Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring > Ceramic & Stone Tile
Old 07-06-2009, 09:32 PM   #1
Trade: residential remodeling/construction
removing silicone
Because of a design change, I removed an existing 1/2" glass partition that was set in stainless channel along a tiled wall.
My question, what have you guys used to fully remove the silicone residue?
I have scraped as much as possible; tried DAP's silicone remover, to little effect.
My glass company said razor blades, something called acrysol that they carry ($27/pt)--I looked it up; it's basically naptha; or GOOF-OFF.
Anybody had luck w/any of these?
The tile is ungauged slate with many variations in height and flakes easily.
I told customer at the beginning that there may be a parting line; tile is no longer available so replacement is out.
rescraft is offline   Reply With Quote
Old 07-06-2009, 09:44 PM   #2
Painter/Rehaber
Dustyrose's Avatar
Trade: Painter
I use denatured alcohol to remove silicone before I refinish countertops. Works great. Given the substrate, you may need to use a firm tooth brush or another type of soft brush to get the silicone out of the grooves.
Politics is the art of preventing people from taking part in affairs which properly concern them. Paul Valery
Dustyrose is offline   Reply With Quote
Old 07-06-2009, 11:25 PM   #3
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Alcohol, and I buy these little brass brushes that look like toothbrushes.
Plus sandpaper (wet/dry) razors and a lot of time. No fun
silvertree is offline   Reply With Quote
Old 07-07-2009, 05:43 PM   #4
jarvis design's Avatar
Silicone is a bugger! Like the above posts, I used to use a lot of razor blades, sandpaper, and finally, to get the last bit of residue, alcohol and a brush.
Good luck!!
Do it Right the First Time....or someone else will!!
www.JarvisDesignBuild.ca
jarvis design is online now   Reply With Quote
Tips/Tricks for removing shingles Jambruins Roofing 33 09-05-2009 12:07 AM
Removing tile that is set under base cabinets.. bujaly Flooring 36 08-20-2009 01:38 PM
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 08:52 PM
removing sheet vynl Rx8 Flooring 10 03-20-2009 12:03 PM
Removing silicone caulk ron schenker Painting & Finish Work 8 02-07-2007 08:33 PM
