New Ridgid Wet Saw
Old 11-07-2009, 08:56 AM   #141
DI Restoration's Avatar
Trade: Restoration
Re: New Ridgid Wet Saw
Review-
We have 2 Dewalts and now one of the new Rigid's. My tile guys are fighting over who gets to leave the Rigid on the side of the road.
DI Restoration is offline
Old 11-07-2009, 05:49 PM   #142
Its all ball bearings
angus242's Avatar
Trade: Tile
Originally Posted by DI Restoration View Post
Review-
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
Old 11-09-2009, 01:14 AM   #143
Target's Avatar
Originally Posted by Bill_Vincent View Post
Actually, it's very easy to adjust for height. There are 4 bolts that hold the clamps in place on a rod that the whole motor and blade head assembly sit on. You might have to use some WD 40 and a good ratchet and 12 point socket, but it'll loosen up and you'll be able to adjust the head.
(I've also got one of the older Targets)
Thanks, Bill, for the advice. Yeah, I noticed 4 bolts under the motor stand. I will give it a shot. By the way, Husqvarna unit has a torsion spring for easier height adjustment. Very nice! I noticed that locking knob for height adjustment is missing on my target. Know where I can purchase a cheap replacement? The blade that came with it is DeWalt diamond blade. It still has some left and I was told it's new. Should I bother replace it with a better quality cutting blade? I will be cutting a lot of thin granite tiles for my next project.
And for bullnose miter, I will need to get one that will work on my Target. Any suggestion on where I can buy one? I thought about making one out of wood.
Bill, I saw your website. Very nice tile work.
Target is offline
Old 01-15-2010, 07:21 PM   #144
Floor Artist
CapstoneMan's Avatar
Trade: Custom floor Artist
ok, I read this thread before buying my Ridgid tile saw (newer one) I knew what I would be getting into. I also figured I could return it for my money back. ok, my ultimate opinion, dont waste your time. I built a 3x6 shower with bullnose. This was the biggest waste of time working with this saw. It has a lot of pretty things on it and they would be great if the dang saw would cut a straight line. The first 20 cuts or so were great. Then they started getting bad. So I had a new 75.00 balde ready to go. Got it put on and the same thing. Took about an hour and adjust every thing. Cut decent the rest of the day. The next day we set it up, from where we left it the night before, about 3 feet total moved. We made the first cut and it was off again. Had to readjust. Then it got just plain silly, the lock for the plunge cuts would not stay, it kept rising up. Then the ports on the water were getting clogged from the slurry drying. IT was one thing after another. I am taking it back on Monday to get my money back. What a POJ. I did like the laser but it made a straight line and the saw was cutting curves in the tile by the end of the week. I liked the blade lock and I liked the way water was in the bucket on the bottom of the stand thus lowering the center of gravity. No more ridgid tools for me again. should have known.
CapstoneMan is offline
Old 01-18-2010, 01:43 AM   #145
rossi inc.'s Avatar
Trade: carpentry,electrical,plumbing,tile&stone,painting,
check out the MK TX-3it is one bad mf will love your job again!
rossi inc. is offline
Old 01-19-2010, 08:27 PM   #146
Master Tile Mechanic
Kyras's Avatar
Trade: Tile & Stone
I use the Dewalt all the time and I love it. The design of the saw is the best I've used, although it's noisy compared to MK. I do use an 8" blade though, to keep the flex of the 10" blade down (porcelain tends to drive it around and make it hard to make a straight cut, but that's true of any 10" that I've used, even the "stiff cores"). The 8" cuts down on the visibility unfortunately, but I find it's worth it for a straight cut.
Kyras is offline
Old 09-30-2010, 04:56 PM   #147
Jake D.'s Avatar
Just bought this new tile saw (they named it the Beast) and its a disaster. The cuts are arched! yes, arched. Never mind cutting square, this saw wanders to one direction and then returns to original width resulting in a slightly curved cut (approx 1/16th on a 13" tile). Called Ridgid tech support and they had no clue. I reexamined the machine and noticed that the motor assembly is not rigidly connected to the large arm that supports it. There is quite a bit of play where the assembly is connected to the angle cut control section. I could find no adjustments that will change the situation. How can you make a saw with a wobbly cutting head and no possible way to tighten it????????????? I think that this is a case of bad engineering and I am taking it back to HD. I am not going to waste another hour reassembling a new unit which will probably have the same problems. I suggest to anyone considering this purchase to think again and buy another brand....I like ridgid but they do screw up from time to time....this is not the first product that they screw up.
Jake D. is offline
Old 09-30-2010, 05:36 PM   #148
Wood Craftsman
PrestigeR&D's Avatar
Exclamation
did you use.. if it's ridgids... throw it out...
PrestigeR&D is offline
Old 09-30-2010, 08:46 PM   #149
Jake D.'s Avatar
As far as the blade goes, I have the same Ridgid blade on my MK100 and I have had no similar problems. I believe the issue is a result of the whole cutting apparatus (blade, motor and motor angle adjuster) not being firmly attached to the arm. If the motor can move upwards and wobble slightly sideways while cutting it will make for a non linear cut, period!
Jake D. is offline
Old 10-02-2010, 10:02 AM   #150
CO762's Avatar
Trade: Remodel
Originally Posted by New Generation View Post
the direct drive motor found on dewalt and ridged will fail...
when the direct drive fails you might as well throw the whole thing in the trash
When one of my bud's dewalt's motor finally broke (his kid kept running it dry as the pump would twist), gave it to someone else and he took it to a dewalt service center. There, they completely rebuilt it and the max it costs is $400.
He said everything was new on that saw except for the frame and pans.
Not a bad pickup for 4 bills.
As an earlier posted stated, it's all a "trade off". On a large commercial job with thick, hard material, hard to be a target, and for larger granite pieces, say a bridge saws. (for me) on most other jobs though, hard to beat a dewalt due to speed/ease on large projects (say hospitals/hotels) due to the ability to go from room to room with the saw on a wheeled cart.
Everything's a trade off.
CO762 is offline
Old 10-02-2010, 06:10 PM   #151
CO762's Avatar
Trade: Remodel
I've been thinking about picking up TM-75 for jobs where the Supertilematic is overkill (like MOST of em). Guess I'd better get it done!
the only time the Target will come out is when it's needed, and that's rarely-- like maybe 20% of the time.
On the bridge forum you adamantly kept stating how the dewalt is only for "homeowners" and that real "full time tilemen" wouldn't use it and use a target.
Yet 80% of your work your target isn't needed for?
And you're going to pick up a $300 homeowner/handyman saw, one with far less capability than the dewalt?
That's interesting.
CO762 is offline
ridgid 10" tablesaw P construction Tools & Equipment 25 01-19-2010 10:11 PM
Ridgid Portable Table Saw--feedback dougchips Tools & Equipment 12 07-19-2007 09:37 PM
DeWalt, Bosch, Ridgid Hurley Tools & Equipment 24 02-02-2007 09:54 PM
New Ridgid rayh78 Tools & Equipment 2 08-10-2006 06:20 AM
milwaukee hole hawg or ridgid r7130 drill?? ko_jun Electrical 10 07-28-2006 11:54 AM
