Ramondi - Tiling - Contractor Talk
Ramondi
Old 08-08-2018, 06:34 PM   #1
Tom M's Avatar
Rewards Points: 8,414
Ramondi
Do you think I can get away with using 1/8" clips for 3/16 grout joint?
Tom M is online now
Old 08-08-2018, 07:46 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,222
Re: Ramondi
Yep...if the tile has a slight bevel on them on the bottom like some do, the joint ends up closer to 3/16" anyway. Bigger question is are the tiles consistent enough for 1/8 joints?
overanalyze is offline
Old 08-08-2018, 08:22 PM   #3
Tom M's Avatar
Re: Ramondi
Andrew Im tying into and existing 3/16" joint on a kitchen floor we saved and I need to extend.
The floor isnt too consistant, neither is the tile so I thought using the system with spacers would be a smart thing to do
Tom M is online now
Old 08-08-2018, 08:57 PM   #4
avenge's Avatar
Rewards Points: 3,218
Re: Ramondi
There's nothing wrong with using spacers regardless of the clip size.
avenge is offline
The Following 3 Users Say Thank You to avenge For This Useful Post:
overanalyze (08-08-2018), TNTSERVICES (09-19-2018), Tom M (08-08-2018)
Old 08-08-2018, 09:07 PM   #5
Tom M's Avatar
Re: Ramondi
I was curious because it is plastic after all and not sure how much give the clip will pull if not tight plus not breaking away clean. For the 1/16 I should fine. after that I may be pushing it
Tom M is online now
Old 08-08-2018, 09:20 PM   #6
Always Learning
Re: Ramondi
You will be fine to use the spacers and clips and they will break away fine. Just make sure to use a proper sized trowel. Tie in height could be an issue if the previous floor didn't use enough/proper thickness of thinset.
Old 08-08-2018, 10:07 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,860
Re: Ramondi
You can use damn near any spacer you want with em....so long as it's fatter than the clip.
Inner10 is online now
Wile E Coyote (08-10-2018)
Old 08-08-2018, 10:21 PM   #8
tjbnwi's Avatar
Rewards Points: 5,402
Re: Ramondi
Agree with everything above.
tjbnwi is online now
Old 08-08-2018, 10:32 PM   #9
Renaissance Man
superseal's Avatar
Rewards Points: 5,628
Re: Ramondi
You'll only get the actual joint size of the clip if the tile is rectified. The reds with an eased edge will give 3/16 min. Chit some edge treatments will give the appearance of 1/4".
supersealconstruction.com
superseal is online now
Old 08-09-2018, 05:49 AM   #10
Tom M's Avatar
Re: Ramondi
I can see the clip flexing more as joints widen but they are probably hard enough to pull alignment.
Tom M is online now
Old 08-09-2018, 06:03 AM   #11
BeforeChristoff's Avatar
Trade: RENOVATIONS
Rewards Points: 94
Re: Ramondi
I always use both, better safe than sorry.
BeforeChristoff is offline
Old 08-10-2018, 10:28 AM   #12
AustinDB's Avatar
Rewards Points: 876
Re: Ramondi
Only reason I used spacers on this wall is to hit the ceiling with a full tile. If you do use spacers on a wall, I recommend putting the spacer in after tightening the wedge. On the floor, you have no issue with the spacer popping out.
AustinDB is offline
Old 08-10-2018, 10:30 AM   #13
AustinDB's Avatar
Rewards Points: 876
Re: Ramondi
with larger grout joints (spacers) do your best to keep the clip perpendicular to the tiles so that even pressure is applied to each tile.
AustinDB is offline
Old 09-19-2018, 09:10 PM   #14
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
Re: Ramondi
1/8" clip even with a 1/4" grout line (I am not sure why that large), would mean 1/16" space on either side of the clip. That isn't going to flex the clip and you really don't have to be so anal to make sure it's perp to the tile. You shouldn't be need that much pressure to level the tile. We just finger tight the wedge and move on.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
