Holder of hands
Trade: Custom builder/remodeler
Modified/unmodified
So I've been building some showers with Mapelastic waterproofing and mesh, some with Wedi, some Noble. All of these claim to be waterproof, just like Kerdi, but with Kerdi, you need to use an unmodified thinset since you are sandwiching thinset between two non permeable surfaces and the thinset cannot get air to dry. I use Ditra on the floors a lot, and have been using unmodified for the tiles without problems, but I haven't ventured into the Kerdi showers because I like the system I already have.
These other systems allow for modified thinset. I guess I really don't see much difference as far as air getting to the thinset. Maybe I am missing something. Thoughts?
CapStone Home Renovations website Follow us on Facebook Follow us on Twitter |
#2 | |
Trade: Control Systems
Re: Modified/unmodifiedQuote:
| The Following User Says Thank You to Inner10 For This Useful Post: | skcolo (11-03-2012) |
Trade: Zoned
Call Schluter. Have them explain it to you. I still don't get it.
Angus |
| The Following User Says Thank You to angus242 For This Useful Post: | skcolo (11-03-2012) |
Holder of hands
I was hoping you would have the answer.
Trade: Zoned
Their answer is modified cannot fully cure when sandwiched between a waterproof membrane and tile. Unmodified self cures.
What they've never been able to address is why every other company allows it if it's really such a bad situation. I always try to give 2 days to cure before grouting when using modified over a membrane.
Angus |
Anyone ever put some modified mortar in a sealed container and see how it cures?
Trade: Zoned
That's not really the point.
But I have put plenty of porcelain over membranes using modified. There have been a few times the following day, I found a tile I didn't like and removed it. In 18-ish hours the thinset was not cured. It was set enough to support floor tile but still needed time to fully cure. This is why I won't grout for 2 days. If time is a real issue, rapid set thinset can be specified. It's only a few dollars more per bag and doesn't break the budget. For those that have access to, Ardex makes some wonderful thinsets. Worth looking in to.
Angus |
#8 | |
Holder of hands
Remodeling GC
Steve we use versabond over kerdi all the time. If we use anything modified more we give more time to cure before grouting (2 days or so) and havent had any issue and if we did with unmodified I wouldnt be waiting for Schluter to do anything warranty wise
| The Following User Says Thank You to kevjob For This Useful Post: | skcolo (11-03-2012) |
Orlando Car
Trade: certified floor covering installer.
253 Gold over and under Ditra..
Wait two days them come back with Spectralock pro grout and you got yourself a lifetime tile installation
http://www.facebook.com/#!/certifiedfloorcovering Certified Floor Covering Serving All California ( 510 ) 760 - 6810 |
| The Following User Says Thank You to Floormasta78 For This Useful Post: | skcolo (11-06-2012) |
YUUUUP!
Trade: Metal Roofing Mogul
So sayeth the MASTA!
| The Following User Says Thank You to JWilliams For This Useful Post: | Floormasta78 (11-05-2012) |
But the warranty! Ohhhh the humanity!
| The Following 2 Users Say Thank You to Inner10 For This Useful Post: | Floormasta78 (11-05-2012), olzo55 (11-05-2012) |
Orlando Car
Schulter might not even be around next time this new home gets flooring again..
| The Following User Says Thank You to Floormasta78 For This Useful Post: | sycamorebob (11-06-2012) |
Dayton Basement Finishing
In theory Schluter is right. In practical application everyone else is right..
____Matt Geddis____![]() .........................Like Us On FACEBOOKOhio Home Doctor Remodeling Dot Com Last edited by ohiohomedoctor; 11-06-2012 at 06:33 PM. |
Orlando Car
Well in theory, we are not all greeks.. So forget that !
We practice what we preach. I'm Father Floor Master. Now let's pray for all those hacks out there...
Groutface
Trade: flooring installer
Schluter will be around for the next ice age and they will make freezethaw stable showers......huhuh
| The Following User Says Thank You to Groutface For This Useful Post: | Floormasta78 (11-06-2012) |
Wearer of Hats
Trade: Kitchen and Bath Remodel
I use unmodified over ditra simply because it's what the manufacturer recommends and that's typically what I go with, but seriously, I don't see why it would be a big deal. Eventually that moisture will escape out the sides, no matter what, and damp modified thinset is still crazy strong after just a few hours. We all know that manufacturer recommendations tend to be overkill. They have to, because they know that idiots will push anything to it's limit and the easiest solution is to set that limit past practicality.
It's kind of like how most rope will easily hold double its test weight. Thinset almost always says no walking on tile for 24 hours, but I'll bet a lot of us walk on tile that's been down for 12-14 overnight. Having removed a few tiles I didn't like over the years, I can say that 12 hours and even the fattest man doing windsprints across the floor isn't making that tile move. It's all CYA. |
