More Tile Guy Help
Old 11-21-2009, 09:33 PM   #1
robin303's Avatar
Trade: Remodel and new construction Austin, TX
More Tile Guy Help
If you had a front door entry at 42" wide with a 36" door and 8' long where would you start the 1st tile. To make it look right I would center the tile in the center of the front door. Or would you use the long base wall as your base line. In other words to look good but limit all the cuts.
I'm a wood guy. Thanks
Robin303 Army Air Slideshow
robin303 is offline
Old 11-21-2009, 09:48 PM   #2
genecarp's Avatar
Re: More Tile Guy Help
Robin, hard to say without a picture of the whole layout. Based on the limited info, find door center, lay tile dead center, break right and left, see what size pieces you end up with against each wall. Next find door center, lay grout line at center mark, break right then left, see what size pieces you end up with along each wall. If there is one wall that is hidden, like under baseboard heat, you can use the long wall as a full tile----IF it is PERFECTLY square to the front door, compromise is most often the case, good luck GMOD.
genecarp is offline
Old 11-21-2009, 10:01 PM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
What's the format and pattern of the tile?
Cuts don't bother me, but skinny pieces do. Does it step into any closets?
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 11-21-2009, 10:39 PM   #4
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Tile size and pattern?
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 11-22-2009, 02:11 AM   #5
Its all ball bearings
angus242's Avatar
Trade: Tile
What's the difference? Aesthetics is aesthetics.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
Old 11-22-2009, 09:37 PM   #6
MarcD's Avatar
Trade: Making Everyone Happy
I would make my cuts go along the wall and against the door so the tile that butts up to the opening of the room is a full tile, But that is asthetics and depends on size/pattern and what the ho is looking for.
MarcD is offline
Removing tile that is set under base cabinets.. bujaly Flooring 43 03-13-2010 05:15 PM
Tearing Up Tile for My Folks (TILE GUYS PLEASE HELP!)- Opinions Please tuffplay General Discussion 30 11-22-2009 05:50 PM
Drywall over ceramic tile kirkwahl Drywall 9 10-02-2009 10:11 AM
Tile over Tile fireguy Flooring 3 02-26-2009 11:36 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 07:44 AM
