Kerdi = Unmodified, Ditra = Modified - Why?
Old 07-13-2010, 09:17 PM   #1
bob_cntrctr's Avatar
Trade: property manager & renovator
Gentlemen,
It's been a while. Hope everyone is well.
Anyway - here's a question that has stuck in the back ofmy mind for some time:
Install instructions specify un-modified thinset between Kerdi and the tiles. Schluter's official explanation is that the impermeable Kerdi will not allow moisture to escape, causing polymer-modified mortars to not cure properly.
But Ditra instructions specify modified thinset between the Ditra and the tiles - and Ditra is no less impermeable than Kerdi.
Anyone know what's really going on?
Thanks.
bob_cntrctr is offline
Old 07-13-2010, 09:26 PM   #2
Remodeling GC
kevjob's Avatar
Rewards Points: 4
Re: Kerdi = Unmodified, Ditra = Modified - Why?
Bob, modified for ditra when installing over wood sub-floor, un-modified is what schluter wants between tiles and ditra. I like kerabond.
Kevin
www.ObrienConstructionDenver.com
kevjob is offline
Old 07-13-2010, 09:29 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Originally Posted by bob_cntrctr View Post
Gentlemen,
Thanks.
You've got it wrong. The ONLY time modified thinset is used is UNDER Ditra when installed over WOOD.
Always unmodified OVER Ditra. Unmodified UNDER Ditra over concrete.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
ApgarNJ (10-27-2010)
Old 07-14-2010, 07:12 AM   #4
You know, I just installed about a mile of Ditra a couple months ago, and I know I did exactly that - modified underneath 'cause it was going over 3/4" plywood, then unmodified on top. But the brain must be getting old, I remembered it backwards, and realized it made no sense that way....
Thanks for jogging the old memory.
Ditra and unmodified primetimeon Flooring 8 05-28-2010 11:25 PM
Ditra Failure abacab Tiling 27 05-04-2010 08:30 PM
Track Record of Ditra and Kerdi Products Morning Wood Flooring 12 04-17-2010 05:14 PM
rapid set with Ditra tang Tiling 4 01-06-2009 08:26 PM
Schluter Kerdi and Ditra Trowels jarvis design Tiling 0 09-06-2008 08:51 AM
