Montolit Masterpiuma Tile Cutter P3 - Tiling - Contractor Talk
Old 10-29-2017, 06:47 PM   #1
Renaissance Man
superseal's Avatar
Rewards Points: 5,630
Just snagged a great deal on one of these and I'm dying to try it out. It's the 44 or 17" model and I've been wanting one for awhile.
Now I just need a metric tape measure
https://www.youtube.com/watch?v=DkD0HBlODbU
supersealconstruction.com
superseal is online now
Old 10-29-2017, 07:00 PM   #2
tjbnwi's Avatar
Rewards Points: 5,402
Re: Montolit Masterpiuma Tile Cutter P3
Great cutter, I have the 24" and the mosaic mat.
tjbnwi is online now
superseal (10-29-2017)
Old 10-29-2017, 07:06 PM   #3
Renaissance Man
superseal's Avatar
I definitely want a bigger one as well, it's just a hard choice picking which one...
Old 11-08-2017, 08:21 PM   #4
Mr_Stop's Avatar
Rewards Points: 282
Where did you find the deal on the Montolit? Need to pick up a new cutter in the next week and trying to decide between one of the Montolits or Sigmas.
Mr_Stop is offline
Old 11-08-2017, 08:34 PM   #5
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,296
What’s the science behind the oiled cutter?
Big Johnson is online now
Old 11-08-2017, 08:52 PM   #6
Renaissance Man
superseal's Avatar
E bay...private seller, I literally stole it. They only had two, new in box...factory sealed. I went back yesterday to buy the other one for my nephew and it was gone
I just received it yesterday...i can't stop hugging it it's got the titanium coated carbide wheel as well.
You can't go wrong with Sigma either...there's just something about Brevetti Montolit MasterPiuma that tickles my fancy...it's extremely lightweight as well as handling up to 22mm thickness
Old 11-08-2017, 09:03 PM   #7
tjbnwi's Avatar
I have a 48" Rubi and the 24" Montolit. There's something about the sound of the cutter on the Mono that is music to the ears.
I went with the Rubi due to recommendations here. I would have gone with the 48" Mono if I had used one prior to getting the Rubi.
Only thing I wish the Mono had outriggers to support cross cuts.
superseal (11-08-2017)
Old 11-08-2017, 09:05 PM   #8
tjbnwi's Avatar
I don't know the science, my guess is the wheel tools better across the hills and valleys instead of stoping and starting at each bump.
Old 11-08-2017, 09:08 PM   #9
Renaissance Man
superseal's Avatar
They recommend it for textured porcelain or for thick materials when the applied pressure to the cutter is greater.
Nothing special, just WD40 packets
Old 11-08-2017, 09:13 PM   #10
Renaissance Man
superseal's Avatar
Only thing I wish the Rubi had was outriggers to support cross cuts.
That Rubi has got to be massive
Old 11-08-2017, 09:17 PM   #11
Renaissance Man
superseal's Avatar
Up next is the Mosaic mat...unless I can make my own...is it possible Tom? Those dang things are nearly 80 clams but worth every penny I'm sure.
I have access to some rubber matting materials, and I know it needs a groove cut in the back of it...I think anyway.
Old 11-08-2017, 10:01 PM   #12
tjbnwi's Avatar
It is expensive, I had a run of glass backsplashes to do. Paid for itself job one.
It's not a groove, it's a spline that holds the mat centered.
Old 11-08-2017, 10:06 PM   #13
tjbnwi's Avatar
It is. Another one of those I had the jobs to support the purchase.
I edited my previous post about the Mono and Rubi. The Rubi does have swing out outriggers, I wish the Mono had outriggers to support long tile on cross cuts. Today I had a couple of tile snap while cross cutting them on the Mono before I reached the end of the score due to the overhung weight.
Old 11-08-2017, 10:16 PM   #14
Mr_Stop's Avatar
Rewards Points: 282
Thanks for pointing out about outriggers/support. My next job contains some 8x40" plank tile. I'll make sure to fab some supports if the cutter doesn't include big enough outriggers.
Mr_Stop is offline
Old 11-09-2017, 06:21 AM   #15
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,634
Build a table with a recess for the cutter to sit in. I like the idea so much I might do that myself.
Home Designer Series Software
B.Johnson is offline
Old 11-09-2017, 06:40 AM   #16
What did it set you back?
Old 11-09-2017, 07:49 AM   #17
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,864
Craig used a hobby cutting matt on his IIRC.
Inner10 is online now
superseal (11-09-2017)
Old 11-09-2017, 09:32 AM   #18
Mr_Stop's Avatar
Rewards Points: 282
Thanks for the tip. Is this the thread?
http://www.contractortalk.com/f73/gl...ng-tip-117372/
Mr_Stop is offline
Old 11-12-2017, 09:13 PM   #19
Renaissance Man
superseal's Avatar
Instead of getting a metric tape measure for use with the Masterpiuma, I've settled on Starrett measure stix to do the job...now why didn't I think of that
Good quality steel tape with adhesive backing...sticks permanently to most surfaces...now that's what I'm talking about.
Montolit Masterpiuma Tile Cutter P3-img_4125.jpg   Montolit Masterpiuma Tile Cutter P3-img_4126.jpg
Old 11-12-2017, 09:37 PM   #20
Mr_Stop's Avatar
Rewards Points: 282
Ordered the Montolit 24" model on Friday. Arrives on Tuesday and I can't wait!
Mr_Stop is offline
The Following User Says Thank You to Mr_Stop For This Useful Post:
superseal (11-12-2017)
tile cutter jordan23 Tiling 12 07-30-2013 08:09 AM
Know Your Tile Type tilecleaningTX General Discussion 0 11-21-2012 04:15 PM
Ready for Tile Bob. Tiling 1 11-18-2012 06:30 PM
Tile Cutter - Superior or T - Handle ? We Fix Houses Tiling 1 06-19-2010 10:38 AM
