Looking For Tip On Installing Ceramic Tiles
I usally sub out this kind of work, but for some reason I want to try to tile a floor. It's a flat concrete floor (basement slab) and about as basic as it gets, 12"x12" tiles. Are there any tips or tricks to make sure the tiles are all level and very straight other than using spacers, and a level, and starting with good layout lines?
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Looking For Tip On Installing Ceramic Tiles
Yes. Lots of experience, and of course a quality tile. Get ready to pull your hair out if your tiles aren't uniform.
Trade: general contracting
get a book from home depot
Fentoozler
I'm a Mac
Trade: ICF Construction
Hire the usual sub that you use, tell him you will assist him to learn, you know, you don't want his services anymore once you know how to do his job. Maybe, just maybe, he may let you mix his thinset, but chances are he will just let you watch.
Chris |
tile mason
Is your floor level?
Prep work is the most important step in tile installations. Is it a ceramic tile or stone tile? Usually stone requires more effort to eliminate any lippage. Sometimes you'll need to add more thinset in areas and use a grinder on others. If you start with a nice flat level surface, pop grid lines, and use a quality material, you'll enjoy working with tile.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
Fentoozler
On a more serious note ...have you tried the forums over at john bridge?
http://johnbridge.com/vbulletin/index.php
Custom Builder
Ahhhhh .....he said lippage.
Bob |
Fentoozler
Custom Builder
Shut up Bevis.
Bob |
Fentoozler
#12 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Looking For Tip On Installing Ceramic TilesQuote:
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#13 | |
Fentoozler
(and thanks to Terry Love for the plumbing support
#14 | |
In this day and age of rapidly diminishing quality control, - - which started about 20 years ago and has gotten increasingly worse, - - those 'spacers' will RUIN your job if (AND WHEN) the tiles are not perfectly cut to match each other. Do yourself a favor (as mentioned a few posts above), - - and lay out GRID LINES, - - this way even if a few tiles are off a little, - - the overall pattern will stay perfectly straight . . . |
Trowel Monkey
Trade: Tile & Stone Contractor
Hello Mtheisen,
You will need to make sure that there is no lingering residue on the slab, either from previous adhesives or accumulated grime. If you have any sort of layer like that, it needs to be removed mechanically rather than chemically. Solvents and such will cause the grime to soak into the slab, and further impede the mortar's bond. Confirming that the slab is flat is the next step. You don't need it to be level but every variation in the plane will make your tile setting more problematic. Grinding high spots can resolve the residue issue but filling depressions is equally important. Sometimes a self-leveling compound is both cost and labor effective? Snapping chalk lines is a much better method than relying on spacers, but so is simply using a narrow 4" straight-edge to "knock" the tiles into line. The straight-edge method might actually be easier for a novice than following the grid alone, but I do recommend that you follow the grid at the very least. Trowel size is also very important. Not only does the proper trowel size give you 100% coverage it will also allow you to make slight adjustments to the level and plane of the tile. For 12" tile over slab, I prefer a 3/8" squate-notch trowel. Larger notch for larger tile and smaller notch for smaller tile. I also like to keep a straight edge with me as I'm setting to lay across tiles and "settle" them into plane. The type of thinset you use is also important. So called "meduim bed mortars" have a larger aggregate and will support a heavier/larger tile without settling and causing "lippage". Most of the "non-sag" types of mortar are also considered to be medium bed mortars. Best of luck, Shaughnn PS: Chris Johnson, did you happen to grow up in Benicia, CA???
Shaughnn Capua Custom Tile & Stone Card-carrying Schluter Systems installer Certified Wedi Corp. installer |
| wall tiles over wall tiles? | graart | General Discussion | 1 | 07-10-2007 10:16 PM |
| Are you noticing an increasing of ceramic tiles instead of carpet or other materials? | jurovi | General Discussion | 14 | 02-18-2007 01:38 PM |
| Ceramic over luann | scottstef | Flooring | 17 | 12-20-2006 12:11 PM |
| Painting over ceramic tiles?? | theworx | Painting & Finish Work | 4 | 07-07-2006 04:11 PM |
| Vinyl self stick tiles question | Mike Finley | Flooring | 21 | 04-03-2006 07:56 PM |
