent based. How about you let us professionals give the tiling advice and you stick to playing in the dirt.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 09-19-2018, 08:19 PM   #15
Hair Splitter
Trade: General
Rewards Points: 214
Here's my advice:
Cement board
1) Shim studs to plumb
2) Square walls by sistering studs as needed
3) Install cement board using cement board screws every 8-10"
4) Use FibaFuse fiberglass tape over seams and in corners. You install using your favorite topical waterproofing product (I have always been partial to Mapei Aqua Defense.
5) At least 3 coats on all seams and screws and 2 in the field. You want to use a mil thickness gauge in order to meet the manufactures recommend mil thickness to achieve waterproofing and crack isolation.
6) Allow to dry and start tiling using a modified thinset. (ARDEX for the win, X5 or 77)
Kerdi board
1) Open window
2) Throw in dumpster
Too much of a mess to install. Foam chit flying everywhere. A pain in the ass to cut. (easier than cement board, but still a pita). Then you have to mix thinset and and install kerdi band on all the corners, seams and screws. So you now have build up in all of those places. Kills me that they won't let you use Kerdi Fix in these areas.
Plus it's too dang expensive. I know, I know, we pass it on to the customer and you save in labor, yada yada...still too expensive for what you get.
Wedi
If I was to use a board this would be it. Super easy to install, not as expensive as Schulter and no build up and BS fabric. Cut, Wedi Sealant on the seams, corners and screws and you are installed.
My method
1) Denshield instead of Cement board
2) Waterproof like I would Cement board
Start tiling
The Following 3 Users Say Thank You to TNTSERVICES For This Useful Post:
BlueRidgeGreen (09-20-2018), Idothat (09-19-2018), mstrat (09-19-2018)
Old 09-22-2018, 07:22 PM   #16
B.D.R.'s Avatar
Iíve always been a fan of dense shield.
But it has been getting more expensive, and Iím sure itís now twenty pounds heavier since I turned 60.
I donít like the time involved to tape all the damn screw holes. In the Kerdi.
B.D.R. is offline
The Following User Says Thank You to B.D.R. For This Useful Post:
TNTSERVICES (09-23-2018)
Plastic Shower wall materials Randyj_302 Remodeling 25 02-03-2018 08:18 PM
Need advise on tile shower install dnkb Remodeling 17 07-29-2014 07:21 PM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Tile shower floor or wall first? Fachovec Tiling 3 02-11-2011 11:43 PM
