Trade: electrical contractor; complete remodeling
Polishing Granite
I recently had a granite top installed and the customer is complaining about a small spot that is not at shiny as the rest. It is an area about 5" in diameter. Tried unsuccessfully to fix it. Polished with rubbing compound..no good. Polished with wet diamond grinder pads to 5000 grit.. no good. let new sealer soak in for 30 min..no good. Any ideas on what to try next?
Tile Contractor
Re: Polishing Granite
Some spots won't polish, it's not in their molecular character.
Probably embedded slag.
Not sure if this is it. The area that needed to be addressed was about the size of a silver dollar. Now after "fixing it" the same effect is 5" in diameter.
Steve
Trade: Remodeling and Custom Cabinets
My granite sub will use superglue to fix areas, they drop it on, let it dry then scrape it level with a razor blade. A bit of polish to the area. Looks good and seems to last, no call backs.
Tile Contractor
Probably a subsurface imperfection that gets bigger the deeper it goes - who knows?
I wouldn't keep screwin' with it.
I think I solved this issue. I only had grinding wheels up to 5000 grit. A factory finish is more polished then this. I needed three more steps. Also I used a flexible backer on the wheel. I needed a stiff one to be sure no swirls are left. (easier to be sure the grinding is perfectly flat). First polish with a black grit pad which is 8500 grit. Next use a buffing pad and tin oxide. Next use a stone enhancer, the granite sealer I was using does not add the dark shine I needed.
Thanks for your help and ideas. |
classic muscle
Trade: General Contractor Tile Contractor
I've had that problem before. If you have some StoneTech Enhancer in the shop, try that localized to the problem area. Give it a chance to saturate, perhaps 3 coats and see if it progresively gets better. It just may be the stone that was in the ground and doesn't like to be polished, but really rare.
| My fault or the granite guy's? | john elliott | General Discussion | 86 | 01-17-2011 03:48 AM |
| What’s Lurking in Your Countertop? | wallmaxx | General Discussion | 13 | 07-31-2008 06:06 PM |
| Granite Shower | Ramblinwreck | Remodeling | 3 | 01-01-2008 08:27 PM |
| Cutting & polishing granite | plazaman | General Discussion | 4 | 01-12-2007 06:14 PM |
