Ripping Carpet To Install Ceramic Tile
Old 09-19-2009, 05:05 PM   #1
Union Electrician
Reseman's Avatar
Trade: Electricial Contractor / Electrician
Question
Once that I have ripped the carpet out of the bathroom and everything with it. Vacuumed and sweep the floor. I would like to know if I need to mop the floor with anything to get that glued foam streak off of the concrete? Or is scraping with a puddy knife sufficient?
Thanks in advance,
Rese
Reseman is offline
Old 09-24-2009, 01:34 AM   #2
Tiling & Bath Contractor
TileLady's Avatar
Trade: Tiling & Bathroom Remodeling
Re: Ripping Carpet To Install Ceramic Tile
Is this your bathroom or a customer's bathroom????
TileLady is offline
Old 10-09-2009, 07:45 PM   #3
tile mason
MattCoops's Avatar
It's a cement subfloor?
Did someone use some sort of adhesive for the foam pad beneath the carpet?
I'd use a floor scraper and some goo gone or similar liqui-release. I try to use mechanical means to clean cement slabs of prior adhesive.
You really want a floor, especially a cement floor that is going to recieve tile directly on top of it, clean of any dirt, goo, and grime.
MattCoops is offline
Old 10-11-2009, 12:22 AM   #4
One tile at a time
floorsRus's Avatar
Trade: flooring installation
well you should always start of with clean floor if you working with cement floor use a belt sender to clean carpet pad glue and other stuff like left on floor by painters and texture people ones that is done sweep floor or vacuum real good that is most of time is good enough i usually damp mop it also sometimes. or have a sponge next to you while spading the thing set Little dampness is ok and use flex base thing set. if subfloor is wood then use cement boards just remove high spots and fasten down board according to instructions, I was at home depot other day they got this new stuff peals and sticks looked like foam bobbles comes in sheets, i would think with this product screwing subfloor down firt real good so grout line wont crack right a way good luck by FLOORS WE DO. com
floorsRus is offline
Tile job goin sour, what to do ? mendelectric Ceramic & Stone Tile 64 08-19-2009 03:49 PM
Carpet Tile Questions M&GConstruction Flooring 0 03-27-2009 11:35 PM
Estimate On Ceramic Tile Buca1025 Ceramic & Stone Tile 30 02-03-2009 10:56 AM
going rate for tile and carpet removal oldglorydev Flooring 18 09-21-2008 02:26 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
