Removing Tooth Brush Holders Soap Dishes Etc
Old 01-21-2008, 10:49 PM   #1
Patrick's Avatar
Rewards Points: 2,364
Hi, Question for my own home, Is there any way to remove a ceramic soap dish and toothbrush holder from a tile wall, without damaging the tiles underneath, and if so, is there anyway to remove the grout around it and clean the tiles underneath? OR do i need to just bust them off, and remove the 4 affected tiles and replace them assuming I can find replacements? Thanks
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 01-21-2008, 10:59 PM   #2
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,016
Re: Removing Tooth Brush Holders Soap Dishes Etc
Try a dremel with small diamond cutting wheel... Score the grout around the perimeter & then tap it out with a rubber mallet. You might get lucky.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 01-21-2008, 11:11 PM   #3
Patrick's Avatar
What are the chances of getting the tiles under it clean from the grout?
Patrick is offline
Old 01-21-2008, 11:21 PM   #4
Builder/Remodeler
ChrWright's Avatar
Unsanded grout will usually clean off fairly easy. Just don't use anything metal.
Sanded still might clean off, but will take a little more effort.
Old 01-21-2008, 11:22 PM   #5
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Are you sure there is actually tile underneath it? I can't think of anytime the dish or holder wasn't either mechanically fastened through the tile, so there will be holes in the tile if you remove it, or the item was fastened directly to the underlayment and the tile cut around it.
Mike Finley is offline
Old 01-21-2008, 11:24 PM   #6
Builder/Remodeler
ChrWright's Avatar
Mike's right... you'll get it off but there'll be a hole behind it.
Old 01-21-2008, 11:30 PM   #7
Patrick's Avatar
Man, you guys just had to foil my plan, So plan B is to find some matching tiles. Plan C is a new back splash to match the new countertop
Patrick is offline
Old 01-22-2008, 10:30 AM   #8
Teetorbilt's Avatar
Around here they're commonly installed with a big goob of mud, no fasteners. The hole size varies by how far the mud slid down the inside of the wall.
Albert Einstein
Teetorbilt is offline
Old 01-22-2008, 11:00 AM   #9
Per-zactly!
My money is on Plan C.
neolitic is offline
Old 01-24-2008, 05:50 PM   #10
tiledogg504@hot's Avatar
Trade: Tile Contractor
I agee most soap dishes are installed directly to substrate > there will be a hole when u get done . Try heating with a heat gun sometimes this loosens thinset and grout . Hope you have tiles to replace . There should always be extra tiles saved for this purpose .
tiledogg504@hot is offline
standard height for shower soap dishes and shelves? zmusashi General Discussion 16 08-10-2011 08:39 PM
Putting soap in mud Chazbe Drywall 37 01-31-2008 11:15 PM
Bottom shelf dishes are not getting clean Patton Plumbing 1 04-28-2007 08:40 PM
Would you pay $20 for a bar of soap if it was made using a bike? Mike Finley Off Topic (Non Trade) 5 08-22-2006 12:26 AM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 10:58 PM
