Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring > Ceramic & Stone Tile
Old 05-03-2006, 04:40 PM   #1
Tile Contractor
"MUD" - What is it?
Here's some information I posted to another ceramic tile site and I thought it would be beneficial to some people here also. Maybe it will help to clear up some confusion.
THINSET: is a form of tile adhesive, it comes two ways.
Modified and Unmodified, and those two ways also come in grey and white. There are more variations and more coming but this will give you the basic idea. Thinset is a portland cement type product.
MODIFIED THINSET: comes with all the necessary additives already in the bag and you add only water, nothing else. There are a variety of modified thinsets, as the price goes up the quality (additives) goes up.
UNMODIFIED THINSET: has no additives and you add water to it.
You can however include your own additives to make unmodified thinset into modified thinset and this method will result in a modified thinset that is in fact stronger than the basic modified thinset you buy in the bag.
DECK-MUD: is the cement product used to cast the preslope of a shower at 1/4" of slope per foot and also the final slope also at 1/4" per foot. It is made up of one part portland cement to four parts sand, nothing else. Usually you mix all of the components yourself.
FAT-MUD: is the same as 'deck-mud' but fat-mud also contains lime. Lime in the mixture is required for vertical surfaces such as curbs and dams and walls. Fat-mud is usually mixed at one part portland one part lime four parts sand and you mix all of the components yourself.
SANDMIX: is for these purposes the same thing as 'deck-mud' except you purchase sandmix already mixed in the bag, just ad water nothing else.
MORTAR MIX: is for these purposes the same thing as fat-mud except you purchase mortarmix already mixed in the bag, just add water nothing else. The lime is already there for you.
ADDITIVES: can be a variety of latexs or polymers or whatevers and they are usually product specific meaning they are only compatible with recommended products and shouldn't necessarily be mixed with other products helter-skelter whenever the moods strike.
SLC's (SELF LEVELLING COMPOUNDS): Have a very specific recipe and already contain all of the necessary additives. SLC's get mixed with a measured amount of water only and you never add anything else to the mix. You never tamper with SLC's.
PATCHING COMPOUNDS: are also available in a variety of mixes and are used to make repairs and corrections but usually only require water and they are formulated to stick and stay with the surface to which they are applied. Patching products come in both portland cement styles and gypsum styles. ONLY portland cement styles of patching compounds are suitable for ceramic tile projects. Gypsum based patching products should never be co-phased with tile installation setting materials. NEVER.
It is not wise to concoct your own recipes. Just because you have something left-over from before, to think that adding some foriegn additive to any powdered product will "beef-it-up" is foolish. In some cases this random mixing is totally counter-productive and will ruin the product and void its original purpose.
I know this is confusing information. All of the above products are unfortunately referred to as "MUD" in the tile trade. People familiar with the trade usually know which "mud" is being talked about depending on the phase the job is in.
When you refer to a particular product here please call it by its trade name not its generic name so we have some idea of what is being talked about.
-Bud Cline 5/06
Bud Cline is offline   Reply With Quote
Old 06-19-2006, 07:13 PM   #2
Trade: low voltage systems
Can you answer why a contractor would build up 3 inches of mud? does this violate and codes?
scubagreg is offline   Reply With Quote
Old 06-19-2006, 07:34 PM   #3
R&D Tile's Avatar
Trade: Tile installations
I've seen 4" of concrete in old brownstones, the only reason I can think off is to level a floor that is out that much, that's alot though.
R&D Tile is offline   Reply With Quote
Old 06-20-2006, 10:43 AM   #4
Tile Contractor
Probably the guy was looking to create some rigidity in the substrate. No code violations I'm aware of but there is added weight, in this case about 6 pounds per square foot if my math is correct but even at that it shouldn't be a problem depending on the structural criteria of the floor.
Old 07-07-2006, 01:34 PM   #5
ee3
Trade: mfg.
12 lbs per sq. ft.per inch. thick
ee3 is offline   Reply With Quote
Old 07-07-2006, 06:25 PM   #6
Teetorbilt's Avatar
Dad mixed all of his own stuff back in the 40's through 70's. I wish that he had written down all of the formulas. So much has been lost!
