Rapid Set Thinsets - Tiling - Contractor Talk
Rapid Set Thinsets
Old 04-26-2011, 09:38 PM   #1
Mtr_20's Avatar
Trade: Flooring
Rapid Set Thinsets
I have a project coming up that will require getting tile set in a limited time... I use mapei's ultraflex rs or custom's speedset when in these situations and both require a minimum 2 hours before grouting I believe... It's a commercial job and the time that's allotted before they open is only 4 hours from the start of the day so I want to make sure I get a good bond before traffic is on it... Just wondering if there is another rapid set out there that requires less time
Mtr_20 is offline
Old 04-27-2011, 01:17 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Rapid Set Thinsets
Not that I'm aware of.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
opiethetileman (05-03-2011)
Old 04-27-2011, 10:45 PM   #3
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
what i do sometimes is i add hot or warm water to the already fast setting thin set . it is a BIG HELP in the setting time, just be FAST because inside the bucket IT WILL DRY FASTER..
Floormasta78 is offline
The Following User Says Thank You to Floormasta78 For This Useful Post:
JohnFRWhipple (04-27-2011)
Old 04-27-2011, 11:11 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Good point
Even warm water will set off the thinset faster then you think.
x2 with it will dry fast....
Angus
angus242 is offline
Floormasta78 (04-27-2011)
Old 04-27-2011, 11:20 PM   #5
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Nice to see you over here Orlando!
JohnFRWhipple is offline
Old 04-27-2011, 11:25 PM   #6
Orlando Car
Mr.Whipple ! .. yea , Dan mentioned it so i decided to check it out.. its cool ! i like it.. nice to know my buddies are here ..
Old 04-29-2011, 08:31 AM   #7
algernon's Avatar
Rewards Points: 79
What would be the problem, if one were to grout before the 3 hour wait recommended by the rapidset instructions? Grout is unmodified, right?
-Algernon
algernon is offline
Old 04-29-2011, 10:13 AM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
If you're asking about the grout retarding the drying time of rapid set, it will not. Grout can be either modified or not. However, rapid set does not rely on air to cure.
But what can happen if you grout too early? You can disturb the tiles you just laid. Screw one tile up because of premature grouting and you will have a big problem on your hand.
Angus
angus242 is offline
Old 04-29-2011, 07:52 PM   #9
algernon's Avatar
Rewards Points: 79
Thanks, that what I thought. I have been working for a guy who owns a ton of apartment suites, and the toilet needs to be back on every night. He doesn't want a warranty, just the toilet back on each night. I don't want to pull the toilet 3 times...
So far, so good with the old; rapid set, wait an hour, grout where toilet is going, put toilet back on. I was shocked when he came in and started walking on fresh laid tiles on the first one. I was all "woah!!! fresh tiles!" He was like "So?! did it move?"
He's the boss, I guess. Did I mention he said he'd pay to have anything fixed by doing it "his way"?
-Algernon
algernon is offline
Old 04-29-2011, 08:12 PM   #10
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,904
Premature grouting...sounds like a personal problem to me.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
The Following User Says Thank You to TNTSERVICES For This Useful Post:
algernon (04-30-2011)
Old 04-29-2011, 08:16 PM   #11
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 05-01-2011, 12:22 PM   #12
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Would adding warm water to the RS thinset not make it dry too fast and alter its curing time and possibly strength? Just a question!
Groutface is offline
Old 05-01-2011, 07:01 PM   #13
Orlando Car
i have not had any issues yet ..
Old 05-02-2011, 09:33 PM   #14
building Contractor
FHS's Avatar
Rewards Points: 160
Rapid set is the only way to set a small bathroom, two trips for anything under 100sf is a waste of fuel.
Just wish i could get Mapei Rapid set ultra contact around here
Tim Fuchs Construction
FHS is offline
Old 05-02-2011, 09:48 PM   #15
Orlando Car
253R gold me ...
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Old 05-02-2011, 09:54 PM   #16
building Contractor
FHS's Avatar
Rewards Points: 160
I am limited by my choices around here for all tile products unless i want to pay inflated prices from flooring stores are very limited. Until I get a showroom setup I am at the mercy of others or long drives to larger towns.
FHS is offline
Old 05-03-2011, 04:32 AM   #17
Tech Dawg's Avatar
253R gold me ...
I used that the other week and was amazed with the open time... I stopped 3 times to look at the bag to make sure it said rapid on it
Todd
Old 05-03-2011, 05:34 AM   #18
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
thats one thing they went ovewr at the PTK 253r has longest open workable time out there. They showed us first hand.
There is a few other tricks to make rapid set go off quicker as well
opiethetileman is offline
Old 05-03-2011, 08:59 AM   #19
Shop Light?
Thermostat?
Heat Gun?
What?
Old 05-03-2011, 12:35 PM   #20
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Magic!
Angus
angus242 is offline
Rapid Set with Membranes Tech Dawg Tiling 54 04-29-2011 12:12 PM
difference between self-leveler and rapid set concrete? MichaelEmerson Flooring 9 04-11-2011 07:09 PM
rapid set with Ditra tang Tiling 4 01-06-2009 08:26 PM
latex modified thinsets mtplus Tiling 7 09-10-2006 08:32 AM
