Trade: Jack of most
Not Sure How To Set Tub Deck Trim Piece
The customer wants a marble subway type tile on the side of the jetted tub enclosure. The tub deck is the same material. He picked a piece of 2x12 trim that is also marble to go around the entire corner/edge. It projects out about an inch and a half at the top and then comes back in at the bottom to meet the tile.
Seems to me that this part of the project will see some stress from getting in and out of the tub and I'm thinking I should use an adhesive of some kind rather than mortar. Any ideas on how to install this trim piece?
MarQ Remodeling (no website) |
tile mason
Re: Not Sure How To Set Tub Deck Trim Piece
Ensure your framing around tub deck is secure and sturdy. Then use 1/2" DensShield (water-resistant) as a backerboard. Mix some thinset and tile as you would any wall. There really is no "stress" involved except cleaning your tools and organizing your van.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
tile contractor
Carl, I take it this is a piece of tumbled marble chair rail? Whether it is or isn't, thinset will be much stronger than any mastic ever could be.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
Trade: Jack of most
Ok. I would have thought a construction adhesive was a proper method for fastening. It is a type of chair rail...not tumbled...but still marble. Probably about 2 inches tall. I actually have Durock all around.
I'll go with the thinset. Thanks.
tile contractor
The durock will be perfect, and the very LAST thing you want to use is construction adhesive. Use a high stgrength latex modified thinset, something like Laticrete's 254, or Hydroment's Reflex. Or, you could go the route of using an unmodified thinset mixed with a liquid latex additive. Either way, you'll end up with a good strong bond.
#6 | |
tile mason
Re: Not Sure How To Set Tub Deck Trim PieceQuote:
Home Depot sells bags of Custom Blend for 5 bucks. And get you some laytex additive (we call it "milk") to cut it with, instead of mixing with water.
tile contractor
That'll work-- either the Custom Blend or the Master Blend, mixed with their additive.... FULL STRENGTH, not cut with water.
| Used the new Correct Deck CX-personal review | IHI | Decks & Fencing | 22 | 07-27-2008 09:52 PM |
| Correect Deck ?'s Robert and others | IHI | Decks & Fencing | 9 | 05-21-2008 10:45 PM |
| Ipe Deck | rjordan392 | Decks & Fencing | 19 | 10-10-2007 10:58 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Dry lower deck stuff | frostyfrost | Decks & Fencing | 12 | 05-19-2007 07:59 AM |