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 07-08-2006, 07:49 PM   #7
R&D Tile's Avatar
Same mix today, Portland cement and sand, not much has changed through the years.
Old 07-08-2006, 09:15 PM   #8
Teetorbilt's Avatar
He had all of the proportions in his head and they were modified to application. The same with concrete and mortar.
I don't think that we ever mixed the same batch twice. He always accounted for everything. Temp, humidity, moisture in the product/surface, everything! Truely 'old school'. Used to put the ratios on cardboard for the mixers and sometimes change them 4 times a day.
Albert Einstein
Old 01-08-2007, 10:57 PM   #9
mostly showers
Trade: Tile & Stone
hey bud
what's that other tile site you mentioned?
numbknees is offline   Reply With Quote
Old 01-09-2007, 11:00 PM   #10
Tile Contractor
You'll have to tell ADMIN over there that I sent you if you want a front-row seat. Seriously.
http://www.thefloorpro.com
Enjoy.
Old 01-09-2007, 11:45 PM   #11
can you define "hot mud"?
ty
POOLMANinCT is offline   Reply With Quote
Old 01-10-2007, 12:17 AM   #12
mdshunk's Avatar
It's a spa treatment women pay lots of money for. Other than that, it's the drywall finishing material that comes in bags that you mix yourself. It will have 20, 45, 90, etc on the bag as far as how "quick" it is.
mdshunk is offline   Reply With Quote
The Following User Says Thank You to mdshunk For This Useful Post:
sparehair (04-08-2009)
Old 01-10-2007, 12:20 AM   #13
ty md but not the definition i was looking for..
its site-made mix w/ a ploymer used for quick cure...
& calcium is not used to hasten the cure.. any1 know the recipe?
ty
ray
Old 01-10-2007, 04:40 PM   #14
Tile Contractor
I have always referred to any quick-drying portland cement product as "hot mud".
Old 02-17-2007, 09:18 PM   #15
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Haven't I seen some of you guys on floorstransformed.com?
Norrrrrrrrrrrrm is offline   Reply With Quote
Old 02-18-2007, 12:06 AM   #16
Tile Contractor
Yip!
Old 03-07-2007, 12:36 PM   #17
Commercial Contractor
Mud Master's Avatar
Trade: Wood/Metal Framing, Carpentry(Rough), Insulation, Drywall, Plaster, Acoustical
Send a message via AIM to Mud Master
Pool, I think your referring to "Poly-Mix". It's a 2 part concrete.When I was working for my father we used it to pour Piers for steel erected buildings. You mix one part of the bag, and another part that came in a can, like a gallon of paint would. Mix it fast and pour it in your form.
It's made for pours under 30 degrees. It can actually be poured to -15. Stuff sets up FAST, to the point it will literally burn you if you touch it during the first hour of curing. NEVER use it in the summer, you'll never get to the hard trowel unless you have 50 guys. It's additives make it set up way to fast.
I'm figuring thats what your talking about. Thats the only thing I can think of thats poly-mer w/ calcium for quick cure.
Yes, I am that damn good.
Mud Master is offline   Reply With Quote
Old 03-07-2007, 08:14 PM   #18
Trade: general contractor
when forming a shower pan. after initial deck mud to create slope 1/4 " per foor, then 90 mil shower liner, do you wrap it up and over the curb? then then deck mud over that with wire? fastening the wire. do you nail thru the shower pan liner.
10secondTone is offline   Reply With Quote
Old 03-08-2007, 07:05 PM   #19
Tile Contractor
WHERE does one find 90mil shower pan liners?
Never nail through the pan liner lower than three inches above the top of the curb or on the curb (inside or top). YES, the liner goes over the curb if you aren't using a formed curb product.
Old 10-09-2007, 03:03 PM   #20
Trade: General Building Contractor
Thumbs up Much info on Mud
Thanks for the straight scoop in MUD. My contractor husband was going nuts doing our bathroom shower and could not recall the "exact recipe" for shower floor mud. Your answer re Deck Mud was just right.
Thanks.....
C. Rechenmacher
Littlerock, CA
onephnurse is offline   Reply With Quote
