Polishing Out Scratches In Natural Tile
Old 01-29-2011, 06:08 PM   #1
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
I got a call earlier this week from an existing customer who had me install 12x12 travertine throughout her first floor. She had a new stove and fridge installed and the goober who put them in put some pretty deep gouges in the tile especially in front of the stove. The fridge wasn't too bad because of the plastic casters, but there were a bunch of fine scratches.
Anyway I assured her I could get the scratches out. My normal method is to get out the ROS and start w/ 80 grit and work my way up to 220 and then hand sand the dull area w/ 320, 400, and lastly 600. This is for honed and filled. Generally this matches up pretty close to the original finish from my supplier.
What I'd like is to find some sandpaper for my ROS (5" 8 hole), that runs up to the needed 600 grit or even higher if I'm running polished.
I think Mirka goes up to 320 if you order online. 400 for 5 hole sanders.
Anyone have a line on the finer grits for ROS w/ holes so I can use a vacuum attachment? I've been looking for a while and I've come up dry.
Also interested in any more effective methods if you've come across any.
Thanks
Josh
hhicontracting.com
HandyHails is offline
Old 01-29-2011, 06:15 PM   #2
astor's Avatar
Trade: FI
Rewards Points: 704
Re: Polishing Out Scratches In Natural Tile
Thanks
I have looked hard for those when I was making a bird cage with acrylic. Ended up using 400 and 600 paper attached to sanding block and some elbow grease. Would be nice if someone has source.
if you can not find,Novus makes "heavy scratch remover" and "fine scratch remover" lotions to eliminate scratches. I have used them over acrylic and stainless steel and have great results after 400 and 600 grit. I assume it will work with travertine, but test before of course.Check with your local plastic sheet supplier.
astor is offline
Old 01-29-2011, 06:33 PM   #3
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
I've been going round and round about buying the Makita buffer. I've never tried truly buffing out any scratches w/ this, but I suppose it would work. Of course I could get the solid sanding pad w/ no holes, but they would make a fair amount of fine dust and most after 400 are made for wet sanding.
Josh
hhicontracting.com
Old 01-29-2011, 06:37 PM   #4
astor's Avatar
Trade: FI
Rewards Points: 704
Yeap, wet sanding with 400 and 600. Lotions work like 800 and 1000 (my guess)Plastic guy was using 400 in his shop, but I did not asked where he got it.
astor is offline
Old 01-29-2011, 07:04 PM   #5
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Here you go. http://www.leevalley.com/en/wood/pag...71&cat=1,42500
katoman is offline
Old 01-29-2011, 07:04 PM   #6
3bar's Avatar
Trade: carpenter
Rewards Points: 416
can you hide the scratches by making them look "wet" with a sealer or something?
i use diamond pads like the granite guys use, for doing touchups and whatnot on stones.
search "diamond polishing pads"
3bar is offline
Old 01-29-2011, 07:11 PM   #7
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
Handy,
Here's my experience with this since I used to work with acrylic...
Wet sand by hand with aluminum oxide sandpaper, go in the direction of the scratches. 600,800,1200,2200
Then I would use a buffer with a standard sponge pad. We used to use a car polish (name unknown) but there was a pink and blue... rub the compound over the area, let it sit for a minute and buff with a dry pad(place pad on product before you turn it on). The compond had a little bit of grit so it would finish sand and polish simultaneously.
Give it a shot on a scrap piece of travertine...
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 01-29-2011, 07:28 PM   #8
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Rewards Points: 1,028
I'll tell you as the greatest ancient secret
Cook beeswax, oil and turpentine in equal parts .. rub on the scratches, heat with heat gun for penetration... and buff .. just do not tell for anyone..
Resta is offline
Old 01-29-2011, 07:38 PM   #9
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Originally Posted by katoman View Post
I love you man.
That's exactly what I was looking for!!
Josh
hhicontracting.com
Old 01-29-2011, 07:41 PM   #10
katoman's Avatar
Trade: carpenter
I love you man.
You're welcome
katoman is offline
Old 01-29-2011, 08:21 PM   #11
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Originally Posted by astor View Post
What are you keeping in the cage? I've got 6 finches in the biggest cage I could find w/ small bars. Hows cleanup for you?
Josh
hhicontracting.com
Old 01-29-2011, 10:34 PM   #12
astor's Avatar
Trade: FI
Rewards Points: 704
I got two Apricot Canaries. Before I used to keep them in this cage, but I had to keep the room door closed all the time (because of the cats), they need humans I guess, were not too happy, so now the cats learned they can not get them, birds are much happier.Move them into FR, we enjoy more and see them all the time.
Cleaning is the most easy job ever now.No seeds on the floor, nothing sticks to acrylic.just paper change every 4-5 days
astor is offline
Old 01-29-2011, 10:40 PM   #13
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
What kind of oil?
My [IMG]http://**********************/forums/images/smilies/images.jpg[/IMG]
It might be a big bitch trying to match the polish on the rest of the stone. Be careful you don't end up having to polish the entire floor.
Angus
angus242 is offline
Old 01-30-2011, 07:35 AM   #14
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Nah, it hasn't been bad at all. Get it to 600 and its fine after a good seal. Travertine has so much difference in the tiles that when your talking honed and filled, its just a matter of making sure you get the whole tile that you are working on and reseal. GTG.
Astor,
Love the canaries. For us it was between a group of finches and a pair of canaries. The finches won out mostly on price, but also because of the cool socialization they have w/ one another. I bet the acrylic cage was a lot of fun to dream up and implement. Looks good.
Josh
hhicontracting.com
Tile Installation Failures in a High End Remodel ChrWright Tiling 139 03-04-2013 06:28 PM
New tile and remodel guy to CT tile9 Introductions 8 10-02-2010 03:06 PM
Tile Flange moves the wall! Neoshade Remodeling 13 07-24-2010 05:29 PM
Removing tile that is set under base cabinets.. bujaly Flooring 43 03-13-2010 05:15 PM
Tile job goin sour, what to do ? mendelectric Tiling 64 08-19-2009 03:49 PM
