Premixed Thinset
Old 01-25-2008, 10:27 AM   #1
POOLMANinCT's Avatar
Rewards Points: 1,008
Premixed Thinset
ok tileman,
another point of confusion. it seems you guys distrust & despise premixed thinset.
I was planning on buying bags of thinset as I usually do. (im sure I'm overthinking my travertine, I'd have it laid on a slab in no time. but laying over wood has my eye out for red flags.)
do you guys suggest making it myself? or do you consider the jars of "peanut butter emulsion" premixed mud???...
I have a friend (accountant/suit) heuse the bucket of peanut butter & its mushy.
anyway, long story short
bag mix or scratch mix?
ty
ray
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 01-25-2008, 10:39 AM   #2
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
Re: Premixed Thinset
Mix it up. The pre-mixed requires air to cure, so on large tile it might take weeks to set up.
reveivl is offline
Old 01-25-2008, 11:55 AM   #3
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Rewards Points: 526
I use mix myself. It cures faster and personally like the way it trowels better than premixed. I have used premixed for a back splash and it took days to dry. I will never use that stuff again. You said you are using travertine, make sure you use a WHITE thin set. The dyes in the gray can bleed though you tile and I can assume you will not be happy.
Norman Sharp
Be sure to like us on Facebook
https://www.facebook.com/Sharpimprov...homepage_panel
Norrrrrrrrrrrrm is offline
Old 01-25-2008, 12:25 PM   #4
I think I'm not expressing myself...
do you consider purchased sacks premixed?
Old 01-25-2008, 02:08 PM   #5
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 222
the sacks of dry powder are perfectly fine to use... I cant imagine anyone trying to make their own thinset from seperate materials.
The term Pre-mixed thinset was conjured up by the manufacturers... It's basically a tile mastic with some sand added for body.. I dont really see any use for the stuff at all. Regular ol' creamy mastic has it's uses, but for the most part, I stick with sacks of thinset. I use Versabond for damn near anything.
So to answer your question, No, I dont think anyone would consider a sack of Versabond premixed.
Splinter is online now
Old 01-25-2008, 04:23 PM   #6
Proprietor
MattCoops's Avatar
Trade: TILE!
Rewards Points: 1,060
Do you really want to suffer the consequences of doing a floor in pre mix mastic just to escape minutes of time mixing a bag of modified thinset?
Matt Cupan TileWorks:
Bathroom remodeling & custom tile projects for the Commonwealth of Massachusetts, southern New Hampshire and Union County, North Carolina.
(978) 476-0662 | cupantile@gmail.com
MattCoops is offline
Old 01-25-2008, 04:25 PM   #7
Tile Pro - Consulting
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Rewards Points: 352
No, no, what he means is not pre-mixed, he meant to say pre-blended. And of course there is no such thing as pre-mixed VersaBond. VersaBond is an entry-level modified thinset which works fine for most projects. But don't confuse it with any premium mortar.
Pre-mixed 'thinset' is JUNK.
Jaz
TILE GUY - retired- TROY, MI - Method & Product suitability consulting.
MARBLE from ITALY & GREECE - PERLATO SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - NAXOS - others, Slabs - Tiles - Custom - marmo.sicilia@yahoo.com
JazMan is offline
Old 01-25-2008, 04:33 PM   #8
that's the ticket,
I thought you guys meant preblended is junk...
ty,
I go through skids of preblended orange sacks in a season, so I was wondering what the prob is....
long story short
sacks/preblended
premixed/peanut butter in a bucket...
ty
ray
Old 02-05-2008, 08:13 PM   #9
css's Avatar
Trade: Natural stone and ceramic tile
did you say you are installing travertine over wood???
css is offline
Old 02-06-2008, 11:44 PM   #10
Proprietor
MattCoops's Avatar
Trade: TILE!
You can actually install tile over a mix of portland cement and moist sand.
Most people use a cutback like thinset, but you can stick the tiles while the mud mix is wet and level.
The trick is to layout your job and make sure everything is prepped.
That's the ultimate "mix" to use for your tile.
Old 02-12-2008, 10:46 PM   #11
Kel, Fletcher Tile
fletcher.tile's Avatar
Trade: Tile & Stone Installation
I have to disagree with you Coops, to play the devils advocate, but if this is true it could help with profit down the road. Sand and cement? Do you have a link? I'm going to set a tile with this tomorrow and pull it up in a few days to check bond strength. Manufacturer's instructions are always helpful if that fails.
- Kel
fletcher.tile is offline
Old 02-13-2008, 09:30 AM   #12
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Kel, it's actually the oldest, strongest, and most successful installation method in the world. It's normally what's known as a mud job (minus the cutback-- that threw me, too). Although very few in the trade know how to do a TRUE mud job, it still exists. Matter of fact, I'll be doing a small one here sometime next week-- where the mortar bed goes down, gets dusted with portland cement, gets sprinkled with water to activate the cement, and then the tile goes in immediately, gets beaten in with a beating block and hammer, and then grouted and finished all at one time. No latex, no thinset, no waiting for the bed to dry and harden. DONE.
However, you won't find its strength within a couple of days. Matter of fact, it's usually recommended that you don't even WALK on the floor for 3 days, no regular traffic for a week, and nothing heavy for 28 days. THEN you'll begin to see its strength, and the longer the installation is there, the tougher it'll get.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
"MUD" - What is it? Bud Cline Tiling 53 08-13-2011 06:39 PM
FlexBond Thinset chimney repair Steampiper Masonry 9 02-27-2009 12:40 PM
Will thinset bond to Quartz tileguy51 Tiling 6 01-24-2008 06:42 PM
thinset under backerboard. Big Dave Tiling 35 09-24-2006 01:01 PM
thinset under backer board? stringblade Flooring 6 02-12-2006 12:59 PM
