Remodeler
Question On Issue I Saw Today
I was a regular customers home today doing a small repair and she pointed out a tile issue in her Lanai (Florida home). Not my install. There are 6 or 8 tiles that have raised at the grout line. Nothing is cracked but these tiles are about 1 to 1 1/2" up. Kinda like the sub floor buckled. This is on a slab. Older home maybe 20 years. The area is hollow so the slab is in place as far as I can tell. It's like the tiles expanded and buckled. I was just wondering how this happen. Any ideas?
Trade: Home Remodeling
Re: Question On Issue I Saw Today
Slab crack due to weak foundation/wet soil movement.
Chief Toilet Mover
Trade: Bathroom Remodeling
Actually based on your description it sounds like no expansion allowed for in a large floor.
Professional Remodeler
I am thinking along the same lines as Mike, no expansion room at the sides and the tiles are being laterally compressed and being forced up off the slab.
-Mike- Falcon Contracting Residential - Commercial
Remodeler
The expansion is what it looks like to me too. Most tile floors I have seen done have been tight to the walls with grout. What type of expansion should be allowed in a case like this? Silicone? I realize the lanai being out doors has much more extreme temperature / moisture changes.
The Remodeler
Trade: Home Remodeler
It's called Tenting.. An expansion joint around the perimeter is usually adequate for a regular sized room... Either 1. remove the base trim, leave out the grout between tile and walls and re-install trim over this gap, or 2. leave trim in place and use a color matching caulk between tile and baseboard. Larger spaces may need an expansion joint down the middle as well.
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
No doubt in my mind that it's tenting. It's caused as already stated, no expansion joints. This can also happen on interior floors if the person doing the install doesn't have the experience to know how to install tiles correctly. (Which today is well over half of those doing it...)
![]() On larger floors you also need expansion joints in the field of interior floors. Especially in wet areas and rooms that get direct sunlight for a good part of the day. For exterior applications you have to also have joints in the field anywhere from 8-12 ft apart, in addition to those around the perimeter of the floor. But how often is that done? Jaz |
tile contractor
funny thing about that tenting-- an 1/8" of compression would be enough to raise a floor a foot off the concrete!!
Go figure!
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
Remodeler
Thanks guys. Now I can tell the customer something that makes sense. And maybe do the repair.
Trade: Tile Mechanic
Paul~ Realistically, the only "repair" possible is to pull the floor and re-install it. There is no "easy" fix for a floor that is tenting. Simply put, you MUST have, at the minimum, a gap at the walls. As has been said, for a large area, an expansion strip would be needed.
"They Didn't Want it Good...The Wanted it Wednesday..."
| Funny phone call today | Tscarborough | Masonry | 11 | 09-23-2006 10:11 PM |
| Disability Insurance Question | Patty | Off Topic (Non Trade) | 5 | 09-02-2006 07:11 PM |
| Basement Window Question | gregt848 | Windows, Siding and Doors | 9 | 07-26-2006 06:29 PM |
| Discount Question... | JMGP | Painting & Finish Work | 8 | 07-19-2006 10:23 PM |
| Question about shower system... | Knyte260 | Plumbing | 59 | 10-24-2005 06:05 PM |
