Problems Polishing Granite
Old 02-01-2009, 05:08 PM   #1
Roofer Ben
bkb0000's Avatar
Trade: Roofing
i've been doing a little granite and marble over the last year- maybe 5 or 6 big jobs requiring some form of polishing, each with dark granites- absolute, quite a bit of pear blue, galaxy, etc. had great results so far. i have an alpha variable speed wet grinder with 2 sets of 2 diamond pads, one about half worn, one brand new and freshly opened up.
decided to give granite slab a try- in my own house first: got a big slab of pre-polished 3cm butterfly blue, cut out the sink, scuffed it a little with this new corner cutter i'm not used to, so i decided to polish it out.
here's what i have now: an 8x2 slab of granite with about 4" of that completely dull and cant get it to polish out. why mott the hoople? never had granite refuse to polish. the butterfly blue is cheaper than most (all) of the granite i've worked with so far, and more porous, but the un-dicked-with section is bright and beautiful shiny.
here's what i've done: cut out sink, roundovered the cutout, polished the roundover, noticed some surface scuffing from my new tool around the sink. started with 400 to rub it out, it rubbed out fine, moved to 800 and the pad stuck to the slab- its a well used pad, still has some tread on it, but it's like it's made of rubber... lots of friction, bogs down my grinder. turn up the speed and water WAY up, move to 1500 which behaves fine, 3000 runs smooth- dry everything off and it's all dull and hazy. i assume my 800 didn't do the job, it looks like it stopped polishing at 800. open up the pad (thinking i might have run it dry at some point), same problem. so i bought a new set of pads, opened them up real good, and try again- same problem.
switch to a fresh chunk of scrap- start with 200, dull it up, work through all the pads, new and old, still cant get it to gloss up. i started to work backward and try some reverse-engineering, and haven't yet gone back behind 3000- i apply 3000 to polished area and it stays perfectly polished, so it snot the 3000. gotta drop back to 1500 and try to polish it out, then 800, etc- is this the correct course of action? and what do i do when i find the pad that's holding me up?
what am i doing wrong?
bkb0000 is offline
Old 02-01-2009, 08:33 PM   #2
Roofer Ben
bkb0000's Avatar
Trade: Roofing
Re: Problems Polishing Granite
the odd friction of the older 800 grit was cured by opening, BTW. that's not the issue anymore.
bkb0000 is offline
Old 02-01-2009, 08:49 PM   #3
Knowledge Factory
Floordude's Avatar
Two grits??
Your skipping too many grits to take the scratches out.
http://www.AustinFloorguy.com
Floordude is offline
Old 02-01-2009, 09:06 PM   #4
Roofer Ben
bkb0000's Avatar
Trade: Roofing
i didn't skip any- 400, 800, 1500, 3000 on two different sets
bkb0000 is offline
Old 04-04-2009, 10:16 AM   #5
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
I have the same set up , It hard to get the granite perfect after it gets scratched . I try not to run the tool over the edge of the grind . The best thing Ive done is to get the scratch out first, then start polishing lightly use a little presser for a longer time . clean very good between grits. To remove the hayes at the end i have a fine powdered diamond that you use to get the finish shine with the polisher .( It wont be perfect )John
wellbuilthome is offline
Old 05-03-2009, 11:52 PM   #6
Dan V.'s Avatar
Trade: Home Improvement/Remodeling
I've had similar issues when polishing edges on Black Galaxy. You need to drop all the way back to 50 or 100 to get the scratches out. Low RPM (1500 max), plenty of water and don't be afraid to apply some pressure. As you progress through the grits, you need to feather out your working area. Using a wax marker, make concentric circles (or half-circles in your case) around the scratches and as you to move to each higher grit, move out to the next line.
I spent most of my money on booze and women. The rest I just wasted.
www.forwardsolutions.net
Dan V. is offline
Old 05-04-2009, 11:44 AM   #7
Natural Stone Restoration
StoneRenew's Avatar
Trade: Natural Stone Restoration/Marble Polishing
Granite polishing is very tough. You say you have polished Black Galaxy? But you can't polish this one?? Doesn't make sense to me. Black Galaxy is probably the toughest granite out there to polish because of the dye's and agers used when its Fabricated. With most dark granites you have to take it up to 8500 grit. It could be that your using the wrong kind of pads. Usually I dont go to resin till about 1000 grit. You also might want to try polishing with Tin Oxide for a final buff. What pads are you using??
