Poor Tile Choice For Shower - Tiling - Contractor Talk
Old 08-05-2018, 02:16 PM   #1
AustinDB's Avatar
Rewards Points: 876
I'm on a custom high-end job where the designer chose the tiles throughout (4 showers). I've been able to make the others work out but the floor/ceiling choice for the master is a poor choice.
I think it's a marble about 1/2" thick but there is no room for grout between the two colored pieces. I threw out an option that maybe an unsanded grout MIGHT work but I really didn't think it would work or work well.
first, any opinion on making this tile waterproof for the shower floor?
second, what's a good thinset to attach this to the ceiling? it's much heavier than the typical tile I've been given for ceilings, I'm concerned about it coming down in the future. The backing doesn't allow for good penetration to the stone.
AustinDB is offline
Old 08-05-2018, 02:55 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,868
Re: Poor Tile Choice For Shower
Unsanded is standard for marble because marble can scratch with sanded grout. Hence the small grout lines.
Seal before grouting.
The shower should be waterproof before tile is installed.
You might benefit from premounting these on kerdi membrane so you can be sure you have good adhesion before mounting to the ceiling.
Half of all people are below average.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
greg24k (08-07-2018), TNTSERVICES (09-19-2018)
Old 08-05-2018, 02:58 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,287
An unsanded grout will work.
Ultraflex 2 should be fine.
You might want to make a clear mortar board with acrylic to help set them exactly where you want them.
MarkJames is online now
Old 08-06-2018, 11:36 AM   #4
Mr_Stop's Avatar
Rewards Points: 282
For what it's worth, I wish designers would actually install the tile the sell. It seems that they always choose the most expensive PITA tile to install. Hopefully you upcharged for this.
As others suggested, waterproofing actually happens underneath the tile.
Interesting thoughts about premounting on Kerdi Membrane. Mosaics often suck to get just right and this might be a good solution.
Mr_Stop is offline
Old 08-06-2018, 12:52 PM   #5
AustinDB's Avatar
Rewards Points: 876
The shower is defn waterproofed. Kerdi-Board on the walls and ceiling with a 68" linear drain on the floor.
I'll often install a piece of Kerdi behind my mosaics to build them out flush with the thicker field tile but will try to premount them on Kerdi, then install.
thanks for the tips, that was what I was looking for.
Regarding designers, this one missed the boat on a lot of details and it's frustrating. Fortunately the builder has confidence that I'll make it right.
AustinDB is offline
Old 08-06-2018, 08:04 PM   #6
tjbnwi's Avatar
Rewards Points: 5,400
Laticrete 254 Platinum for the ceiling.
tjbnwi is online now
Old 08-08-2018, 01:17 PM   #7
t.carpenter00's Avatar
Trade: excavating/ drywall/ currently remodeling
Rewards Points: 230
How do you use sanded grout on marble?
I've seen so many marble jobs in my area destroyed from sanded grout.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline
Old 08-08-2018, 06:11 PM   #8
tjbnwi's Avatar
Use epoxy or acrylic grout. DO NOT USE SANDED GROUT!!!
Old 08-08-2018, 06:19 PM   #9
Rewards Points: 230
I miss read one of the earlier posts. I thought someone said sanded grout will work. I couldn't wait to hear how that could be! Sorry guys.
Old 08-08-2018, 06:38 PM   #10
MarkJames's Avatar
Actually, there are a few seasoned tile pros that say sanded is fine.
If I had to do that for whatever reason, I'd polish out any fine scratches.
Old 08-08-2018, 10:26 PM   #11
Rewards Points: 230
I had to look at a new marble floor for some wealthy customers of mine that I do repair/maintenence for. They just had a new house built. Between the sanded grout and the harsh cleaners someone used... I told her that the only way I knew to fix it was to have it resurfaced. I have seen fewer scratches on a hardwood floor in a house full of dogs!
Old 09-19-2018, 11:10 PM   #12
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
You can use Mapei CQ on softer stone tile. The quartz is more rounded and doesn't scratch as easy. Also getting the tile damp helps with that as well as clean up.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 09-19-2018, 11:11 PM   #13
Hair Splitter
Trade: General
Rewards Points: 214
Mosaics always get premounted on our projects. So much easier to work with and cut.
Old 09-19-2018, 11:12 PM   #14
Hair Splitter
Trade: General
Rewards Points: 214
I would use Ardex 77 on the shower ceiling. Or Mapei UF3.
Old 09-20-2018, 06:41 AM   #15
Mr_Stop's Avatar
Rewards Points: 282
When you premount, do you mount to Kerdi-membrane using thinset, or another product?
Mr_Stop is offline
Old 09-20-2018, 07:29 AM   #16
Hair Splitter
Trade: General
Rewards Points: 214
Thinset
Wood choice for Board and Batten BlueRidgeGreen Windows, Siding and Doors 22 12-09-2013 05:16 AM
Any one have a good choice on a good Planer? Houston's Tools & Equipment 22 02-24-2011 10:40 PM
Dealers Choice? Holman Off Topic (Non Trade) 9 01-02-2011 11:59 PM
Software Choice - IMHO hennel Accounting Software & Discussion 0 12-19-2010 04:19 PM
cabinet paint of choice world llc Finish Carpentry 8 12-31-2008 08:43 PM
