Sand Or Unsanded
Old 02-07-2009, 12:14 AM   #1
woodlover's Avatar
Trade: Builder/Designer
Sand Or Unsanded
witch type of grout is used for tub/shower( sand or unsanded)and witch type is for the floor and why?
woodlover is offline
Old 02-07-2009, 12:22 AM   #2
Mellison's Avatar
Trade: Home Improvement General Contractor
Re: Sand Or Unsanded
It depends on joint thickness as well as the tile used.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 02-07-2009, 12:32 AM   #3
woodlover's Avatar
joints are 1/8"
ceramic tile 10 x 13
Old 02-07-2009, 12:37 AM   #4
Sean
SLSTech's Avatar
1/8 & less unsanded
The sand is a filler for larger joints
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
woodlover (02-07-2009)
Old 02-07-2009, 12:21 PM   #5
bathroom guru
jarvis design's Avatar
It doesn't sound like you've done much tile work!! I would really recommend getting the TCNA handbook on tile installations and spend some time going through the posts on this forum. Both will give you a lot of info. Also, if you want to be at the top of your game, look into Schluter products.
And, as mentioned, sanded or un-sanded is all about the joint width and depth - unless you are like me and use epoxy grout - which is the best and can be used for any joint width
Good Luck
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
The Following User Says Thank You to jarvis design For This Useful Post:
Old 02-08-2009, 05:27 PM   #6
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
You're half right. The ONLY thing that determines the grout is the joint size. Period.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
