Protecting The Weepholes
Old 02-26-2008, 07:16 AM   #1
orson's Avatar
Trade: Kitchen & Bath
Just wondering what everyone prefers to protect the weepholes from clogging. I've seen small gravel and tile spacers used and also the preformed products I have seen online at different tile sites. What do you guys use?
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 02-26-2008, 10:16 AM   #2
tile mason
MattCoops's Avatar
Re: Protecting The Weepholes
The TCA actually recommends small, broken pieces of tile.
We use "quad" silicone. It lasts.
MattCoops is offline
Old 02-26-2008, 10:45 AM   #3
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
I'll usually use tile chips, also-- one less thing to have to bring to the job with me!!
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 02-26-2008, 10:54 AM   #4
bujaly's Avatar
Trade: Commercial interior super
Sorry to ask. I know what weep holes are, but I'm lost on what you all are conversing about.. ???
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 02-26-2008, 11:25 AM   #5
Its all ball bearings
angus242's Avatar
Trade: Tile
If you know what weep holes are, then you know not to get them covered when you're setting your mortar over your waterproof membrane:
Matt suggested and Bill is saying he uses bits of tile, just like spacers are used in this picture.
angus242 is online now
Old 02-26-2008, 12:21 PM   #6
tile contractor
Mitch, what it's for, is to make sure that the mortar that's used to make the shower pan doesn't plug up the weepholes under where the spacers in Angus' picture are. It never made much sense to me, being that if water can get thru the mortar to get to the weepholes in the first place, how is it that the mortar could plug them up!! But it's spec, so I follow it. I have a feeling it might have to do with foreign material plugging up the pores of the mud, but I'm not sure about that.
Old 02-26-2008, 01:50 PM   #7
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
The weep holes are very small and easily clogged, that is completely different from moisture saturating and wicking through the mud. The best way to keep them from clogging?................KERDI SHOWER METHOD!
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 02-26-2008, 04:06 PM   #8
Tile Contractor
Bud Cline's Avatar
Where are the weep holes in the KERDI Drain?
Bud Cline is offline
Old 02-26-2008, 07:15 PM   #9
JazMan's Avatar
OK, I guess you're not going along with my humor?
On second thought maybe we should 'plain that for those that don't get it? Or.....they can ask?
Jaz
Tile 4 You llc
KERDI Shower
www.tile4you.com
JazMan is offline
Old 02-26-2008, 08:12 PM   #10
Tile Contractor
Bud Cline's Avatar
OK OK OK, so much for the tileguy humor.
The KERDI Drain doesn't have weep holes.
Old 02-26-2008, 08:33 PM   #11
Tile & Marble Contractor
Ceramictec's Avatar
Trade: Tampa Tile Contractor
so a Kerdi drain is always Happy ?
-Brian-
Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota
website: www.ceramictec.com
Ceramictec is offline
Old 02-26-2008, 08:39 PM   #12
Tile Contractor
Bud Cline's Avatar
I know I'm happy when I use them.
Old 02-26-2008, 09:24 PM   #13
Tile Guy
Whip's Avatar
Trade: Tile and stone
Weep holes very simply drain the watter from the bottom of your mud pan. I use a product called troba by schluter. I cut a small hole in it to fit the drain though it and then trim it up about 1 in bigger then the bottom of the drain to cover the weep holes. Then pack the pan on top of it. This reduces the chance of sharp tile cutting the rubber and spacers moving. We have packed over a 300 pans this way and have never had one leek.
Whip is offline
Old 02-26-2008, 11:26 PM   #14
cleveman's Avatar
Trade: custom home building
I never had a leek last year, despite planting a whole row of them. What's the deal? Do you need to plant them especially early? The best I had around October was something which looked more like a common salad onion or scallion. I'm going to plant them in mid-April this year.
On another note, my wife wants to know what happens to all the celery root. Sure, we've got celery everywhere, but where are all the roots? Maybe someone from CA can chime in?
cleveman is offline
Old 02-27-2008, 12:21 AM   #15
JazMan's Avatar
Hey Cleveman, don't you know that whether or not you have leeks depends on your geographic location? See, you're in Central Iowa, where as Whip is in Cininnati, I saw the difference right away!
Jaz ........
Tile 4 You llc
KERDI Shower
www.tile4you.com
JazMan is offline
Old 02-27-2008, 01:11 PM   #16
Tile Contractor
Bud Cline's Avatar
Leeks will grow in region 5 but you need to start them early in pots then later transplant them in your garden. Welcome to the Garden Web.
That's all BS I don't know anything about leeks.
Old 02-27-2008, 08:24 PM   #17
cleveman's Avatar
Thanks for the info, guys. I've often thought that I need to get a greenhouse.
cleveman is offline
Old 02-27-2008, 09:07 PM   #18
orson's Avatar
All I know about leeks is that they taste darn good in a pot with potatoes, stock, and a touch of cream.
www.rubycon.us
orson is offline
Old 02-27-2008, 09:10 PM   #19
R&D Tile's Avatar
Trade: Tile installations
Pea gravel.
R&D Tile is offline
Old 02-27-2008, 09:16 PM   #20
tile contractor
Now I kin unnastand the gravel part but why you gotta pea on it?
I crack myself up.
Protecting your computer GunnCon Technology 17 07-30-2006 10:10 PM
Garage - Protecting wiring installation eastment Electrical 1 11-22-2005 02:52 PM
