Setting Prehung Doors/Tile Sequence
Old 05-29-2017, 09:48 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 974
I've set tile in baths, and set pre-hung doors, though not in bath areas.
Knocking my head for SOP -- in the past I have tiled "up to the jamb". It doesn't help that the mind is going!. And may have gone beneath at certain times...
I do want to avoid "notching" the base of the jamb, given different floor height transitions like for wood-to-vinyl.
But doing our own bath right now, having (2) doors; one on the inner tiled closet and the other, the entry, having inner tile & outer carpet.
When should door jambs be set on both these spots?
artinall is offline
Old 05-29-2017, 02:05 PM   #2
avenge's Avatar
Rewards Points: 2,610
Re: Setting Prehung Doors/Tile Sequence
You're supposed to undercut the jambs for tile, as a remodeling contractor you should know that. I don't know what you mean by "notching".
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
TNTSERVICES (05-29-2017)
Old 05-29-2017, 05:53 PM   #3
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 406
I think he's referring to splitting flooring of different materials/heights under the door slab so one side of the jamb is cut to one length and the other is cut to a different length. It ends up being a notch.
Xtrememtnbiker is online now
Old 05-29-2017, 06:41 PM   #4
artinall's Avatar
Rewards Points: 974
That's it.
That'd be the advantage of keeping both (inner/outer jambs) lower at the same height.
It's a given that the installed jamb could be cut, but probably not cleanly if it's half the jamb.
With one side tile, the other side carpet, the carpet side can still end up being lower so if the jamb is undercut the gap would show on the carpet side. I see tile carried up to the wood of jamb all the time - that doesn't mean it is right.
artinall is offline
Old 05-29-2017, 06:55 PM   #5
avenge's Avatar
Both carpet and tile go under the jamb and casing. If it has to cut at different heights so be it I do all the time cut cleanly. I install the doors before the flooring and space it above the subfloor.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
Jaws (05-30-2017), TNTSERVICES (05-29-2017)
Setting Prehung Doors-Clearance for Carpet? Spencer Flooring 37 08-04-2013 04:03 PM
exterior prehung door replace - uneven floor artinall Windows, Siding and Doors 19 12-24-2012 11:38 AM
Ideas on for setting cap Captainsls Masonry 15 05-10-2012 10:43 PM
Setting large granite slabs mant Masonry 18 05-08-2012 06:12 PM
Setting a standard. Taping sequence, tools, materials HawaiiBuilder Drywall 0 01-18-2009 02:36 PM
