MLT Inquiry
Old 04-18-2017, 09:55 PM   #1
tjbnwi's Avatar
Rewards Points: 3,450
MLT Inquiry
Have a job coming up, 120 square feet of polished marble wall tile.
I normally use the RLS. I'm concerned about the wedges scratching the marble.
What I'm considering getting are the green bases with the separate strap, pressure caps with rubber feet, setting tool.
Open to suggestions.
tjbnwi is online now
Old 04-18-2017, 10:04 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 900
Re: MLT Inquiry
Try some test pieces first? Maybe slip some masking paper under the wedges??
overanalyze is online now
Old 04-18-2017, 10:08 PM   #3
tjbnwi's Avatar
Re: MLT Inquiry
Could test the set up once I get to the job. Won't be installing tile until a few weeks after.
Looked at the MLT website, they now have a plate for stone and marble.
I have some UHMW sheet I could cut up for under the wedges----huummmm
Old 04-18-2017, 11:05 PM   #4
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Re: MLT Inquiry
Tom you are looking at one of the few job scenarios Where MLT is the best choice. I use between 3-5000 RLS clips a month and am a vocal supporter of them but If I had that job coming up I would pick up a MLT starter kit. (More likely borrow one of my buddies and pick up 500 clips and give him the left overs.
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
Wile E Coyote (04-26-2017)
Old 04-19-2017, 01:13 AM   #5
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,678
Re: MLT Inquiry
At first I started with the Tornado system made by the same folks that produce the MLT System. It was horrible. I looked at all that was available at the time, and choose the MLT. Never regretted it. My gun does get sticky and won't release properly. Not a big deal but does slow me down. Nick was supposed to send me a new one and got my address, but never followed up, so they loose a star for customer service. What I really like is the fact that I can apply a good amount of pressure and everything stays straight. You will learn quickly how tight you can go before the stem snaps off. Something will be needed to protect soft shiny tiles though, for which there are options available from the manufacturer, or a lot of work could provide another solution.
Peter_C is offline
Old 04-19-2017, 08:25 AM   #6
tjbnwi's Avatar
Re: MLT Inquiry
Thanks. I'll see if they make a starter kit with the P3 plate.
I'll be using the RLS on the porcelain large format floor tiles.
Alas----I have no buddies or friends...
charimon (04-21-2017)
Old 04-24-2017, 11:59 PM   #7
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,654
Re: MLT Inquiry
They make plates for wedges systems. They work on LevTec, RLS, PLM... I will try and find the link.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
Old 04-25-2017, 09:05 AM   #8
Hair Splitter
Trade: General
Re: MLT Inquiry
http://www.tiletools.com/product/uni...eling-systems/
The Following 9 Users Say Thank You to TNTSERVICES For This Useful Post:
avenge (04-25-2017), Dan_Watson (04-25-2017), Golden view (12-26-2017), goneelkn (04-25-2017), Inner10 (04-25-2017), overanalyze (04-25-2017), Peter_C (04-26-2017), rblakes1 (06-25-2017), Xtrememtnbiker (04-25-2017)
Old 04-25-2017, 09:06 AM   #9
Hair Splitter
Trade: General
Re: MLT Inquiry
The Following 2 Users Say Thank You to TNTSERVICES For This Useful Post:
BlueRidgeGreen (04-25-2017), Golden view (12-26-2017)
Old 04-25-2017, 11:50 AM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,496
Re: MLT Inquiry
Originally Posted by TNTSERVICES View Post
That's the ticket right there.
Inner10 is online now
Old 04-25-2017, 03:21 PM   #11
Always Learning
Rewards Points: 900
Re: MLT Inquiry
I bet those would help with preventing the wedges from pushing the tile apart too.
Sent from my SM-G920V using Tapatalk
Old 04-25-2017, 04:03 PM   #12
Hair Splitter
Trade: General
Re: MLT Inquiry
I never have that issue. I just shim in between the wall and tile and then push towards the wall. Occasionally I will tap the row with a mallet to tighten everything up.
Old 04-25-2017, 04:13 PM   #13
Always Learning
Rewards Points: 900
Re: MLT Inquiry
Yeah it doesn't happen a lot but seems to more on tiles with a rougher surface.
Old 04-25-2017, 04:44 PM   #14
Inner10's Avatar
Re: MLT Inquiry
I find it happens more when you are using your fingers vs the tool.
Old 04-25-2017, 05:45 PM   #15
tjbnwi's Avatar
Re: MLT Inquiry
Thank you, very much appreciated.
Looks like thats what I'm going with.
Hopefully the tile is gauged, if not will the "regular" plates work. Guess I'll find out.
Old 04-25-2017, 05:53 PM   #16
tjbnwi's Avatar
Re: MLT Inquiry
Ordered.
Old 04-25-2017, 08:17 PM   #17
Hair Splitter
Trade: General
Re: MLT Inquiry
Not if you know how to use your fingers instead of the tool.
Push the top of the clip towards the wedge. Put a little pressure on the wedge and allow it to release the tension on the clip. Repeat until optimum tension is reached. The tile shouldn't move at all.
Old 04-25-2017, 08:18 PM   #18
Hair Splitter
Trade: General
Re: MLT Inquiry
Marble is usually gauged.
Old 04-25-2017, 09:17 PM   #19
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 889
Re: MLT Inquiry
I've had the odd tile chip on the edge after hitting the clips off with a rubber mallet. Any thoughts on reducing this issue. Would the discs help. I use the t loc wedges a lot
gowings is offline
Old 04-25-2017, 10:50 PM   #20
Hair Splitter
Trade: General
Re: MLT Inquiry
Where are you hitting the clip?
Armen makes a nice mallet for tile. http://www.tavytools.com/2012mallet.html
Job Specific Kitchen Crown moulding inquiry tucnasam Carpentry 13 07-31-2016 12:03 PM
License reassignment inquiry csadco7 Contractor Licensing 2 03-08-2016 09:26 AM
crazy inspector? house foundation inquiry illbuildit.dd General Discussion 16 08-11-2015 08:48 PM
Timber Tech Consumer Inquiry Program ECSOWNER Marketing & Sales 1 07-27-2012 08:25 AM
Has anyone used Pay Per Inquiry Advertising Jake101 Marketing & Sales 1 12-09-2008 03:09 PM
