Schluter Shower Pan
Old 03-20-2011, 10:07 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Question
Schluter Shower Pan
why in the installation videos schluter tells you to use dryset mortar to install their foam pan and curb? Why would you not use modified?
bluebird5 is offline
Old 03-20-2011, 10:08 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Schluter Shower Pan
Depends what the substrate is. If it's plywood, I've been told by Herr Schluter you can use modified. If it's over concrete, use non.
Angus
angus242 is offline
Old 03-20-2011, 10:31 PM   #3
Tile Pro - Consulting
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Rewards Points: 352
Not for the foam Angus. You're supposed to use regular dry set unmodified over plywood. You're thinking of Ditra.
Jaz
TILE GUY - retired- TROY, MI - Method & Product suitability consulting.
MARBLE from ITALY & GREECE - PERLATO SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - NAXOS - others, Slabs - Tiles - Custom - marmo.sicilia@yahoo.com
JazMan is offline
Old 03-20-2011, 10:36 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Jaz
No Jaz. I asked this exact question to my rep and that was his answer.
Angus
angus242 is offline
Old 03-20-2011, 11:00 PM   #5
JazMan's Avatar
Rewards Points: 352
And so......? Their videos and handbook say otherwise.
I agree that modified makes sense, and I always questioned that in my mind, but since I have no plans to use the tray I didn't investigate further. I see no problem using modified, but I'm gonna believe the videos and handbook over what one person may have said.
I suppose I should check into it tomorrow.
Jaz
JazMan is offline
Old 03-20-2011, 11:04 PM   #6
bluebird5's Avatar
Rewards Points: 694
is there a minimum tile size for the schluter tray?
Old 03-20-2011, 11:05 PM   #7
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I would assume you and I have the same rep so I would hope you would get the same reply.
I asked Chad in the summer of '09. That was his reply to me and I have been using that formula since.
Angus
angus242 is offline
Old 03-20-2011, 11:09 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
There is no size limitations. Although, there are certain materials you might not be able to use based off setting material recommendations. You need to set the tile with non-modified.
Angus
angus242 is offline
Old 03-21-2011, 10:22 AM   #9
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Does Non Modified Thin Set even stick to plywood?
How could they spec Modified with Ditra and Non Modified with the foam pan...
JW
JohnFRWhipple is offline
Old 03-21-2011, 11:33 AM   #10
JazMan's Avatar
Rewards Points: 352
Absolutely it does.
The two are a different situation. The need for modified under Ditra is obvious. I think Schluter thinks non mod solves the curing aspect while still supplying plenty of bond power to do the job.
Remember non modified mortars were used for many years to set porcelain tile until modified thin sets came along in the '70's.
Jaz
JazMan is offline
Old 03-21-2011, 11:39 AM   #11
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
non modified sticks to plywood?
not very well I would imagine.
does any cement product that isnt modified in any manner really stick to wood? I use a piece of ply wood to rid myself of cement based products quickly.......why because it doesn't stick, I can scoop it off no problem the next day.
boogers stick to plywood too Im not about adhere to tile with it though.
Sebastian
Check out my gallery here http://on.fb.me/I2XylV
Check out my blog here http://sebastianbethke1337.wordpress.com/
Bastien1337 is offline
Old 03-21-2011, 11:42 AM   #12
ee3's Avatar
Trade: membranes and shower products
Rewards Points: 192
most mfg. of setting materials and ANSI Standards would say ANSI 118.11 (modified) to plywood.
I thought there was a Min. tile size for the tray of 2"..
ee3 is offline
The Following User Says Thank You to ee3 For This Useful Post:
JohnFRWhipple (03-21-2011)
Old 03-21-2011, 11:48 AM   #13
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
Hey Jazz-
Have you used DITRA Set before? Just curious because it is available at my supplier as well as the additive. You seem to be very loyal to the Schluter products so I figured I would ask. I am considering using it on my next install. Can this product (with the additive) be installed over OSB. I have not seen a manufacturer give this blessing yet. Thanks.
Brian
ROVACON is offline
Old 03-21-2011, 11:52 AM   #14
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
There is not a 2" restriction for the pan, only Ditra.
Like I said, I've been setting the foam pan and curb over EGP with modified. A 24 hour wait has been sufficient for a cure and substantial bond. I use Kerabond + Keralastic for my modified thinset.
I guess I'm a rebel like that
This just goes to show the continued issue with Schluter support; inconsistent information. I'm not making this up. My rep told me in July '09 that setting the foam Kerdi shower pan with modified thinset over a properly structured exterior glue plywood base is acceptable.
Angus
angus242 is offline
Old 03-21-2011, 12:53 PM   #15
JazMan's Avatar
Rewards Points: 352
Bastien,
Yes it sticks to plywood. Not good enough to bond tiles to it, but that is not the subject here.
Brian,
Yes of course. We've been lucky that a Schluter distributor added several Hydroment lines 5-6 years ago. They have now dropped it but there's plenty of quality non modified mortars available to set tiles onto Ditra & Kerdi to.
You can use any modified thin set to install Ditra over OSB. The "not on OSB" warning is in regards to the installation of tiles on OSB. (Big difference.) That of course will not work and is not recommended by anyone.
Jaz
JazMan is offline
Old 06-08-2017, 09:33 AM   #16
PatrickDIY's Avatar
Trade: Masonry
Rewards Points: 6
Hi, I was looking for the answer to this question, modified or unmodified for shower tray on plywood, so came across this thread. I finally decided to call Schluter today and asked. They said without hesitation, use modified over plywood, just to set the tray, everything above (orange cloth and tile) unmodified.
Hope this helps, it's been a nagging question I've had since watching the video's (just didn't square that the ditra used modified and shower tray didn't). BTW if you have a question about Schluter products, call their customer service, they seem quite willing and able to help.
PatrickDIY is offline
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
Schluter Rookie Morning Wood Tiling 21 03-09-2011 06:02 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
tub spout to shower wand lshomesolutions Plumbing 1 06-08-2010 09:42 PM
Tiled shower leaks...Could use any advise at all... Jay22 Tiling 17 12-10-2008 07:15 PM
