Primer For Travertine Tile Backed With Fibre Net And Resin/epoxy - Tiling - Contractor Talk
Old 06-24-2018, 05:29 PM   #1
speedsix's Avatar
Trade: General Construction
Rewards Points: 24
Dear all we will be installing travertine which is backed with a net and resin/epoxy.
We where suggested to use Mapei Grand Rapid but after some test it was clear that the glue was adhering 100% to the resin backing of the travertine.
Now i was advised to use some primer on the resin backing.
Any suggestions re glue and primer.
On the backing of the glue there is written that you could use Mapei PRIMER S or P or Eco Prime T. but we are lost on what to use as none of the spec sheets mentions application on epoxy. tks
Sent from my SM-G925F using Tapatalk
speedsix is offline
Old 06-27-2018, 07:32 AM   #2
AustinDB's Avatar
Rewards Points: 876
Re: Primer For Travertine Tile Backed With Fibre Net And Resin/epoxy
might help if you tell us what substrate you're attaching this to.
the primer 'might' be to prepare sheetrock or plywood for the glue but I'm not sure why you would use glue.
I've installed mosaic travertine before and embed it in thinset. Seal then grout.
AustinDB is online now
Old 06-27-2018, 07:54 AM   #3
speedsix's Avatar
Rewards Points: 24
Hi Austin we are installing some travertine to another ceramic tile and some other travertine to cement board.
We are worried that the tile glue "Mapei Grandrapid" is not adhering 100% to the backside of the travertine since its backed up with resin/epoxy.
tks
speedsix is offline