Matt White
www.ClevelandMarblePolishing.com
StoneRenew is offline
Old 05-04-2009, 11:45 AM   #8
StoneRenew's Avatar
Originally Posted by Floordude View Post
Two grits??
He isnt skipping grits.
Matt White
Old 07-21-2009, 10:03 PM   #9
So Cal Chando's Avatar
Trade: Tile & stone Flooring & slab countertop installer
go all the way back down to 50 grit take your time make sure its smooth after every grit... use a polishing wheel.. and if that doesnt work u can use like a laquer.. "tiger ager" its used by the shops down here....
So Cal Chando is offline
Old 07-25-2009, 11:38 PM   #10
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
My understanding is it's next to impossible to properly spot polish using a 4" polisher on a flat surface, like on a piece of slab or tile?
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 08-31-2009, 09:17 PM   #11
Rock Star!
GraniteGirl's Avatar
Trade: Natural stone fabrication & restoration
Send a message via Skype™ to GraniteGirl
Hi Bill!! How are ya?!
Surface polishing is possible - with a lot of practice and the correct tools.
High quality resin pads like ALPHA or comparable brands, along with rigid polishing disks (also ALPHA, although a few others do exist) are vital to the process, along with a high quality buff pad suited to the color (light/dark) of the stone you are polishing.
You will need a variable speed machine and loads and loads of practice and elbow grease.
Suffice to say, not many DIY persons or folks that are not dedicated stone professionals are willing to spend the money or time to learn to do this properly. The initial outlay (cash wise) could end up being $400-$500 depending on the quality of your tools & pads. The rest really takes hours and hours of trial and error to perfect.
GraniteGirl is offline
Old 09-03-2009, 09:35 AM   #12
tile contractor
Hey Lady!! Nice to see you found your way over here!!
Old 09-06-2009, 12:23 PM   #13
Tile and Stone Cleaning
brzelt's Avatar
Trade: Tile and Stone Restoration
Is this granite acid sensitive?
From your description, I question whether you have a basalt or a true granite.
Most basalts (cheap chinese dyed 'granites') are almost impossible to polish plus
they are acid sensitive like most marbles.
brzelt is offline
Old 02-21-2010, 10:25 PM   #14
Roofer Ben
bkb0000's Avatar
Trade: Roofing
I've never surface polished black, just the roundovers, which seem to be significantly easier than surface polishing. you could be right about the pads, they're not super expensive pads. they work great for roundovers, and i have surface polished several marbles and a couple granites with great results with them. this butterfly blue doesnt seem like it should be any harder to polish than blue pearl, with is obviously denser- that stuff took some elbow grease but came out really well. those were pieces that had swirl marks in them- all the supplier had from the same lot when i ran short.
but, as i said, i've never done slab/this big of an area before.
i did what you say a couple times.. same results. in fact, it seems the more i take off, the harder it is to get back up- the left side of the sink cutout, where i did take it all the way down to 50, is noticeably flatter than the right.
i did finally resort to lacquer... this is getting into totally alien area for me, but i did already have some stone lacquer from another project. it was just too damn hard to get an even coat over the whole thing. i tried twice, stripping off both attempts. i wasn't really trying all that hard, though- i suspect the best application method is going to be a one-swipe application, like with a 2" floor finishing bar (which i have). i just figured this was a stupid idea to begin with, and gave up. but if you've done it/know it works, then i might explore that further..
i don't know- i've wondered since the beginning if i just have really crappy "granite." it was sold to me through an outlet place that gets these from strange origins and sells mostly to local distributors (they say). all their stone products are seconds or thirds, which, in the right application, has worked fine for me in the past. is there some kind of test to see? and if this is the case, is it reasonable to assume it came with some sort of lacquer/resin/something that i stripped off with my polishing attempts?
thanks for the replies, gentlemen. and ladies.
bkb0000 is offline
My fault or the granite guy's? john elliott General Discussion 86 01-17-2011 03:48 AM
Polishing Granite Bob Mariani Ceramic & Stone Tile 6 01-10-2009 11:40 AM
Granite Shower Ramblinwreck Remodeling 3 01-01-2008 08:27 PM
Cutting & polishing granite plazaman General Discussion 4 01-12-2007 06:14 PM
