Niche Idea
Old 09-07-2017, 10:02 PM   #1
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 506
Niche Idea
I have a client that wants a very clean niche with minimal corners and easy to clean but still needs to have some shelves. I have 48" tile available to use so I can make it as big as I need. I am thinking of taking the porcelain and making a large niche. For the shelves I would use glass. My idea is to drill shelf pin holes in the sides and use a stainless pin with a vinyl cover for the glass. This way the glass can be removed for cleaning and the niche is easier to clean. How can I drill the holes precisely and cleanly? I haven't had the best luck with the small diamond core bits in hard porcelain. Can a water jet be that precise?
Sent from my SM-T310 using Tapatalk
overanalyze is online now
Old 09-07-2017, 10:57 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 92
Send a message via Skype™ to jlhaslip
Re: Niche Idea
How are you going to deal with the water that gets in the holes?
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
TNTSERVICES (09-27-2017)
Old 09-07-2017, 11:17 PM   #3
Always Learning
Rewards Points: 506
Re: Niche Idea
Either not drill all the way through the tile or kerdifix/wedi sealant in the shelf pins. Don't we always preach the waterproofing matters and the tile if just the facade...lol! Seriously though I don't think the holes would be an issue...
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
A&E Exteriors (09-08-2017), TNTSERVICES (09-27-2017)
Old 09-07-2017, 11:29 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,291
Re: Niche Idea
Tempered glass, hopefully. That sounds like it would need more cleaning than the rest of the shower.
How about setting a couple marble shelves instead? Ease the edges, maybe.
MarkJames is offline
Old 09-07-2017, 11:34 PM   #5
Always Learning
Rewards Points: 506
Re: Niche Idea
Tempered for sure!
Old 09-08-2017, 10:52 AM   #6
VinylHanger's Avatar
Rewards Points: 7,048
Re: Niche Idea
I would probably epoxy some nice tile supports. How often are they really going to adjust the shelves once they put stuff on it.
Like you said, drilling tile is a pain. You might even get most right, but it only takes one miss and you are starting over.
Is there such a thing as cnc for tile. You could take your side pieces and have them jigged up and cnc drilled, then you just need to set them parallel.
Or you could have small glass panels drilled at a glass shop and inset them into the niche sides.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
overanalyze (09-08-2017)
Old 09-08-2017, 03:33 PM   #7
Hack
asevereid's Avatar
Rewards Points: 228
Re: Niche Idea
I don't do much tile work... Let alone showers ; but would a wide pencil trim be sufficient for supporting the shelves?
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 09-25-2017, 11:21 AM   #8
Always Learning
Rewards Points: 506
Re: Niche Idea
Had an aha moment...going to propose a CRLaurence slotted glass shelf support. Clean and simple to install.
Sent from my SM-G920V using Tapatalk
TNTSERVICES (09-27-2017), Xtrememtnbiker (09-25-2017)
Old 09-25-2017, 10:45 PM   #9
AustinDB's Avatar
Rewards Points: 526
Re: Niche Idea
bet you a dollar Schluter makes some sort of trim for what you're asking for.
I don't understand why you want to remove the shelf, does it have to have the ability to be removed for your design?
hope the picture shows up, maybe that kind of design will work for you. It's a recent niche I built with 12x24 tile and everything had a demi bullnose applied and polished. It was good quality tile, not sure how it would have turned out with tile that didn't have good color throughout the tile.
AustinDB is online now
The Following User Says Thank You to AustinDB For This Useful Post:
overanalyze (09-25-2017)
Old 09-25-2017, 10:50 PM   #10
AustinDB's Avatar
Rewards Points: 526
Re: Niche Idea
the Schluter Dilex-BWB may do what you are looking for. it's not surface mounted but being creative you could come up with something. That rubber piece in the center of the profile is removeable.
(https://www.schluter.com/schluter-us...WB/p/DILEX_BWB)
Old 09-25-2017, 10:50 PM   #11
Always Learning
Rewards Points: 506
Re: Niche Idea
She wants glass shelving and for it to removable for cleaning. Also for the glass to be away from the sides and back so as not to create an inside corner with caulking that needs cleaned/maintained.
Old 09-27-2017, 06:09 PM   #12
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,912
Re: Niche Idea
When you install a glass shelf you typically sandwich it between to tiles...that split tile is a hole lot more real estate for water getting in that some holes in the tile. Proper water proofing and as he mentioned filling with silicone or other waterproofing would suffice.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
The Following User Says Thank You to TNTSERVICES For This Useful Post:
overanalyze (09-27-2017)
Old 09-27-2017, 06:11 PM   #13
Hair Splitter
Trade: General
Re: Niche Idea
You can run tiles through a water jet cnc. I don't think they want to adjust, just be able to remove the shelves for cleaning. Any epoxied supports would be more of a dirt and grim catcher than pins.
The Following 2 Users Say Thank You to TNTSERVICES For This Useful Post:
overanalyze (09-27-2017), VinylHanger (09-27-2017)
Niche build custom size different backerboards gowings Tiling 7 06-01-2016 07:04 PM
Facebook marketing idea I just saw oktex56 Marketing & Sales 1 08-25-2012 10:19 PM
Footing Idea ? dproc Decks & Fencing 17 08-15-2012 07:24 PM
open minded customer likes counter top idea but not sure if it will work Randal Kitchens & Baths 3 11-28-2011 03:31 PM
Are all-in-one web solutions a good idea? cbscreative Websites and SEO 5 03-10-2010 09:05 PM
