Nailing Hardi W/ Roofing Gun
Old 02-11-2008, 06:18 PM   #1
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I just nailed 300 sg ft of hardi and I had about 50 to go and realized I had a roofing gun in the trailer and would have saved so much time. I was wondering if any of you guys use roofing guns with galvi nails when installing large amounts of backer.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 02-11-2008, 06:23 PM   #2
Re: Nailing Hardi W/ Roofing Gun
I don't think I'd be confident of
electro-galvanized (phony-galvanized)
with thinset.
neolitic is offline
Old 02-11-2008, 06:24 PM   #3
orson's Avatar
Trade: Kitchen & Bath
I did it on my kitchen floor, worked pretty well but i had to go back and set a fair number of nails, still saved time.
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 02-11-2008, 06:27 PM   #4
Sharp Improvements
Was you pressure too low or shot at an angle or just heads not sinking or or or...
Norman Sharp
Old 02-11-2008, 06:28 PM   #5
Sharp Improvements
with thinset.
Good point. Some more research needs to bo done on this issue.
Norman Sharp
Old 02-11-2008, 06:58 PM   #6
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Hey Norm-- not to piss in your Cheerios but you DID put thinset under that Hardi, right?
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 02-11-2008, 07:06 PM   #7
Sharp Improvements
What, do you take me for a hack?
Of course I did!!!!!!!
Norman Sharp
Old 02-11-2008, 07:19 PM   #8
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Roofing nailer works great. It's faster and so you'll likely to shoot more nails into the board which is good. You do have to good back and drive most of the nails after. That's just the way it is with Hardi.
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 02-11-2008, 08:08 PM   #9
Originally Posted by JazMan View Post
Roofing nailer works great. It's faster and so you'll likely to shoot more nails into the board which is good. You do have to good back and drive most of the nails after. That's just the way it is with Hardi. Jaz
with thinset.
So Bill what do you say?
neolitic is offline
Old 02-11-2008, 08:31 PM   #10
tile contractor
Iiiiiii'm sorry. :
Old 02-11-2008, 08:39 PM   #11
Iiiiiii'm sorry. :
No,no,no,
you can piss in Norrrrrrrrrrm's cheerio's
all you want!
What about using electro-galvanized
under thinset?
It's sort of corrosive isn't it?
neolitic is offline
Old 02-11-2008, 08:47 PM   #12
tile contractor
To tell you the truth, I don't ever use nails, so I haven't really paid much attention to which ones are good and which ones aren't (screws don't back out!). I didn't know there was a problem with ANY of the galvanized nails, so for this one, I think I'll just sit back and learn.
Old 02-11-2008, 09:06 PM   #13
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Installation instructions from the James Hardie website specify only, "Minimum 1-1/4" long corrosion-resistant roofing nails."
If you call their tech support dept, they'll tell you the electro plated galvi's are fine.
A lot of guys don't like to use the electro galvanized nails for whatever reason. Myself and others have used them without any problems.
HS345 is offline
Old 02-11-2008, 09:18 PM   #14
Cool.
I'm one that doesn't believe in electro-galvanized
anything.
Used to use hot dipped roofers when I first found
"Wonderboard" in the 70's.
All coated backer or hot dipped screws for many moons.
Hot dip is more corrosion resistant,
but whatever.
Only crusade is to learn something now and again.
neolitic is offline
Old 02-11-2008, 09:23 PM   #15
tile mason
MattCoops's Avatar
You mean to tell me you used to work at Delta Roofing in Billerica, MA with Joe and Gray Gary, and then switch hit with "Steve" at Edge Metal Systems, Inc. ???
St0rman N0rman,
Did you use a "rippagh" hammer for your copper nails, with the slick shaft?
That's what we use at Matthew J Cupan's Custom Tile and Paint!, for nailen all over little Miss Kerdi; we lay her on the floor and set tile all over her perimeters.
MattCoops is offline
Old 02-11-2008, 09:31 PM   #16
BCULP2's Avatar
Trade: General Contractor, Residential Remodeling
We use 1 1/2" or 1 3/4" roofing nails with our guns. Works great.
BCULP2 is offline
Old 02-11-2008, 09:32 PM   #17
Tile Contractor
HS345's Avatar
There's no question that hot dipped galvi's are more corrosion resistant, and screws are even better, but the roofing gun is sooo much faster.
Of course, if you use Schluter products you don't have to worry about such things.
HS345 is offline
Old 02-13-2008, 10:17 PM   #18
Sharp Improvements
St0rman N0rman,
I'm not sure how to take that post, I think it is over my head. Im from the d.c. area and have lived in cali, N.J. and now N.C.. But I will talk with that wicked awsome accent if you want me to!!!!!! hah
Bill,
I was just joking when you asked about the thinset hack thing. I was working/thinking today and thought I may have offended you. Not the intention.
Norman Sharp
Old 02-13-2008, 10:30 PM   #19
tile contractor
I unnastand. I, too, was worried that I'd offended YOU!
It's tough sometimes when you can't see the other guy's face!
Old 02-13-2008, 10:59 PM   #20
Tile & Marble Contractor
Ceramictec's Avatar
Trade: Tampa Tile Contractor
I use a Rigid coil nail gun and love it.
had a BeA years ago a roofer friend gave me and I wore that thing into the ground.
I would buy a new gun again if I have to hand nail 500+ nails in a floor or nail up some cement board on a ceiling.
Ceramictec is offline
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
Production Manager - Roofing (Seeattle WA) raynproof Help Wanted or Looking For Work 0 10-12-2007 05:31 PM
GAF nailing strip Jaketoo Roofing 12 08-10-2007 07:58 PM
Roofing License stevel27 Roofing 10 03-28-2007 06:19 PM
