Need A Half Inch
Old 04-03-2008, 06:38 PM   #1
G-Build's Avatar
Need A Half Inch
Customer wants a level transition to carpet, so i need to bring up the tile [12x12] by half an inch. The floor is a concrete slab thats sealed and in good condition. No cracks or moisture problems. The area is 175 sq ft in a finished basement. I planned on using Ditra. Any suggestions for the 1/2" build up?
Gary.
G-Build is offline
Old 04-03-2008, 07:26 PM   #2
R&D Tile's Avatar
Trade: Tile installations
Re: Need A Half Inch
First, you need to remove the sealer, mechanically, no chemicals.
R&D Tile is offline
Old 04-03-2008, 08:06 PM   #3
Doofenshmirtz Evil Inc.
JumboJack's Avatar
Gary.
How about putting down cement bord first?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 04-03-2008, 08:15 PM   #4
Brock's Avatar
Trade: Residential Remodeler
Gary.
What's under the carpet that is making it a full 1/2 inch higher?
Brock is offline
Old 04-03-2008, 08:16 PM   #5
Brock's Avatar
Can you please explain the procedure for that process?
Brock is offline
Old 04-03-2008, 08:27 PM   #6
Tile Contractor
Bud Cline's Avatar
Forget it Brock, cement board on concrete is never a good idea.
Actually the carpet will of course naturally crush when walked on at the transition and the tile will easily come up to just under 1/2" anyway. I don't see the problem with leaving everything as-is. If cracking concrete is an issue then DITRA at 1/8" would also work out fine.
Customers must understand that a transition of tile flushing up with carpet just ain't gonna happen.
Bud Cline is offline
Old 04-03-2008, 08:35 PM   #7
send_it_all's Avatar
http://www.blanke-co.com/index.php?id=156
You might find some of these items helpful.
send_it_all is offline
Old 04-03-2008, 09:01 PM   #8
JumboJack's Avatar
Well you could screw it down.Granted that would be a PIA.Also you could try a P.A.T..
He wanted a way to get 1/2"..That was one way.
Old 04-03-2008, 10:33 PM   #9
Brock's Avatar
It was a joke. I can't imagine there is a hack alive that would try such an idiotic idea. My post was just a stab at sarcasm. It shows that there really are people in the field installing that shouldn't be.
Brock is offline
Old 04-03-2008, 10:36 PM   #10
genecarp's Avatar
confused by this thread
genecarp is offline
Old 04-03-2008, 10:37 PM   #11
genecarp's Avatar
1/2'' notched trowel wtf
genecarp is offline
Old 04-03-2008, 11:01 PM   #12
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Yeah I hear them Tapcons work really great for that....
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 04-03-2008, 11:20 PM   #13
Knowledge Factory
Floordude's Avatar
Your fixing to mess up big time!! The carpet needs to be higher then the tile, to some degree!! If not, your going to have a tile edge that is going to get abused and if it is a cut edge, will it be sharp and cut there foot, that is if your not using a metal edge profile??
Ditra will be all you want to go, if that, or your going to be ramping up under the carpet because the tile sits too high.
http://www.AustinFloorguy.com
Floordude is offline
Old 04-03-2008, 11:25 PM   #14
arconstruction's Avatar
Trade: Full service design and build renovation contractor
i can tell u dont know this so dont try it hire a tile guy to "WET SET" the tiles with a cement ....This is a proper method and is the mix is the correct mixture it will come out purfect expect to pay $5-7 persqft ....this is how marble and stone that are rough are set ...
http://www.arconstruction.us
arconstruction is offline
Old 04-04-2008, 08:58 AM   #15
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Now what would stop a guy from thinseting and then installing 1/2 underlayment with tapcons on a concrete floor if he really wanted to do it?
Mike Finley is offline
Old 04-04-2008, 12:50 PM   #16
G-Build's Avatar
To a select few. Just because someone asks a question doesn't mean they don't know what their doing. Moms didn't teach us condesending sarcasm was how to make freinds. [sorry... my ex always said i was to sensitive].
Anywho... The carpet going down will be berber over a quality padding. Very limited crush. So there CAN be a smooth transition using an edge profile. I was just wondering if there was a product out there that didn't require mechanical fastening. A thicker version of Ditra? I thought i saw a post that mentioned something like this.
G-Build is offline
Old 04-04-2008, 03:27 PM   #17
Knowledge Factory
Floordude's Avatar
Anywho... The carpet going down will be burber over a quality padding. Very limited crush.
The quality pad does not even come close to being in the thickness equation.
You have a 1/4" if that of tackstrip thickness, not the padding, to figure. Loop pile carpets, Berber as you are calling it, are very thin in profile height. The carpet does not butt to the tile. It gets tucked or rolled along the edge.
When tiles are set upstairs on wood, with CBU, I'm ramping under the carpet to raise it.
Old 04-04-2008, 09:11 PM   #18
Brock's Avatar
common sense.
Obviously a guy could do it. There are ways to fasten just about anything to concrete. The correct way to add height to concrete is more concrete or compound.
Brock is offline
Old 04-05-2008, 09:13 AM   #19
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Not for nothing, but I've used as big
as a 1/2" wide by 3/4" deep notched trowel for large format tile.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 04-05-2008, 11:41 AM   #20
Railman's Avatar
Trade: Railing
I highly recommend listening to FLOORDUDE! All of his points are a matter of fact. He knows flooring.
1)You definitely want the carpet to be a little proud of the hard edge on the tile. If carpet is not proud at least 3/16" or so, it'll be a toe buster, or at least uncomfortable when stepped on.
2)There is no pad under the carpet at the transition...usually just a 1/4" tackless, with tucked edge.
3) Tile will be in the range of 3/4" +-
4) Carpet will be 1/4" (tackless) + 3/8? = 3/4" +-
If anything the carpet will need to be raised!
Funny thing is, I was recently in a home where the HO just finished his basement, & had the same transition at a wet bar. His problem was that the tile was above the carpet (berber) about 1/8" in a few spots, & was trying to figure out what to do with it. His main concern was stubbed toes, & tripping! Leave the carpet proud!
Joe
Railman is offline
Three inch drain pipe. AbeBarker Plumbing 28 12-31-2007 08:01 PM
Concrete backer over 1/2 inch subfloor jim20 Ceramic & Stone Tile 4 08-01-2007 11:22 PM
6 Inch Block Garage Foundation????? fortstowe Masonry 26 07-01-2007 08:56 PM
By the inch? illya_allman Welding & Steel Trades 3 03-27-2007 09:23 AM
Main beam sagging 1/2 inch? AllGoNoShow Construction 10 10-12-2006 08:20 PM
