Removing Tile On Concrete
Old 11-01-2007, 08:35 PM   #1
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
I helped a Friend this afternoon removing a few tiles on a concrete floor. We used a 2' chisel and it took about 40 minutes to remove the tile/motor/grout from just 3 tiles. My arms are now dead and my body is sore........what do you folks use to remove tile from concrete?
2ND question: All three of the tiles were cracked and we were not surprised to see a crack in the concrete floor under the tiles. Is there any cure for a crack in the concrete or is it just one of those things in life?
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 11-01-2007, 08:43 PM   #2
Three Rivers Services LLC
aWorkaHolic's Avatar
Re: Removing Tile On Concrete
1. A hammer drill with chisel bit
2. Nothing in the area of tile your replacing.
aWorkaHolic is offline
Old 11-01-2007, 09:35 PM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Get your self a cheap air chisel ($29.00). WAAAAAY easier then manuevering around a hammer drill, and way better than putting all them hours on an expensive piece of equipment, plus you can get lower angle which really helps pop the tiles up. Then get yourself one of these nice demo bars they are selling now and scrape the big residue stuff of thinset off while standing and finish up with a smaller demo bar to scrape anything off remaining.
Cracks are all different, if it's a spreading crack that's easy, if it's a crack that one side is going up or down you're screwed.
Mike Finley is offline
Old 11-01-2007, 10:06 PM   #4
dirt diggler's Avatar
Trade: contractor
chipping hammer ... all of five minutes .... more time in setting up
I have yet to ever put a warranty against cracking on concrete. KInda as you put it - it's one of those things in life. If someone knows a way to 100% guarantee "no cracks" - I would listen but be skeptical. I make sure any customers/clients realize the liklihood of concrete cracking
Thanks in advance!!!
dirt diggler is offline
Old 11-01-2007, 10:19 PM   #5
Teetorbilt's Avatar
I use an air hammer with a 1" bit when things get tough. I think that I know what you are up against, not thinset but something like hydraulic cement. I run into it a few times a year.
Buildings settle, no guarantees on slab cracks.
Albert Einstein
Teetorbilt is offline
Old 11-01-2007, 10:25 PM   #6
Mod / ArchiBuilder
Cole's Avatar
Exactly what I was thinking, good luck!
Cole is online now
Old 11-02-2007, 12:01 AM   #7
CaliDesigns's Avatar
Hey Dirt, I guarantee my Concrete!!!--- Against fire and theft.
CaliDesigns is offline
Old 11-02-2007, 05:18 PM   #8
Insert title
dougchips's Avatar
I'm not sure what they used I have never seen such a strong bond before. We had to hold the chisel at a 70 degree or so angle to chip the stuff up. I'll stick to removing tile from plywood and durock.
Old 11-02-2007, 05:27 PM   #9
Doofenshmirtz Evil Inc.
JumboJack's Avatar
I have had great luck with this...http://www.us.hilti.com/holus/module...jsp?OID=-12053
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 11-02-2007, 05:28 PM   #10
Trade: contractor
hey watch out though - ANYTHING can happen on "concrete day"
Old 11-02-2007, 05:53 PM   #11
Kingfisher's Avatar
My floor guy used something like jack post to remove about 200 sq ft of tile for glue down wood and it did a great job. Got everything up with out alot of dust. His had a longer shaft so there was not alot of back strain. I have a cheap air hammer from habour freigt ($5 with 5 bits) that I welded a 2" wide 3/16 flat stock to for chipping tar flashing of brick. It worked well but the soft steel needed a torch of the grinder every 10' at it needs a big compressor.
Kingfisher is offline
Old 11-02-2007, 09:33 PM   #12
POOLMANinCT's Avatar
ice
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 11-03-2007, 09:32 PM   #13
tileguy51's Avatar
Trade: TILE AND HARD SURFACE FLOORING
Get a grout removal tool first, scrape all the grout out of the tiles you want to remove then start chipping with a chisel or air chisel. For the cracks there is a crack isolation kit you can pick up at any flooring outlet. Lay the tile over that, Its always worked for me.
Pain is temporary, pride is forever
www.mccowinflooring.com
tileguy51 is offline
Old 11-04-2007, 02:20 PM   #14
tile mason
MattCoops's Avatar
We just use a demo hammer with a 2" cold chisel.
Rips up a floor in minutes.
The demo hammer we have set me back $780.
You can rent one from HD though.
MattCoops is offline
Old 11-04-2007, 02:36 PM   #15
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
dougchips We used a 2' chisel and it took about 40 minutes to remove the tile/motor/grout from just 3 tiles. My arms are now dead and my body is sore........
The 2 foot chisel may have been the problem! Try a smaller one or an electric chisel.... 2" would have been plenty
woodmagman is offline
Old 11-04-2007, 04:51 PM   #16
Insert title
dougchips's Avatar
2' so we could remove 2.18 10x10 tiles at a time........typo it was actually a 2" plastic putty knife.
Old 11-05-2007, 06:26 PM   #17
tile mason
MattCoops's Avatar
I ripped a floor apart with a rubber mallet and flathead screwdriver once
dont ask
Old 11-17-2007, 11:18 PM   #18
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Usually the tile's the easy part. It'll usually come up pretty quick with an electric chipping hammer and 3" chisel bit. The one I use is a Bosch 11316EVS (shown in the pic below). For scaling thinset or any other product off concrete, the scaling blade shown in the machine can't be beat. it'll scale thinset like there's no tomorrow (as you can see, it does great with vinyl, too!). It costs about 280.00, but it's worth every penny, and the blade on it can be replaced for about 35.00:
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 11-30-2007, 05:18 PM   #19
TimNJ's Avatar
Another case of this website being a valuable "tool" in itself. I am remodeling my kitchen for a "winter" indoor project around Feb. and I have 400+ sqft of ceramic to remove from my slab. I figured somebody on the Ceramic forum would have the best way and sure enough, here was this thread. Thanks guys
TimNJ is offline
Old 12-01-2007, 09:12 AM   #20
Knowledge Factory
Floordude's Avatar
Bill, where did you get that SDS scaling blade????? I have a sharpened paddle bit, but that there is the bee's knees!!! I need one!!!
I have the Bosch hammer. I just need that bit.
http://www.AustinFloorguy.com
Floordude is offline
Tile over cold concrete ponch37300 Flooring 6 02-01-2009 12:29 AM
Concrete over old asbestos tile... Cellomangler Flooring 10 10-20-2007 05:52 PM
Ceramic tile over concrete floor Handyman62010 Flooring 14 03-15-2007 09:40 PM
Removing Tile over hard wood flooring CMSuper Flooring 10 04-28-2006 10:43 AM
tile over concrete stringblade Flooring 14 02-12-2006 03:06 PM
