polishing granite saw cuts
This is probably a really simple question, but I would like to polish my saw cuts on granite to be approximately equivalent to the polish of the finished surfaces of the granite. How is this done, preferably quickly and cheaply? I'm tempted to use a belt sander or even a buffing wheel. Please specify both the grit size sequence and the type of grit prefered.
Thanks in advance. The pieces I'll be polishing will probably be as large as 8" x 3" X 1" at the most, so easy to handle. I don't expect to do larger slabs.
I'm getting decent but not polished saw blade cuts, so hopefully I won't need to go real low.
Ken
