Marble Floor Tile Tips?
Old 02-29-2008, 05:34 PM   #1
Remodeling Professionals
buildenterprise's Avatar
I am getting ready to lay about 210 sf of 12 x 12 marble on a kitchen floor in an older home. It will be laid over 1/2" hardibacker on 3/4 t & g. The floor sags toward the middle of the room but has been shored up so it's pretty solid, and it's not uneven, just saggy. Several questions:
How tight should the joints be? I know it's pretty close with marble since I need to use unsanded grout, correct? Also, what size trowel should I use for the mortar? Any other tips for laying marble?
Thanks guys.
buildenterprise is offline
Old 02-29-2008, 05:41 PM   #2
R&D Tile's Avatar
Trade: Tile installations
Re: Marble Floor Tile Tips?
For starters, how can it be flat and saggy at the same time.
Also, you NEED 2 layers of plywood before a CBU or membrane, and are you SURE the joists system meets specs for stone.
As for spacing, 1/32 to 1/6" is what I would want.
Trowel size depends on how flat the floor is and if isn't dead on, you'll be backbuttering as you go to avoid lippage, stone is a lot harder to set then plain old ceramic, a whole other ballgame.
R&D Tile is offline
Old 02-29-2008, 06:05 PM   #3
Tile Contractor
Bud Cline's Avatar
Can not simply start by adding tilebacker to existing t&g.
Bud Cline is offline
Old 02-29-2008, 06:32 PM   #4
The floor is not uneven as in bumpy, but it IS out of level toward the center of the room. That make more sense?
They don't want the cabs removed so what happens at the toekick if I need to add another layer of subfloor in addition to the CBU? Should I remove the existing plank subfloor to the toekick to allow for the extra height?
Old 02-29-2008, 07:30 PM   #5
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
I'll tell you what happens if you dont.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 02-29-2008, 07:31 PM   #6
Thom
thom's Avatar
Sounds to me like
The customer wants to pay for a half ass job.
When it's done, and a problem, the customer will want your full ass.
You need to get rid of the bowl. You need to repair the floor framing before you install the floor. Adding tile backer then tile will make it worse, and unfixable without removing the tile and backerboard.
thom is offline
Old 02-29-2008, 07:35 PM   #7
How did you know they were gay?
Old 02-29-2008, 07:51 PM   #8
Its all ball bearings
angus242's Avatar
Trade: Tile
Protecting your ass....nothing gay about that
angus242 is online now
Old 02-29-2008, 08:14 PM   #9
R&D Tile's Avatar
Plain and simple, if I can't do the job the right way and my way, it's the H.....y.
Walk away, not worth it.
R&D Tile is offline
Old 02-29-2008, 08:39 PM   #10
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Marble floor tile tips?
Yep.
Get a pro to do it.
Stone, especially marble is not the floor you wanna learn on the fly. If you have no experience, I would bet a dollar to a soggy donut it will turn out bad. No offense to you or your abilities, but there are many things better left to those that know what they're doing. This is one of them.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 03-01-2008, 10:43 PM   #11
Tile & Marble Contractor
Ceramictec's Avatar
Trade: Tampa Tile Contractor
I would say do a mud bed and set the tile. but you say they wont remove cabs.
an extra layer of ply wont take out the rolls.
Mud will.
I would tell them the way it has to be done or your looking for trouble doing the job, you'll have a real hard time setting the marble flat.
-Brian-
Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota
website: www.ceramictec.com
Ceramictec is offline
Old 03-02-2008, 01:37 AM   #12
Knowledge Factory
Floordude's Avatar
To even be asking, your in way over your head!!!
Time to back out, before you lose more then you make.
http://www.AustinFloorguy.com
Floordude is offline
Cleaning marble tgeb Ceramic & Stone Tile 15 05-19-2008 07:14 PM
Tiling over Existing Marble in Shower Tommy C Kitchens & Baths 3 02-22-2008 07:17 PM
Tile Over Existing Marble Tommy C Ceramic & Stone Tile 5 02-21-2008 12:18 AM
Tiling over Marble??? RussellF Ceramic & Stone Tile 5 01-27-2007 08:12 PM
White Marble Stained and needs Cleaned ABLE1 Masonry 4 07-31-2006 10:34 PM
