Self Leveling On Ply Floor
Old 08-14-2008, 09:54 PM   #1
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Question
OK,
I am in a situation where I am scratching the noggen. I have an old house with a dip in the subfloor. It is in an area of about 1/2 sheet of plywood. The h.o. does not want to tear up the entire floor to rectify the problem. I am hesitant to tile on this floor for future problems. I am planning on using ditra and a modified thinset for flex. I would like to know if there is something that will level this dip and hold up over time. I am a bit concerned.
Suggestions? run? jog? skip to my lou?
Thanks
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 08-14-2008, 11:32 PM   #2
genecarp's Avatar
Re: Self Leveling On Ply Floor
here you go
http://www.parabond.com/surfprep.php
genecarp is offline
Old 08-14-2008, 11:37 PM   #3
Sharp Improvements
Originally Posted by genecarp View Post
Nice,
I really appreciate that link! Your good deed for the day is done.
Thank You!
Norman Sharp
Old 08-15-2008, 09:04 AM   #4
Tile Contractor
Bud Cline's Avatar
You don't want to install ceramic tile over any gypsum floor patch.
Bud Cline is offline
Old 08-15-2008, 10:59 PM   #5
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Two coats of primer, wire lathe, and your good to go with SLC....IF the substrate it up to spec deflection wise. That's the place to start FIRST.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
water damaged wood floor replacement 72chevy4x4 Flooring 21 03-30-2008 09:39 AM
Job Sequence - New House MHMConstruction Construction 19 12-09-2007 01:14 PM
New Concrete Floor laid, cracking, and sealer Q's. Knyte260 Construction 21 10-07-2007 12:25 AM
leveling floor for nail down planks ike_in_nc Flooring 5 08-01-2007 01:53 AM
leveling out a flagstone floor to install hardwood CharlieGE Flooring 9 08-02-2006 09:46 PM
