New "rules" For Laying 12x24 Tiles From Olympia Tile
Old 10-10-2011, 08:52 AM   #1
bathroom guru
jarvis design's Avatar
Rewards Points: 560
I was in Olympia Tile this week with a client picking tile for her bathroom. I asked one of the sales people for a sample board for some 12x24 tile and he handed me a sheet showing the recommended ways to lay the tile (I'm referring to layout, not actual setting).
And, btw, these tiles were going to be installed on the wall, which I normally install like subway tile - half bond
The sheet showed two acceptable ways:
Stacked - all grout lines "line" up and a 70/30 bond install.
On the bottom they show a half bond installation and it is NOT recommended.
I asked why and was informed that 12x24 tiles are warped and installing them half bond style will result in lippage.
Hmmm, I've done quite a few jobs using 12x24 tiles from olympia, always installed them half bond, never a problem. I did however run into this issue with some 10x16 tiles from olympia last fall and, after losing a couple of days and driving to Toronto (going through 20 pallets of the same tile which were ALL warped) ended up switching tile.
I'm assuming Olympia now has a LOT of warped tile in stock and this is their answer to the problem.
Anyone else ever run into this?
Oh, they also have a 24x48 porcelain tile...makes me wonder how flat it is!
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
Old 10-10-2011, 10:09 AM   #2
Remodeling GC
kevjob's Avatar
Rewards Points: 4
Re: New "rules" For Laying 12x24 Tiles From Olympia Tile
I have seen some 12x24's that are straight as an arrow and some not so much.
When i deliver tiles I check them and then have the tile guy check them and if they are too warped we bring it to the attention of the client and would recommend a straight lay.
I havent had a job yet where we couldnt do running bond.
Kevin
www.ObrienConstructionDenver.com
kevjob is online now
Old 10-10-2011, 10:27 AM   #3
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
The new spec is an industry standard.
Across the board and relates to all large format tile.
JW
JohnFRWhipple is offline
Old 10-10-2011, 10:45 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
The TCNA endorses the same methods that Olympia Tile is recommending.
Angus
angus242 is offline
Old 10-10-2011, 10:51 AM   #5
bathroom guru
Rewards Points: 560
John and angus, thanks for the heads up!
www.ExpressBath.ca
519-495-4062
Old 10-10-2011, 10:55 AM   #6
bathroom guru
Rewards Points: 560
I'm guessing the moral of the story is that manufacture's have not figured out a way to produce flat tiles consistently?
www.ExpressBath.ca
519-495-4062
Old 10-10-2011, 10:58 AM   #7
ee3's Avatar
Trade: membranes and shower products
Rewards Points: 192
that is correct Mr. Wipple!
It is one of the things that the Contractors group was pushing for .With a 50% off set it puts the low ends to the high warp..*(or versa visa) Its ment to be one of those items that you can point out to Specifiers that it MAY NOT WORK with a 50% off set.(for warned)
ee3 is offline
Old 10-10-2011, 11:14 AM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Yes, I was at a conference with Gerald Sloan and Eric Astrachan from the TCNA which basically said that. The larger the tile, the harder it is to get them flat.
Angus
angus242 is offline
Old 10-10-2011, 11:31 AM   #9
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Originally Posted by ee3 View Post
(for warned)
lol. Now ya tell me. I called that "cuppage" (cup meets lip) and when ya roll something across it, it thunk thunk thunk. Some folks didn't mind it, just like some folks like ungauged material.
CO762 is offline
Old 10-10-2011, 12:23 PM   #10
that is correct Mr. Wipple!...
W.H.I.P.P.L.E. Whipple with a "H"
Eric what is the heat rating of Noble Seal TS for steam showers?
Old 10-10-2011, 12:30 PM   #11
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
He's just getting you back for all the Nobel you posted
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
JohnFRWhipple (10-10-2011)
Old 10-10-2011, 02:13 PM   #12
Old 10-10-2011, 04:01 PM   #13
ee3's Avatar
Rewards Points: 192
I only allow myself so many key strokes a day and thought I could save 1 but No...H .back to even.
ee3 is offline
Old 10-10-2011, 04:35 PM   #14
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
I would just let the customer know and give them the option... either way the floor/wall will be wavy
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 10-10-2011, 06:29 PM   #15
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Why can't they grade them accordingly? Depending on desired layout choose appropriate grade. To hard on manufacturer?
Make setters job more difficult me thinks. Pass the buck as usual..
I dug through a bunch of 6's last week to get consistent tile. They really were that bad.
JHC is offline
Old 10-10-2011, 06:34 PM   #16
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I believe the kiln process warps the tile. The larger the tile, the more warping occurs.
Angus
angus242 is offline
Old 10-10-2011, 08:34 PM   #17
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
i just finished up a 12 x 24 with 50% and had no problem at all. it was florida tile. i'll snap a pic and post it tomorrow
world llc is offline
Old 10-11-2011, 06:45 AM   #18
world llc's Avatar
Looks flat to me
New "rules" for laying 12x24 tiles from Olympia Tile-forumrunner_20111011_074356.jpg   New "rules" for laying 12x24 tiles from Olympia Tile-forumrunner_20111011_074428.jpg
Old 10-11-2011, 07:40 AM   #19
Aaron Tritt's Avatar
Trade: Tile Installation
Rewards Points: 150
I have found that taking a 2' to the tiles before a decision is made can give me a good answer. It clearly shows if there is cuppage or not. The tile that I come across this most with these days is a rectified 12x24 with a grain that looks like paint. They are always cupped.
Also, since the TCNA handbook said that 30 percent offset is recommended, I do that. I tell the customer that I can do the 50 percent, but there will probably be lippage.
Nice floor above World!
Aaron Tritt
Custom Expressions LLC
Insured, NTCA Member, BBB accredited
Aaron Tritt is offline
The Following 2 Users Say Thank You to Aaron Tritt For This Useful Post:
world llc (10-11-2011)
Old 10-11-2011, 12:06 PM   #20
GO Remodeling's Avatar
Rewards Points: 96
Aaron, that's a great way to check your tile. I used it on some 4x36 and found 3/16 curvature from the center point. Had to change the layout to prevent "washboard" look. Never hurts to check.
GO Remodeling is offline
Question for the tile & carpet Guru's RocknTJ Flooring 15 08-11-2011 09:01 PM
Experienced Tile Contractor Call Back plumoutasight Tiling 12 08-10-2011 01:15 PM
Laying new tile on top of existing tile?? Bergmeister Tiling 10 05-17-2011 09:02 PM
Tile Over Gypcrete Golden Rule Tiling 6 11-26-2010 03:00 PM
Need help with a tile Floor Docwhitley Tiling 1 07-19-2010 12:19 AM
