#21 |
tile contractor
Re: Shower Drain
You'd be shocked at what I'm capable of.
![]() Besides, the person that gave me those codes is on the ANSI board, and my info was that those codes were for all 50 states.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
#22 | |
tile contractor
Re: Shower DrainQuote:
#23 |
The Grand Wazoo
Re: Shower Drain
Some of us still remember that the name plumber comes from a latin term meaning "worker with lead", we still use lead to pour CI joints here too.
#24 |
tile contractor
Re: Shower Drain
Well, I guess I just learnt something new!!
#25 | |
Trade: Tile installations
And I treat all the jobs I do as high end, whether the home cost 200gs or 18mill, they get the same service, you wouldn't do less of a job just because the home is worse less, would you?
#26 |
Tile Contractor
Re: Shower Drain
.....and how are the seams in the copper pan welded? Remember? Lead!!!
Well it used to be lead but that has all changed now. The point is...the joints are susceptible to corrosion and erosion from the cement as far as I know.
#27 |
Trade: Remodeling contractor
Re: Shower Drain
Exactly, and the MA plumbing code says the pan is to be fabricated from non-corrosive material. Now he could have put some kind of barrier between the copper pan and the Cement floor, BUT HE DIDN'T.. He says he's been doing this for 10 years now..
Complete Custom Remodeling "When Quality is Top Priority" www.completecustomremodeling.com |
#28 |
tile contractor
Re: Shower Drain
Not for nothin, but copper's not exactly non-corrosive, either.
#29 |
Re: Shower Drain
the lip on that bottom portion of the drain is a good 1/8" thick. So the water isn't going into the drain until it's higher than that.
#30 |
Re: Shower Drain
Hard to see from here, but there should be weep holes in the bottom part of that drain to let water in at pan level.
#31 |
Re: Shower Drain
If you look in the photo of this drain, you'll see weep hole slots at the bottom of the clamping ring.
#32 | |
#33 |
Re: Shower Drain
So should water normally be reaching the pan? Or is it a failsafe put in place just in case it does?
#34 |
Remodeling GC
Re: Shower Drain
with a dypack mortar bed water will reach the pan eventually, this is the reason behind the pre slope. the kerdi system is better because the membrane is on top if the pan not sandwiched in.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
#35 |
tile mason
Re: Shower Drain
Never mind.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
#36 |
Trade: Mudset Marble, Tile, Flooring Professional
Re: Shower Drain
Did they do a water test on the pan???I always make sure they do one before they leave because it's so hard to get plumbers back after they hack everything up and leave. not having the weepholes is the biggest probelm here. Depending on how the the pan slopes away you shouold be able to correct it with the mud you pitch in the pan. I have had a similar situation when the pan sloped away, and it also was not formed correctly at all, the corners were not even close to sitting flush to the subfloor, but a little persuasion with a mallet and I got it to work, then extended the drain as much as I felt safe with, and proceeded to pitch the pan, I first did a perimiter pitch line all the way arounf the pan in attempt to really pound the mud into the corners with the tamper, and then began skreeding from there and it worked out just fine.
| What are they doing using my pictures and linking to my site? | Mark Daniels | Technology | 19 | 08-04-2011 07:39 PM |
| is the underground pipe layout correct? | stoneweed1 | Plumbing | 26 | 02-02-2008 05:14 PM |
| odd find for drain pipe | 72chevy4x4 | Plumbing | 9 | 11-06-2007 10:48 PM |
| Questions on Tiled Shower | ksensen | Remodeling | 10 | 09-10-2007 09:54 AM |
| Tub install and drain in slab | Mpeters | Plumbing | 2 | 03-04-2007 05:43 PM |
