Porcelain Vs. Marble Tile - Page 2 - Tiling - Contractor Talk
Old 12-20-2012, 12:47 AM   #21
SMLWinds's Avatar
Trade: Jack of all trades, master of none
Rewards Points: 25
Re: Porcelain Vs. Marble Tile
No ditra? Why remove the T&G planks and put down new ones? Just because they are old?
SMLWinds is offline
Old 12-20-2012, 12:57 AM   #22
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 1,784
That's one hell of a floor Angus. You could tile that thing in Saltines and they'd last for 200 years.
BlueRidgeGreen is online now
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
astor (12-26-2012)
Old 12-20-2012, 12:58 AM   #23
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Why Ditra? What does it offer that is so special?
3/4" T&G is a stronger substrate than individual planks.
Angus
angus242 is offline
Old 12-20-2012, 01:00 AM   #24
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
That's the point. However, it's not far off what the minimum specs are recommended by the "industry".
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
BlueRidgeGreen (12-20-2012)
Old 12-20-2012, 08:48 AM   #25
bathroom guru
jarvis design's Avatar
Rewards Points: 560
I like natural stone over look a likes as well. I did however find a pretty nice fake from Dal tile!
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
Old 12-20-2012, 02:40 PM   #26
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Originally Posted by angus242 View Post
If you could sister in 2x10's on at least every other joist under the foyer, you'd be real close to the minimum. I'd remove the planks and add 3/4" T&G. An additional layer of 1/2" EGP and you are good to tile. If leveling is a problem, a mud bed fixes the issue in 1 step. If you are not confident with floating that much, or the floor height would be too dramatic, go with prime and self leveler. You could then do a thin crack isolation membrane using a liquid like Mapei Mapelastic CI or a sheet membrane like NobleSeal TS. Both are very thin and won't raise the floor height.
I'd definitely remove the planks, add T&G and the 1/2" ply. The rest is up to you but at least at that point your subfloor will be sufficient enough for whatever you install.
Pretty much exactly what I'd do. For a beginner I wouldn't even think about a mud bed if you have access to SLC. Follow the directions EXACTLY on the bag of slc! Do not use even lukewarm water - the warmer the water the less working time. A newbie needs all the time he can get lol. Considering the substrate flatness needed for stone and tight joints you'd be waaay ahead going that route.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following User Says Thank You to PrecisionFloors For This Useful Post:
astor (12-26-2012)
Old 12-20-2012, 03:28 PM   #27
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
With that spacing and span any type of fir 2x10 #2 or better is all ready stiffer than 1/720. If your old joists are a full 2" (roughsawn) thats even better
smeagol is offline
Old 12-20-2012, 06:03 PM   #28
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Not quite, It's still in the L/680 range. And don't forget, L/720 is MINIMUM.
Angus
angus242 is offline
Old 12-20-2012, 09:54 PM   #29
smeagol's Avatar
Rewards Points: 638
Angus you must be figuring in some insane live load on top of a 20psf dead load to come up with that.
smeagol is offline
Old 12-20-2012, 10:15 PM   #30
smeagol's Avatar
Rewards Points: 638
Correct if I am wrong but i thought 1/720 only pertained to marble and 1/360 to tile?
smeagol is offline
Old 12-20-2012, 10:24 PM   #31
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Nope. My handy-dandy national forestry chart gives me L/679 for
2x10
16 OC
11'2" unsupported span
douglas fir in good condition.
Angus
angus242 is offline
Old 12-20-2012, 10:25 PM   #32
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
L/720 for natural stone
L/360 for man-made tile
He's asking about installing marble.
Angus
angus242 is offline
Old 12-21-2012, 01:06 PM   #33
smeagol's Avatar
Rewards Points: 638
I get my span info from awc.org/calculator
smeagol is offline
Old 12-23-2012, 10:44 AM   #34
SMLWinds's Avatar
Rewards Points: 25
Ok, now that we have the floor nailed down pretty well, on to selecting tile!
I have done significant research and received mixed reviews on marble vs. porcelain. At this point I think we are planning on a compromise...honed marble. We really like marble and the honed instead of polished will be a bit more tolerant of traffic.
With that in mind, I know that there is a whole range of quality when it comes to marble. Some marbles are very soft while some are relatively hard. We really liked a bianco carrara marble from Stone Partnership, Inc (NJ). Supposedly this company is very picky about the tiles matching and quality. However, the tiles also come a bit pricey compared to others we've seen ($15.69/square foot at the first store we had price it).
