Sharp Improvements
Mold On Tile In Shower
Hey Guys,
I have a situation where there is a bit of mold on a shower floor and a little bit on the wall. I suspect the sealer has thinned out and not great ventilation when the shower is used. The tile is travertine. What is the best way to go about cleaning this up without damaging the stone? I have read vinegar, but also read it is not good. Thanks, Norm |
#2 | |
Its all ball bearings
Trade: Tile
Re: Mold On Tile In ShowerQuote:
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Sharp Improvements
A bit of both, mostly in the grout. The tile has some in the deeper crevasses due to the nature of the stone.
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Another reason not to use natural stone in showers.
Your shower was not built with waterproofing in mind most likely. You may not have a pre-slope under the membrane. Do you know how it was built, step by step and with what materials? Sealer has nothing to do with waterproofing a shower or keeping water out of the grout or tiles. I'm guessing your base and maybe part of your walls are saturated. You can bet it's much wetter behind and under the tiles than it appears. You can kill surface mold with Concrobium, but I don't believe it'll remove the black, and you'll still have problem again. Jaz |
Sharp Improvements
It was built with a 1/4'' slope per ft with the first bed, rubber membrane, matching slope again, then added another roll on waterproofing membrane for extra security and tiled. Do you think the second membrane is not letting the water drain even with the slope? Dal Tile had recommended the second membrane. I am a little concerned.
#6 | |
Trade: Tile
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" Last edited by angus242; 10-18-2009 at 09:22 PM. Reason: spelling |
Sharp Improvements
I wore socks when I tiled on top the membrane and I put two coats of the membrane down. The weep holes were not covered up. Dang.
Trade: Tile
Geez Norm, I dunno
![]() I totally agree with Jaz. I'd bet there's moisture sitting under the tile or mud bed and that's the source of the mold. Not that this helps you but for anyone else reading, this is why I prefer a fabric-style membrane (KERDI). I feel they are much more reliable in such a critical area.
Sharp Improvements
I appreciate the help. After the posts I decided to get super stiff brush, turn the shower on and went to town on the tile as I showered. Nothing like multitasking. My main squeeze gave me a weird look when she looked in as to what I was doing. But most of the stuff came off then. I will go back and clean with another solution(concrobium) to see if it stops. I used a light acid before and it did not seem to do as good as a job as the brush and water. It has been 2 1/2 years since the shower was built and for it now to start was puzzling me. Like in my earlier post, I think my girlfriend and I are not letting the tile dry in time. I guess we need to shower together more often to prevent this problem! Thanks guys,
Norm |
#10 | |
Trade: Tile installations
Get some Zep Mold & Mildew remover, test it first on a small area to see if it does anything to the stone, if not, use it, no scrubbing, just spray it on, wait an hr. or so and rinse. |
Tile and Stone Cleaning
Trade: Tile and Stone Restoration
For any stone shower you better go to either mbstone.com or stonecarecental.com and buy both:
MB-3 and MB-9 I use them all the time and nothing is better or safer in an acid sensitive shower. |
#12 | |
Remodeling GC
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
| The Following User Says Thank You to kevjob For This Useful Post: | skyhook (11-22-2009) |
tile mason
What kind of water is it? City punch or well?
I ran into a situation like that no too long ago on a well system. And the water needed to be treated. It was white gunky build-ups though, not mold. How often is the shower cleaned? Is there a vent fan in the shower area? And is it used? It may be something as simple as a low spot where water accumulates and then the mold builds up. For future reference, 1/4" slope is the MINIMUM. The slopes I do are almost double that amount. I can tell you for sure, it is definitely NOT a sealer issue. Run the water a few minutes. Shut off. See how long the water takes to disapear. Are there any "puddles" left anywhere?
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more Last edited by MattCoops; 11-07-2009 at 07:17 PM. |
tile mason
There's a couple ads for VENT FANS on this page to the right and bottom.
You may want to buy one of them. Nathan will appreciate it.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
#15 | |
Pedro
Trade: Stone & Tile Cleaning
If the mold comes back, dilute bleach with water and keep in a spray bottle and spray the mold when you first see it return. Be sure it's diluted as the akaline bleach can cause some etching as well.
Pedro Najar Integrity Stone & Tile Cleaning www.integrity-tile-and-grout-cleaning.com |
Where in my post did I mention using an acid product.
Read it again and try the products I said. They are magic on stone showers. |
Pedro
Actually, I agree with you and recommend the same products.
I was just stating never use acids when cleaning natural stone. When I posted, I noticed it look like I was contesting what you said, but in reality I was agreeing wholeheartily. Sorry for the confusion.
| Tile over existing shower surface | SK Builders | Ceramic & Stone Tile | 16 | 07-06-2009 01:42 AM |
| Shower leaks / Tile / new construction | keytermite | Ceramic & Stone Tile | 9 | 03-27-2009 08:05 AM |
| how many courses for ceramic tile shower walls? | Bazooka Joe | Ceramic & Stone Tile | 19 | 02-14-2009 11:06 PM |
| Tile in shower? | gtmstang | Flooring | 14 | 09-23-2008 09:55 PM |
| Questions on Tiled Shower | ksensen | Remodeling | 10 | 09-10-2007 09:54 AM |
