Remove Grout
Old 04-28-2011, 10:11 PM   #1
Carpenter
J.M.'s Avatar
Rewards Points: 93
Remove Grout
With is the tool to remove grout. It is a nice size floor.
If guns kill people I can blame misspelled words on my pencil.
JAY
J.M. is offline
Old 04-28-2011, 10:23 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Remove Grout
Prayer....
Your biggest issue will be dust control. Do you want to:
a) Contain the dust within the room?
Grout Grabber
b) Contain the dust within the tool?
Pearl Vacu-Guard
Of course, you need a suitable extractor for the 2nd option.
Angus
angus242 is offline
Old 04-28-2011, 10:39 PM   #3
Tile Guy
Berniktile's Avatar
Trade: Flooring, tile, stone (residential, commercial )
Re: Remove Grout
Angus, is thy just an adapter to a sawzall? If so where are they sold?
Berniktile is offline
Old 04-28-2011, 10:43 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Remove Grout
Yes and click the blue link directly under the picture!
Angus
angus242 is offline
Old 04-29-2011, 04:08 PM   #5
Carpenter
J.M.'s Avatar
Rewards Points: 93
Re: Remove Grout
Angus: I just went out and got 4 Grout Grabber last night. I saw them in the store before did not know if they were any good thank you.
JAY
J.M. is offline
Old 04-29-2011, 07:30 PM   #6
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
Re: Remove Grout
Home Creapo carries them here.
Josh
hhicontracting.com
HandyHails is offline
Old 04-29-2011, 08:15 PM   #7
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,808
Re: Remove Grout
I like my Bosch cordless oscillating multi-tool to remove grout. Granted the battery life is a little short, but the blade for grout removal is the bomb. Doesn't kick up much dust at all. Not recommend for over 100 sq feet, a little slower than Angus's suggestions.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 05-01-2011, 05:46 PM   #8
opiethetileman's Avatar
Trade: DIYer apparently
Re: Remove Grout
Well if they would have used permacolor grout by laticrete ya wouldnt be cutting it out because of staining
opiethetileman is offline
Old 05-01-2011, 05:50 PM   #9
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Re: Remove Grout
I use a multi tool with the diamond semi oval attachment.
JHC is offline
Old 05-02-2011, 09:11 PM   #10
Carpenter
J.M.'s Avatar
Rewards Points: 93
Re: Remove Grout
I used the Grout Grabber on the job today and it works great. The Grout Grabber works a lot better then my multi-tool on bigger jobs and my be on smaller jobs to.
JAY
J.M. is offline
Old 07-14-2011, 07:05 PM   #11
Maciek's Avatar
Trade: handyman, remodeling
Re: Remove Grout
I have a small problem
its about 250sqft of 12/12 tile with a sealed grout that is kicking my butt
I have used my multimaster with the grout removal wheels but they don't last long enough and its taking way too long, I was only able to do about 50sqft today in about 4hrs with 3 wheels
would the grout grabber work better? and most importantly faster? or is there a better way to do it?
I never had a problem with any grout before and I usually just use the triangle grout remover and they have been working great and faster most of the time than the multimaster but this grout is too hard for that tool
Maciek is offline
Old 07-15-2011, 11:30 PM   #12
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Re: Remove Grout
this is what ORLANDO uses... cant go wrong..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 07-16-2011, 06:23 AM   #13
GO Remodeling's Avatar
Rewards Points: 96
Re: Remove Grout
I've always used a grinder with vac and fan in the window. Seems to me it's the fastest. Also, I like the control I have with a grinder. For small jobs or small grout joint, a Multimaster type tool is best.
But why does all this grout need to be removed? Is a grout stain possible? That might be a better use of your time.
GO Remodeling is offline
Old 07-16-2011, 06:31 AM   #14
Maciek's Avatar
Re: Remove Grout
When I went into this house there was cracked grout, the previous guy left spacers in the grout and the home owner sealed the grout with out cleaning it so she had paint and drywall dust in it.
I cleaned all of that up with grout 66, fixed the cracks and took out all the spacers. Now we are getting complaints that the grout is still discolored so we just decided to take all of it out and re do it.
after Thursday i have been trying to convince them to stain the grout but we will see how that goes.
if they won't go with that i will have to start using the grinder because i don't want to stay there for another 2-3 day removing all of that grout
Maciek is offline
Old 07-16-2011, 10:03 AM   #15
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Re: Remove Grout
I had a friend call me last summer when an Epoxy Grout install went South. The grout sagged on the vertical surface and needed to be removed.
I had heard somewhere that a Heat Gun can be used and he tried that. Seemed to work for him.
Have any of you other guys tried a heat gun on Epoxy or even Urethane Grout?
JW
JohnFRWhipple is offline
Old 07-16-2011, 06:51 PM   #16
JHC's Avatar
Rewards Points: 516
Re: Remove Grout
Nope not me, but I would make double sure epoxy didn't sag. Such a pita to get haze up or clean up tools that were forgotten about I don't even wanna think about that.
Only had to learn those lessons once.
Aren't you guys scared the grout grabber will chip a tile?
JHC is offline
Old 07-17-2011, 03:31 PM   #17
bathroom guru
jarvis design's Avatar
Rewards Points: 560
Re: Remove Grout
JW
I did a retile job on a stainless steel hot tub a few years back. Some of the tiles(mostly ones already replaced) were set with thinset. All the rest were set with epoxy.
We used our oxy/aceteline torch to heat up the tiles(and epoxy thinset), and they came off not too bad...which was good cause trying to "chip" them off wasnot working so well!
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
The Following User Says Thank You to jarvis design For This Useful Post:
JohnFRWhipple (07-18-2011)
Old 07-17-2011, 10:20 PM   #18
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Remove Grout
I seem to recall that stainless steel tub debacle.
cleveman is offline
Old 07-20-2011, 04:39 PM   #19
RichE
mwtradetool's Avatar
Trade: Tile Tools
Rewards Points: 75
Re: Remove Grout
The Grout Grabber is designed to not chip the tile, unless your hands are very unsteady!
The Grout Grabber doesn't work well on epoxy grout. I did have a contractor use it with a heat gun and he was able to slowly remove the grout.
RichE
Midwest Trade Tool
www.tiletools.com
mwtradetool is offline
Old 01-02-2013, 08:19 PM   #20
ets80's Avatar
Trade: roofing
Rewards Points: 75
Re: Remove Grout
Grout Grabber - Hands down the best!
ets80 is offline
The Following User Says Thank You to ets80 For This Useful Post:
Sprung831 (01-03-2013)
Urethane Grout Installation Tidbits angus242 Tiling 100 05-13-2013 03:23 PM
What do you tool the joints with after you rubber float the grout MikeGC Tiling 15 04-24-2011 08:29 PM
grout stains unavoidable? MichaelEmerson Tiling 32 02-27-2011 06:56 AM
Grout sealer Jer Tiling 7 12-19-2010 02:50 PM
best stain-resistant grout for glass tile rock nohow Tiling 3 10-10-2010 05:58 PM