There are a thousand people out there selling honed white carrara...I've seen anywhere from $6/square to $20/square. How do I decide which one? I don't want to pay more for the same product but more importantly, I don't want to try to save a few bucks/tile and end up with a softer marble or lower quality stone. Any help is appreciated.
SMLWinds is offline
Old 12-23-2012, 11:28 AM   #35
Trade: Craftsman
IMVHO, I rely on 2 things when trying to purchase the best possible stone for the best price. Relationships and/or careful inspection.
I used to have a long-standing relationship with a great supplier built over many years, and I just knew that they would get me great stuff.
Now, I just have to go.....and see the stone for myself. Trying to order stone sight unseen is difficult without that relationship. I just sent back 3 orders of Travertine before I finally went and put my hands on the stone I wanted.......in stock somewhere.
Go put your hands on the stone you will lay. You should be able to tell which is the good stuff. In my experience, bad stone is like bad breath........very obvious. If you look at lots of different stock it should become clear which are the good ones. Consistent sizing, consistent color, lack of extreme veining.....those are a few things I look for.
Good luck......and good choice.
Old 12-23-2012, 11:36 AM   #36
Holder of hands
skcolo's Avatar
Trade: Custom builder/remodeler
The first cake of coke that some kid spills on the floor and etches it will make you regret putting marble in an entry, with kids, in eastern VA, by a river.
skcolo is offline
Old 12-23-2012, 11:42 AM   #37
Holder of hands
skcolo's Avatar
Here, buy one of these.
http://www.granitecitytool.com/clarke-floor-polisher
skcolo is offline
Old 12-23-2012, 12:26 PM   #38
SMLWinds's Avatar
Rewards Points: 25
Thanks for the responses.
BlueRidgeGreen--Do you have any places where you can reliable get good marble? You are about 2.5 hours from me so if you have a reputable person I should contact for a price quote please let me know. I have only gotten a quote from Best Tile in Richmond. Also will be checking Morris Tile in Richmond as well as L&M Tile in Mechanicsville. I'm getting them to price the tile from Stone Partnership, Inc in NJ. They are higher end for price but but all accounts seem more selective with their process. Unfortunately, I am not sure I am qualified to really tell the difference in grades of marble and figure out whether or not a few extra bucks is worth the upgrade. I'm sure I could see the difference between the worst and the best, but in the middle would probably be tough so I'll take all the help I can get.
skcolo--Thank you for your input. Yes, I might regret this. But, I haven't found porcelain that we love and we do love this SPI bianco carrara so I'd rather risk having to replace it down the road.
Are one of those floor buffers necessary/beneficial? If that is the best way to seal and protect the marble to give it the best chance of survival, I have no problem buying one. I guess that is what I have to learn about next--how to protect this floor as best I can and keep it looking good as long as it can.
Thanks again!
SMLWinds is offline
Old 12-23-2012, 12:40 PM   #39
Holder of hands
skcolo's Avatar
Thanks again!
Acually, I was being a little sarcastic. Some marble etches more than others, but it's all fairly soft. I have a Makita 7" variable speed grinder that works well for polishing small areas like an entry. There are buffing pads, polishing paste, and etching removers that you can get. Lots of youtube videos you can watch.
It's a little time consuming, but not too difficult. That's probably all you will need. Just know that lots of chemicals, even vinegar, will etch the floor instantly. Be careful what you clean it with, and how you use it and you will be fine.
skcolo is offline
The Following User Says Thank You to skcolo For This Useful Post:
BlueRidgeGreen (12-23-2012)
Old 12-23-2012, 02:25 PM   #40
Trade: Craftsman
Thanks again!
Unfortunately, this place is a vast, unforgiving desert when it comes to materials acquisition. I had a couple great ones back in NYC, but this part of Va has been tough.
I met a guy in Charlottesville a little while back who seemed like a real ace. He owns a place called Sarisand Tile, his name is Pete (i think). From what I remember he has a place in the Outer Banks too.
I have never done business with him, but I got a great first impression from him the day we met. His showroom was top-notch and I saw a bunch of pics of his tile and designs. Real nice.
As I'm typing, I'm wondering why I never got back in touch with Pete............I'm going to email him now.
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 12:14 PM
Different size tile in the same lot HandyHails Tiling 69 02-10-2011 08:40 PM
Porcelain Tile Porch jbtn9 Flooring 1 09-22-2009 03:45 PM
Porcelain Tile on a Wood framed Exterior Porch jmckay Tiling 5 09-21-2009 06:52 PM
Removing Porcelain Tile on Stapled and Glued Subfloor ParaDiddle777 Flooring 20 11-08-2008 09:48 PM
